are there something like cleats with straps, bound and fixed to other shoes
I don't see any relevance in your posting to the question except only two clipless pedals and regular shoes are employed as noun as many others. do you have dyslexia?
If I need clipless then I want a good cycling shoe and if I want to just wear regular shoes than I want a good platform pedal with adjustable or at least replaceable pins. I don't need or want to adapt regular shoes for clipless or clipped pedals. It is just not a good idea.
If you are saying "I am not that athletic" then why bother with clipless pedals in the first place? Having some clunky weird strap on on your feet isn't going to be a good clipless solution. Go ask a professional bike fitter if they recommend some jenky cleat mount for a sneaker. You want that cleat in the right place, it has nothing at all to do with "athleticism" it is all about putting your foot in the right spot for your pedaling and being more efficient and also comfort. Having something that slides around and moves a bunch isn't good for you in that situation and could be dangerous while clipped in.
If I need a bike to do both clipless and platform I would just get the Shimano PD-T8000 or Crank Brothers Double Shot or Mallet DH (if I was using their cleats). Otherwise I would go with a Crank Brothers Stamp (in large for my feet) or Issi Stomp XL or Spank Pedals or one of the many other options in a large platform with replaceable pins (just avoid fakes and knock offs)
Maybe I wrote in too complicated way for many people in the forums.
if I carry cycling shoes additionally, that'd be bulky. not every occassion I ride my bike for is not for cycling shoes.
toe strap provided too little attachments.
I'm asking if there is stuffs like cleat adapters for non-clipless shoes to clipless. I expect some loss of power more than cleat shoes, but still more effective than flat pedals in the matter of attachment.
this one looks the closest thing to what I want so far. thank you very much.
I found the opposite
https://www.modernbike.com/kool-kovers
there is the one I saw the other day https://www.amazon.com/Fly-Pedals/b/...bin=Fly+Pedals
LMK how well they work and I might buy a set too.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
Guest
Liked 3,270 Times
- You can't make non-clipless shoes into clipless shoes.
- You can buy a shoe with a recessed cleat that would work with both platform and clipless pedals.
- You can make clipless pedals into platform pedals, by using the clip-in platforms I showed you.
- If you put a platform on one side of a clipless pedal, it will roll over when you take your foot off of it.
- You can either learn how to flip the pedal back over, or you can mount a platform on both sides so it doesn't roll over.
- It's "better" than flat pedals (in your case) because you can remove the platform(s) when you want to be clipless.
Likes For Rolla:
actually, there has been. someone in another comment has offered a slight hint to a reliable source,
and my question didn't ask for your pointless thoughts. I've been already familiar with most of what you mentioned.
you look like you delude yourself as you know, but it seems like that only proved yourself as a type of meaningless bigot.
in my country, there's common saying that 'if one just stay still or quiet, at least the one might do a medicore.' .
I'll try to be clearer:
- You can buy a shoe with a recessed cleat that would work with both platform or clipless pedals.
- So you can either learn how to flip the pedal back over, or you could mount a platform on both sides so it doesn't roll over.
Quoted: 18399 Post(s)
Liked 4,525 Times
Winwood Instep made toe clips for clipless adapters. Both "Look" and "SPD" styles. They've been out of production for quite some time now, but they do periodically show up on E-Bay.
https://www.ebay.com/sch/i.html?_fro...winwood+instep
It looks like all I'm seeing are "Look" style at the moment, but the SPD style do exist.
There is also the winwood decksters which is a platform attachment, and perhaps more recent production.
https://www.ebay.com/sch/i.html?_fro...wood+decksters
I tried to use the Winwood Instep using clipless shoes, just for fun, and they didn't work well, but that may have been because the shoes are so thick. "Normal" shoes might have been better.. I've converted almost exclusively to SPD shoes, and haven't found them to be needed.
Likes For CliffordK:
thank you so much! this is the kind of what I'm looking for !
Quoted: 3450 Post(s)
Liked 420 Times
Forgive me but the OP seems to be searching for a solution to a problem that was solved 60-70 years ago. (or more)
I've personally ridden with most options. Toe clips PLUS straps ( we really should have spelled out that toe clips are supposed to work with straps) are really very good at retaining your feet and only marginally less secure than cleats, toe clips and straps or modern clips systems and I have certainly sprinted with toeclips, straps and street shoes.
Straps without toeclips is a serious step backwards.
I'm not sure what the OP was asking but this type popped in my head.
Back in the late '80s and early '90s Joel Thompson or Matt Brick couldn't beat duathlon king Kenny Souza. Duathlon are a run bike run event. Generally it was a 5k run followed by a 30k bike then another 5k run. Btw (they would run a sub 15 min 5k then ride at average about 28 mph then click off a 15 min 5k) Although he was as fast a runner, he was a tiny bit slower on the bike and could never close that less than a minute gap. So he tried a variation of these allowing him to use his racing running shoes on the bike segment and having a faster transition from bike to run.
Likes For texaspandj:
Guest
Liked 3,270 Times
I can't imagine why you're attacking me for trying to help you, but I'll assume your rudeness is due to a language barrier. Good luck with your shoe problem.
Clark W. Griswold
Quoted: 4413 Post(s)
Liked 4,056 Times
As I said go ask a professional bike fitter about your ideas and see what they say.
I didn't ask about common pedal attachment neither other's irrelevant personal preferances like yours.
what I asked is already mentioned in the original question.
still your comments have presented a kind of the least relevances.
if I disclose my intention necessarily more,
though self-obsessed bigotries could be rarely helpful,
but in this question I don't particularly expect ever more from such.
No dyslexia here...sorry bud. I said what I said to help you figure out what you needed. Please feel free to ask questions on what I said because it seems like we might have a language barrier and that is why you assume I have dyslexia. Or it is possible you don't understand clipless and clipped pedals.
Clark W. Griswold
Liked 4,056 Times
If you want to throw a cleat on your shoe go for it. Take some hot glue and just put it anywhere on the shoe and just ride like that. It is a bad idea but it is exactly what you want.
There is a reason clipless pedals and shoes exist, there is a reason good flat pedals with pins exist and we did clipped pedals before all of that and for some on the track in more modern times (though typically with a clipless pedal as part of it just for double holding power for Quadzillas, paging Robert Forstermann). There is a reason they call running shoes, running shoes and hiking boots, hiking boots. They serve particular purposes though yes you can ride in running shoes they just aren't going to be practical and efficient but if you are not "athletic" as you said that doesn't really matter to you and if it did you would get the proper set up or do as I said by getting the "flip flop" pedals like the Shimano PD-T8000s or Crank Bros DoubleShot. It seems silly to do something else but what do I know after many years in bike shops and studying gear and other topics related to cycling and having pedals as described and having used a lot of different pedals.
ugh, you reminds me of blinded christian missionaries what nobody except themselves care.
if I continue to reply, it'll have to be a thesis which I don't find that much need.
so I'll hope your best for something really beneficial for your life and value and for others as well.
and I'll just roughly say that you're a validly existent individual life form, but other each individuals are so too.
I gave you useful information and tried to take apart what you said and think about it more logically and try to help you. If you don't want the help, then I suggest maybe a bike forum is not for you. I work in the industry, I know bikes, I know pedals, I know a little bit about fit and riding and tried to pass that info on to you. Bikes are how I make my living and one of my biggest passions in life.
Liked 420 Times
This may be worth mentioning. When using toe clips and straps, the straps need to be pretty tight for high performance purposes. Uncomfortably tight to keep your feet in place and yes I've had my feet go numb on long rides in the past.
actually I don't use translation program.
I was saying his personal life, working in the bike business, passion, bike industry, blah blah blah doesn't matter to the question.
he's like preaching his industrial conventional thoughts to a person who already declined it.
there can be a man who served their entire life as a missionary, they can have their ideas about life of human. but do I buy that or even ever asked?
Dirty Heathen
Quoted: 889 Post(s)
Liked 927 Times
What you asked about is a solution to a problem you’ve brought on yourself.
You can either use clipless pedals with compatible shoes, flats (or toe clips) with ‘regular’ shoes, or a hybrid/touring pedal that’s got a platform on one side and an SPD on the other, so you can use either, depending on what shoes you’re wearing.
One solution requires swapping the pedals between rides, which isn’t a big deal, if you do a little prep work; The other way just requires flipping the pedal to the appropriate side for the shoes you’ve got on.
The way you’ve chosen requires you to adapt your shoes to the pedals, rather than using pedals and shoes that work together.
I wish you good luck in your search for “The Part That Does”
ooh, another dyslexic bigotry-obsessed preacher.
I’ve gotten the info even without your worthless good luck:
abd I‘ve used 3 set of cleat shoes meanwhile the question doesn’t ask what these dogmatists babble.
these kind of zombies delude themselves they’re ‘helping.’ even before they learn how to distinguish what to read before reply anything.
Dirty Heathen
Quoted: 889 Post(s)
Liked 927 Times
I’m not a bigot or a zealot, especially as far as bicycles are concerned; and personally, I’m a lot of things but definitely not dyslexic; Better get right with your DSM-5 before you start throwing diagnoses around, Tough Guy.
