The 41 refugee thread
#1501
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times
What do you think the rake is on this fork:
[IMG]<a href="https://www.flickr.com/photos/34107262@N03/6828209238" title="IMG_0150 by crzybastard2, on Flickr"><img src="https://farm8.staticflickr.com/7203/6828209238_b1e0166344_s.jpg" width="75" height="75" alt="IMG_0150"></a>[/IMG]
"Your beauty is an aeroplane;
#1502
Quoted: 1851 Post(s)
Liked 679 Times
I went to replace my cables and housing this weekend, when I noticed my rear derailleur cable was rubbing on my frame. The cable exits the guide and cuts across the frame before going to the RD.
I never noticed it before, but it I guess it's been doing that since I bought it in late 2012. The cable has worn a nice groove into the frame. I've talked with my LBS and sent this photo, among others, for a possible warranty claim. The LBS said they've not seen this happen on any other bikes.
#1503
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
I give up, what ?
#1504
Not actually Tmonk
Liked 3,153 Times
Flickr is being pretty weird. I'm having trouble copying the appropriate image URL into the insert image window here on BF. I'll d!ck around with it a little more today in order to get a proper image.
Bike is a 90's centurion "Dave Scott" ironman road bike. Steel lugged, steel fork. It is my primary training bike, equipped with shimano 6600 and dura ace DT shifters. I would like to convert the front end to 1" threadless, and don't know what rake(s) to consider for the new fork I will purchase. Additionally, I would like to tighten up the handling a little bit, if that can be achieved by a fork with different rake.
#1505
Super Moderator
Liked 929 Times
I was able to get to the link and see it. Rake looks fairly small already.
You can measure it if you take it off the bike and lay it on the countertop.
#1506
Not actually Tmonk
Liked 3,153 Times
It feels like a boat compared to my CAAD9
#1508
Not actually Tmonk
Liked 3,153 Times
Hah, small world. I remember you mentioning your Centurion before.
I rode and raced my first 1.5 seasons exclusively on the Centurion, during college. Those were good times.
#1509
Super Moderator
Liked 929 Times
You can slide the rear wheel 3/4" forward. Probably won't make any difference. I guess it's not really criterium geometry, maybe shallower head tube angle.
#1511
Fly on the wall
Bikes: a few
Anyone have any favorite 3rd party seat posts? The tarmac (SL4) post seat clamp thingy has been screwing with my short seams and comfort. I've been thinking about a zipp post. Any opinions on other posts? I do run a lot of set back so I was looking for at least 20mm (that puts Thompson out of the question).
#1512
¯\_(ツ)_/¯
Bikes: aggressive agreement is what I ride.
Quoted: 967 Post(s)
thomson seatposts ftw.
you said they are out of the question, but you should reconsider and just move your saddle forward and drop you bars more
#1513
Quoted: 417 Post(s)
#1515
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
I swapped out the Specialized seatpost I was using on my CAAD9 for an Easton x70 aluminum one. Easy to adjust, doesn't move once you set it, 20mm setback, cheap.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1516
Liked 679 Times
Of all the posts I've used, I like the Specialized post with the sideways bolt best. But I hear that isn't good for carbon rails, which I don't have.
I like it simply because it is the easiest to adjust.
Selle Italia Monolink is pretty good too.
From an adjustment standpoint, Thomson is OK. FSA is less OK. Argon 18 posts are the absolute worst. I'm not sure why they designed a four-bolt post (two for fore-aft and two for tilt) but it is a nightmare to adjust.
#1517
Quoted: 2952 Post(s)
Liked 3,106 Times
Can you recommend a minimalist saddle bag? Just big enough for a tube, levers, patches, and tube of glue. And without a Velcro strap on the seat post.
#1518
Quoted: 4236 Post(s)
Liked 2,949 Times
I keep thinking I'd like to give one of these a try at some point. Not sure about lightweight, but they do seem a bit minimalist.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
#1519
OMC
Quoted: 461 Post(s)
Liked 116 Times
I've been using one of these for the past three years. I'm really happy with it.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1520
Bikes: Yes
Quoted: 9 Post(s)
In the Pain Cave
Ok, q factor question. Looking at used srm cranksets. Some rotor 3D+, some shimano some cannondale etc. I have the tarmac SL4 pro. I have found a workaround for the majority of SRMs to fit OSBB but I would like ideal setup aside from forking over for the optimal specialized spider due to $$.
with rotor 3D+ it looks like I will need a fair amount of spacers. with regards to q factor will this be less than ideal and is a larger qfactor number even a big deal aside from ground clearance? ie more efficient?
Same general question for other cranksets but I tend to beat around the bush if I continue to babble.
#1522
Bikes: Yes
Quoted: 9 Post(s)
I would avoid spacers and adapters if possible. They work, but they are a compromise. I went from a GXP with BB30 adapters to straight BB30. The Q was the same but the crank is noticably stiffer.
#1523
OMC
Quoted: 461 Post(s)
Liked 116 Times
Here is a possibility. It's marketed as a conversion rather than an adapter. I've got no idea how well it works, just putting it out there.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#1524
In the Pain Cave
Thanks guys! Time to call praxis and see what it's all about. Makes sense to avoid adapters if possible
