For the love of English 3 speeds...
#9576
Quoted: 3811 Post(s)
Liked 6,711 Times
Stuck cotters are such a shame. It needn't happen. 3 minutes with a file and a bench vice is all that's needed to properly fit a cotter pin. From the looks of this, how uneven the surface of the pin is, you'll never be able to drill a straight hole through it and the crank and shaft might be ruined. Might be worth cutting off a bit of a bolt and try pressing it through. Or you could clean up the surface with a round dremel grinder and center punching a clean center for drilling.
#9577
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
My friend George, from Parts Unknown on Fraser Street, here in Toronto has one of these vintage presses that REALLY works.
#9579
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 599 Times
I drilled one bad one by starting with smaller drills (less than 1/4 ") until it reached the edge of the crank, let it soak and it pushed out in one piece. Get as much metal out as you can and don't give up!
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
#9580
Quoted: 887 Post(s)
Liked 335 Times
I cannot claim to be one of the 3 speed lovers but I've now put a toe in your pond. I have a strange Raleigh Sports that belongs to a friend. I'm doing some overhaul work on it during this wicked cold and, today, completed my first 3 speed IGH overhaul. I'm pretty impressed with you folks who really know these Rube-Goldbergs. I confess I still don't really know how it works but it came all apart and back together and works fine. I've learned a lot.
When I got it, the indicator spindle was broken off down in the axle - only two links of chain were attached and nothing was left outside, nothing to get a grip on. So I had to disassemble the whole shebang so I could slide the rod up, get a hold on the end and unscrew it from that pin that goes thru the axle. Of course, I then had to clean and repack all the bearings and clean and oil the rest. I got it all back together yesterday and it did not work - the cog would not turn the wheel. I took it all apart again today (while tending the wood stove) and studied the insides. I cannot describe what I found as I don't know all the part names but I found two reasons why it may have been binding and resolved them. Back together and it all works fine now. I'll visit a friend later this week who probably has a new indicator spindle. Otherwise I'll order on line. Its been fun and a real learning experience.
No photos but you all know what a 1973 SA SC3 looks like, probably have the guts memorized. I'm just a IGH noob here.
BTW: strange Raleigh Sports as it's a pretty small frame, 26 inch tires, coaster brake and no hand brakes, 1971 frame and 1973 rear hub. It looks just like a Canadian Gents Model 99 from 1954 - curved top tube and all but the S/N matches The Head Badge's 1971 pattern. I assume it was a European model brought over some time since '71. Nice bike but too small for me.
#9581
Bikes: 1972 Motobecane Le Champion, 1976 Motobecane Grand Record
Quoted: 24 Post(s)
What wheel size came on a 1956 Raleigh Sports with a dyno front wheel? Was it EA1 or 650A?
#9582
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 175 Times
#9584
Liked 443 Times
#9585
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 265 Times
Yeah, I realize speed is about the rider, but that's not what I'm talking about. I guess I can say that it's not fun to ride. It's very bland....like vanilla ice cream.
I guess it's the geometry and the heavy wheels. I think I'm coming to realizations about the kind of ride I enjoy best.
I love the Tektro 559 brakes. Yes, they spoil the vintage look to the bike, but one of the Mai things I don't like about riding vintage three speeds is poor braking and fear of the dreaded shift cable maladjustment where you get between 2nd & 3rd and you're just spinning. It's happened to me despite knowing how to adjust, etc. and it's quite alarming.
If I decide to build new wheels I may get a new SA 3-speed hub so not have to worry about it.
Also, I'm a fan of the Michelins, which allow for 85 pounds in the tire. That made a big difference over the Kendas, although the ride is not as soft.
#9586
Cotterpin removers/installers.
Here's my tool for cotterpin removal.
Never failed for me.
Pretty obvious how it works.
It is actually a Ball Joint Splitter. Available from MachineMart, etc. for £7/8 a few years ago.
Slight modification on the contact point, I just drilled a slight indent to locate the pin under pressure.
It's tough enough to whack it with a hammer once it is under pressure.
#9587
#9588
Quoted: 263 Post(s)
Liked 9 Times
Harbor Freight has something similar
3/4" Forged Ball Joint Separator
#9589
That's the style. And affordable. I always thought MachineMart was an American outfit!? I live & learn still....
@3speedslow
I do have a few cool tools also, but I sold most of my kit when I moved into my small retirement apartment.... No workshop....
BB taps, head set presses, you name it. I regret it now: (
Still got some cool bikes though; )
#9590
Count Orlok Member
Ahhhh... yes, that makes sense. Well, I will probably run out of project$ before we run out of winter - so I guess I can pull those wheels and washer them up. The spokes did seem a bit long on that `63 Dunelt. I recall I had to grind some of them down to the nipple tops so they wouldn't protrude from the double-wall rim. I will probably have to rebuild that one with new spokes, now that I've buggered up the threads.
Well, thanks. I know it's the right thing to do. It's just kind of a faff, as they say in old Blighty.
He recommends washers. I suppose the spokes could break at the bends without them.
Several people I know have built wheels without them, though, so rebuild them if you must but YMMV.
#9591
Count Orlok Member
You have a camel back frame with the infamous coaster brake hub. I have one frame hanging in the rafters with most of its original parts, and a ladies bike all built up and working. I also have a rear wheel with an SC3 that defies all attempts to work well. That is on my back burner now. Sounds like you learned a lot though. Welcome.
#9592
Bicycle Repair Man !!!
Probably read Mark Stonich's SA tips: https://bikesmithdesign.com/SA/sa-tips.pdf
I have worked on quite a few vintage SA wheels that also had spoke washers which are softer than the steel and seat the elbow on the steel flange better.
#9593
I have a SA 3 speed in a steel wheel that I liberated from a ladies Schwinn.
And a loose SA too.
How to check the functionality of it before lacing to a wheel ?
Thanks.
Srinath
And a loose SA too.
Thanks.
Srinath
#9594
Quoted: 472 Post(s)
Liked 1,028 Times
Thanks!! What year and country is that catalog page from? The bike I have here looks just like the DL-58. Same color, fenders, rack, bars, hockey stick. 18 inch ST and 26 in tires. This hockey stick says Sport vs Colt. Could easily have been changed along the way. I may be mistaken about the front brake. Just cuz it's not there now does not mean it never was. I don't see clear signs that a lever was clamped to the bar but I checked this afternoon and it does look like there was a caliper there on the fork at one time - paint scratched around both holes. The bike here is no jewel. Mostly working on it to learn a few things - waiting for spring.
#9595
Count Orlok Member
from www.bulgier.net - /pics/bike/Catalogs/Raleigh74/
#9596
Abuse Magnet
Quoted: 151 Post(s)
Liked 175 Times
I almost came home with a late-'50s Hercules frame from a shop in Moab, UT. Imagining my wife's ire at more bike stuff cluttering the living room stayed my hand.
#9597
Liked 6,711 Times
#9599
Quoted: 1299 Post(s)
Liked 103 Times
I'm good about passing up bikes in good condition. It's the messed up, un-ridable ones that get me every time. I just can't resist fixing nice old but neglected bikes. My wife can't really complain. Se has more "stuff" around than I do.
Inflate Hard
Inflate Hard
