Show us your vintage mountain bikes!
#8401
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 977 Times
Likes For georges1:
#8404
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,220 Times
But luckily we have top pull front derailers now. Sooooo much better!
Stuart Black
Stuart Black
#8405
Top Seeded Amateur
Likes For OldForerunner:
#8406
Quoted: 1872 Post(s)
Liked 692 Times
You're going to have the same issue I had with my Hard Rock. At some point the brake cable cuts a groove into those metal cable guides and get bound up. Then the calipers don't release. Super fun problem to solve.
2019 Salsa Warbird
2019 Salsa Warbird
#8407
I have something like that on my Rockhopper (likely the same as your HR). I stuck a short piece of housing liner in the fitting. Seems to be working well; the cable movement is noticeably smoother.
Likes For due ruote:
#8408
Liked 692 Times
Dang, liner didn't work for me. The groove was already too deep and the cable would still just pinch in the slot. I wound up dremeling out half of the cable stop and creating a new path for the cable.
2019 Salsa Warbird
2019 Salsa Warbird
#8409
Liked 4,220 Times
Stuart Black
Stuart Black
#8410
Top Seeded Amateur
Well, it darn sure ain't worse. Less weight, less complexity, one fewer cable and requisite housing(s), one less thing to adjust and maintain, less overlap in gearing, seamless changes through the gears, etc.
Of all the 'improvements' and changes in standards the bike industry creates at the expense of the consumer, the 1x drivetrain is one of the few I can get behind.
YMMV.
YMMV.
#8411
Bikes: Gunnar, Shogun, Concorde, F Moser, Pete Tansley, Rocky Mtn, Diamant, Krapf, Marin, Avanti, Winora, Emmelle, Ken Evans
Quoted: 275 Post(s)
Liked 417 Times
The angle that top pull derailer cables goes off at, away from the seat tube, always bothers me.
#8412
Quoted: 1400 Post(s)
Liked 1,883 Times
#8413
Liked 1,883 Times
and the shorter the seat tube - the more severe the angle will be
#8415
Agreed. I’ve had a few bikes with them and they’ve always worked well. How cool is a 3DV pulley down low on the seat tube where no one expects it?
#8416
Liked 1,883 Times
seems to work well - no issue on this similar PDG70
( equipped with this from the factory )
I will need to find this stuff ... not sure what the technical name is ... housing liner ... ? cable liner ? ...
Likes For Schweinhund:
#8418
Liked 4,220 Times
I don’t find the front derailer to be all that difficult to adjust nor maintain. Once set, there is very little need for adjustment. I’ll gladly trade a little weight and complexity so that I don’t have to coast.
YMMV.
Stuart Black
Stuart Black
#8419
Liked 4,220 Times
You usually can’t mix the two. A top pull front derailer has the cable guides running along the top tube while a bottom pull has cable guides running along the downtube. It’s difficult to change from one to the other.
Stuart Black
Stuart Black
#8420
Top Seeded Amateur
Less range is their major fault. Choose a good high gear or a good low gear…you can’t have both. A 10-52 cassette will give a 520% gear range. I have bikes with a 720% gear range which means I can ride with really low gears and still not spin out on the high end. I have one bike with an 800% gear range. That’s a 13” low and a 110” high. A 10-52 can have that low a gear but has a 72” high which means you coast over speeds of about 25 mph.
Yes indeed.
Yes indeed.
And while FD adjustment and maintenance may not be difficult for you, 0 is less than any.
#8421
Quoted: 253 Post(s)
Liked 223 Times
I have actually fumbled a side pull to work with a bottom pull setup on my Rockhopper. Will try'n provide some pictures from my adventurous cable routing and edit them in.
Likes For shoota:
#8423
Thank you. I've wasted too much of my life trying to explain this to the kid at the LBS who's never actually experienced a front derailleur. I like me some 3x9!
Likes For Smokinapankake:
#8424
Horses for courses and all that.
Likes For DesmoDog:
#8425
Liked 692 Times
While I am also a fan of ditching front derailluers and chain rings, one detail seemingly overlooked here is location. If I lived in Denver, Colorado a super low gear would be much more important to me than it is in Ann Arbor, Michigan. Ditto a higher gear... the elevation changes go both ways after all.
2019 Salsa Warbird
2019 Salsa Warbird
