Expanded Tern recall
#251
Holy crap. The Link is the lower cost series, and I presumed to be heavier, tougher frames. It was my impression that all the failures were Verge series; now it looks like the problem is in the design and company-wide.
Dr. Hon needs to tell his idiot family members to get out of the bicycle business. They're bad at it.
#252
Quoted: 24 Post(s)
Holy crap! Ok I didn't think one could get into that much trouble. I guess I seriously need to replace my bike / frame. Speedy recovery to you sir.
Would really love to see the photos. I'm still trying to understand what's the mechanism of the frame welding failure that could happen.
#254
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
Take a look at https://www.google.com/search?q=tern...w=1280&bih=893
Thanks,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
#255
Quoted: 24 Post(s)
Oh my gosh, so they fail at the welds!
So I guess I'll have to scrap Mark Bickerton's idea of replacing the frame of my Tern Link.
Interestingly enough I have just made a search for "Dahon Frame Failure" but all the images returned were of Tern bicycles?
#256
Quoted: 282 Post(s)
Liked 24 Times
Thanks,
Yan
#257
https://www.******.com/r/Brompton/co...rn_it_to_hell/
Saw this. Could be an old model. Also, the bike has an electric motor.
#258
55+ Club,...
Bikes: 9+,...
Quoted: 1117 Post(s)
Liked 850 Times
#259
What happened?
Quoted: 1835 Post(s)
Liked 292 Times
It's possibly dead because this thread is dated in 2016?
If you want to find a current recall, you should visit https://www.bikeforums.net/recall-announcements/ and if you cannot find it, try a search engine you like or ask the staff.
There is also https://www.cpsc.gov/recalls
#260
Picture from redd it dot com
It is dead because I think there is censorship bot in this forum. What you can do is click on the link and replace the asterics with "redd it" dot com.
The hinge failure is recent ( like maybe several days ago), but the bike could be old model plus modded with electric motor.
#261
The link should work if its embedded in text, for example CLICK HERE.
#262
Thanks for the link! Looks like Tern's learning curve on how to weld is not quite finished. At least they know how to produce slick websites and pr.
#263
55+ Club,...
Bikes: 9+,...
Liked 850 Times
"Warning: My Tern Cargo Node + BBSHD split in half while riding yesterday. Just under 2k miles and it broke in two while slowing down at an intersection. Could have been much worse! This is not a safe conversion."
#264
Cargo Node.
Oh ... somehow I missed the part that it was a different kind of bike. I thought it was just a normal bike with a rack.
#265
The redd it link I posted was not the original owner's link. I believe the one below is the original. Sorry about that.
https://www.******.com/r/ebikes/comm...split_in_half/
#268
55+ Club,...
Bikes: 9+,...
Liked 850 Times
Post a word, then use the "chain link" in the bar up top to add the site link,...posting a direct link to that site is apparently taboo! LOL!!! I believe it has to do with spam and such.
#269
I noticed that as well. The frame joint looks like the earlier version (with no gusset plate) that caused problems on earlier bikes though. Would be very interested to know where the frame was made (Vietnam, China, or Taiwan). The frames with the gusset plate are all Made in Vietnam.
#270
What is worth mentioning regarding that case:
- The bike in question was a Tern Cargo Node - a cargobike, basically consisting of a Tern Node Frame (thier 24" bike) with a factory fitted xtracycle rear frame cargo extension. I do not know if the frame of the cargo node is different or stiffened in compariston to an ordinary Tern Link frame though optically identical for the innocent watcher.
- The poster says he had no heavy load on the bike at the time of the accident - just himself (at 165 lbs) and a laptop
- he had fitted an electric motor to the bike. A Bafang BBSHD mid-drive motor at the bottom bracket. The BBSH is rated at 1000 Watts. Tern themselves do sell the cargo node with an electric mid-drive motor, but only one with 250 Watts.
Edit: There is no electric version of the Cargo Node on Terns webseite, so possibly they did not even sell an electric version at all. The claim was from memory.
The force of that retrofitted motor is clearly far higher than what Tern offer themselves, so basically he used the bike outside the specification.
The poster himself writes in said r-e-d-d-i-t (seems on is not even allowed to post the word ****** here ) thread:
- He posted more pictures of the break at imgur: https://imgur.com/a/DwozLzH
- As usual we do not know if the breakage developed over time or happened completely all of a sudeen, maybe starting secretly at the underside of the frame.
So while it is the same well-known area where the bike broke it seems maybe a bit questionable in this case to simply claim it was Tern who still are unable to weld. With the extra force of that extremely powerful motor the bike was used far out for what it was designed, specified, rated and tested. Luckily the rider did not suffer injuries. Maybe a sign of warning to people to put the most powerful motors on any given bike w/o knowing the limits or paying respect or attention to the forces that the frame will have to deal with. Just because things fit mechanically it does not mean it is a good idea or a valid combination.
The BBSHD puts out an incredible amount of torque. I could take off like a rocket from a stop, something most people couldn’t do. I’m sure that put a lot of stress on that joint.
#271
"“Ross Evans, the founder of Xtracycle, is a good friend,” said Hon (pictured below grabbing a slice of pizza at Eurobike). “We went to Stanford University together and have kept in touch.”
Almost literally because the Cargo Node originated from some close proximity thinking: “We were sat in a hot tub, and I said you make this really cool rear rack and we make these cool bikes, maybe the joining of the two could make something interesting?”
#272
What happened?
Liked 292 Times
I'll say it for the third time this month, that site URL is directly blocked because the place is just too potentially OTT and not safe for 16-20" riders and not pleasing to Donny and Marie even. If you can find a different source, try, a lot of their stuff originates elsewhere anyway.
#273
55+ Club,...
Bikes: 9+,...
Liked 850 Times
#274
Hello from Germany. Yesterday my Tern Vektron P9 broke down. Fortunately not during the drive but when starting at a traffic light. I bought it on november 15th last year. I am curious what my dealer will say on the phone afterwards. 2 minutes before I stood at the traffic light, the tachometer indicated still good 40km/h (it went downhill) not to imagine what could have happened. maybe I should start to pray ;-) unfortunately I can only post after 10 posts photos or left on pictures :-/ it looks exactly the same as with tds, exactly the same place.
#275
"broke down" can mean the problem is fixable, such as when you have minor car trouble on the highway and you call the local motor association for help. Or did you mean the bicycle frame broke in half?
