Ruler and Chain Checker are Diverging
Cantilever believer
Quoted: 536 Post(s)
Liked 1,841 Times
I'm in the "toss at 1/16" camp as well. Doing that on my own chains has resulted in chains lasting 2500-4000 miles, but other parts such as freewheels & chainrings lasting 7500 miles or more, as they don't get the accelerated wear from a too-worn chain.
I can end up checking dozens of used chains in a single shift at Rusty Spoke, all of them grubby (we don't have the time or resources to clean every chain that comes in). The 1/16" reject value is conservative, but minimizes problems with a chain wearing out other components or any reading error from chain gunk. I'll measure the wear in inches and the pin width in mm, and look for missing/reusable links or damage/twisting (it's surprising how many chains we get where the chain is opened with a tool even though a missing link is present). I'll then bag and label the chain for reuse with brand/model, pin width & optimum number of speeds (such as "7.1 mm - 7-8 speed"), wear ("none/slight/moderate") number of links, and whether it has a "missing/reusable" link or not.
A few weeks ago, I encountered a chain that had over 1/4" wear in 12". It was separated from its original bike, but I'd hate to see the rest of that drivetrain...
Quoted: 4236 Post(s)
Liked 2,949 Times
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
Exposing my innumeracy
How do those Rohloff numbers (mm?) match up to the Park Tool and Shimano .5% and .75% wear? And the 1/32" and 1/16" of ruler users? I've Googled conversions but I can't make any sense of it.
Liked 2,949 Times
True. As someone who pulls his chains off every 700-1000 km to give them a fresh dip in MSW (how many hot topics can we drag into this sucker ), I always have at least 2 chains off the bike hanging on a nail, so I tend to measure then.
The rollers are not a factor in measuring chain wear. The "stretch" comes between the pins and the inner plates that act as bushings. Nice drawing though.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Why are your chains wearing out so fast? I have a chain that has 6000 miles and it isn't at 1/16 inch yet. Granted I'm mostly a fair weather rider....at least by choice.
Cantilever believer
Quoted: 536 Post(s)
Liked 1,841 Times
None of this discussion includes the recumbent, whose current chain is from the early 1990s, has about 8000 miles on it, no measurable wear, and may outlive us all.
Quoted: 4410 Post(s)
Liked 1,566 Times
You think stretched chains are going to break or something?
Likes For Kontact:
Likes For Lombard:
Likes For davidad:
Liked 1,566 Times
The only thing that affects the cogs is the increase in pitch between the rollers. What makes you think chain wear somehow doesn't involve roller wear when rollers are what wear out the cogs? Rollers are part of the chain.
Quoted: 1109 Post(s)
Liked 1,200 Times
My normal routine is to use a chain gauge (coincidentally, the CC-3.2 @Kontact mentioned) to find out if it's time to break out the ruler. However . . .
Using a ruler isn't automatic. I'll go with a longer rule, such as a measuring tape or the Park SBC-1, so I can center the beginning (1" on the tape or the triangle on the Park) on a rivet. Measure to the center of the '12" rivet', then go back and make sure the beginning mark didn't shift. Repeat at least one more time to make sure you've got the right measure. Or you can measure to one end or the other of the rivet, if you're not sure you can eyeball the middle of a rivet accurately.
And then go measure another one or two 12" sections of chain, to see if the measurements match or are longer than you want the chain to be to stay on the bike. If there's significant divergence, go with the longer measurement IME, and replace the chain.
IIRC the Pedros tool is supposed to take roller slop out of the measurement, FWIW.
My guess is that your "ruler" moved while you looked from one end to the other. That's one free opinion that's worth everything you paid for it!
You, I and probably a significant portion of bikeforums denizens know this (but not all of us knurds). The typical bike user, even racer and enthusiast, doesn't know and probably doesn't care about mechanical stuff or know this stuff. So chain checkers serve a really good purpose for almost anyone who wants to know the status of the chain.
If I've cleaned a chain (mineral spirits bath) I hang it from a little nail on the edge of a shelf in my garage to dry and go ahead and measure with a ruler. If it's on the bike, every once in a while I use the Park CC4 or Pedros Chain Checker Plus II (I have one at home and the other in my travel bag.) I'm not much of a scientist so can't really tell you how the two methods compare. But if one or the other makes me think I need a new chain, I get one.
Likes For Camilo:
Liked 1,566 Times
What gets me with this discussion is the same thing that I find so vexing about saddle sizing:
The current marketing is that you should select your saddle's outer width based on the width of two spots you don't sit on, and then apply that to the width of a portion of the saddle you also don't sit on.
And chain wear is important because of the affect a worn out chain has on cog pitch. What interacts with the cogs and also has pitch? The rollers. What should we measure? Something other than the rollers.
Imagine going to get some new shoes. The salesperson sits you down and takes incredibly precise measurements of your ankles (not your feet), then recommends a 43 Wide. Reasonable?
Mad bike riding scientist
Quoted: 6220 Post(s)
Liked 4,221 Times
Your points about saddles and shoes aside, you can see why we measure the pin wear from your illustration. The pin wear allows the roller to move rearward under pressure so that it no longer fits the pitch. This allows the roller to erode the edges of the cog resulting in elongation of the cog pitch. If you allow the pin to wear too much, the roller erodes more of the cog resulting in the classic shark fin in extreme cases. The cogs, being smaller in diameter, wear faster than the larger but softer chainwheels. Small inner chainrings can wear pretty fast which is why they are usually steel rather than aluminum.
Stuart Black
Stuart Black
Likes For cyccommute:
Sock Puppet
Liked 863 Times
FWIW, My last chain on this current drivetrain lasted 6000 miles. The only reason I replaced it was because it had a stiff link I couldn't work out. My current chain now has 6000 miles and has about 1/32" of "stretch". So that is 12,000 miles on my cassette and crankset. I will probably replace my current chain at 8-10K miles. Will my next chain skip on my current cassette? I don't know. But I would say 14-16K miles out of a cassette isn't worth crying over.
Likes For Lombard:
Quoted: 6972 Post(s)
Liked 10,970 Times
When in doubt, throw it out.
Liked 1,566 Times
Likes For Kontact:
Liked 1,566 Times
Knurds?
Huh?
As analogies go, this is probably one of the worst I've seen.
Huh?
Liked 4,221 Times
The illustration shows that roller wear is just as important as pin wear, so I don't follow what you're saying. Trying to measure just pin wear in absence of the other types of wear that affect chain pitch doesn't make any sense, unless you can guarantee that pin and roller wear are always in a fixed proportion to each other.
The question I have for you is how do your propose to measure roller wear if that is what you think is causing the problem? I can think of no way to measure roller wear separately from pin wear. It is possible, and even quite common, to measure secondary effects to measure a primary phenomena. In chemistry, for example, we often react two chemicals together and then further react the products of that reaction to see what the concentration of the unknown of the first two chemicals are. Pin wear and roller wear are related. Measuring pin wear also measures the effect of the rollers on the cogs.
Frankly, if you are worried about cog wear, you should probably be using one of these. I have one but find them to be mostly useless.
Stuart Black
Stuart Black
Quoted: 1104 Post(s)
Liked 1,825 Times
The roller isn’t wearing. The pin wears and allows the roller to follow something of an elliptical path as it goes over the cog and chainwheel. New chains follow a circular path so they engage the pitch of the cog and chainwheel properly so they don’t wear the edges of the teeth like a chain where the rollers can shift.
Just kiddin ya
Likes For nomadmax:
