How much air goes from the tire to the pump when you plug it on the valve?
#76
Advocatus Diaboli
Quoted: 4739 Post(s)
Liked 1,533 Times
True, until you make your first pump that does release the valve, so that you can have a pressure reading in the first place.
Likes For Sy Reene:
#77
One solution for presta valves is to loosen the top nut, tap the nut to break the seal, then screw on a Schrader adapter and use a Schrader pump head. No air will be lost. Apparently, some mini-pumps also have this problem, where air is lost while removing the head.
#78
Quoted: 3957 Post(s)
Liked 7,309 Times
Likes For tomato coupe:
#79
Liked 7,309 Times
#80
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
Ever try to open the fridge door super quick to see if the light really goes off when you close it?
#81
Should Be More Popular
Quoted: 22606 Post(s)
Liked 8,929 Times
#83
Liked 7,309 Times
#84
Liked 8,929 Times
#85
Quoted: 8287 Post(s)
Liked 9,064 Times
Lose air into the pump? Why would that matter? Aren't you going to pump it up anyway? And it can't be because you need an accurate pre-pump reading if the valve doesn't open.
#86
Liked 9,064 Times
Solution to what? Why would anyone go through all that? Just put the chuck on and inflate the stupid tire. Take the chuck off quickly and go ride. No problem.
Likes For big john:
#87
Liked 9,064 Times
#90
Liked 9,064 Times
Likes For prj71:
#93
Quoted: 252 Post(s)
Liked 67 Times
Also, pump is not an air pressure checking device. When I take my pump from its place, you can be damn sure the tire needs some air added to it and the gauge is used as an indicator when to stop adding. I repeat, it is not to be used just to check, when you don't intend to pump air. For that, use those small gauges made for the purpose, ie. not part of a pump.
It seems people consider air pump such a simple device that it is beneath them to devote some thinking as to how it operates, or in the case of some chinese knock off pumps, how they should be operated correctly.
#94
Bikes: 2020 Trek Emonda SL6, 90's Vintage EL-OS Steel Bianchi with 2014 Campy Chorus Upgrade
Quoted: 452 Post(s)
Liked 162 Times
I recently sheared the stem off the tube in my front tire while removing the pump. So in that case the answer was around 75 pounds. dave
Likes For DaveLeeNC:
#96
Liked 8,929 Times
