Immersive waxing / it should be more popular
#226
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#228
Quoted: 8286 Post(s)
Liked 9,055 Times
Then there's brake clean, acetone. I worked next to a guy who washed everything off with brake clean or carb cleaner. Brain damage.
#229
Liked 9,456 Times
Let me spell it out - I'd rather spend more time riding and less time maintaining my bike and, for me, over the course of tens of thousands of miles, waxing has proven to be the best solution to that end. Do you think that's an example of not valuing my time?
#230
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
#231
Liked 9,456 Times
#232
Quoted: 2976 Post(s)
Liked 1,182 Times
In almost 50 years of working on cars I have consumed more than my share of petro chemicals. Huffing gasoline sucks, gives me headaches, and I read that the volatiles in it are absorbed through the skin.
I think I will be OK though lubing my chain once a week with an aerosol based lubricant.
#234
Advanced Slacker
Liked 2,537 Times
#235
Liked 9,456 Times
I don't want or need a spotlessly clean chain - I want a non-grimy chain.
#236
Liked 9,456 Times
#237
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
10 pages about chain lube.
#238
Liked 9,456 Times
#239
Quoted: 3241 Post(s)
Liked 2,512 Times
Likes For jasoninohio:
#241
Advanced Slacker
Liked 2,537 Times
If you had just bothered to read the whole post before responding to it you wouldn’t have to go through all this work to pretend that you didn’t miss something that you obviously did.
#242
Liked 9,456 Times
People don't need to be anal-retentive for waxing to make sense as a time (and hassle) saver. Frankly, the most fastidiously clean drivetrains that I've seen have certainly not belonged to people that wax. Go figure.
#244
Liked 2,512 Times
Let's talk about the lubing methods a little deeper. We could compare it to the options cyclists have when they want to remove body hair. They have the longer lasting products/processes such as Nair, Nads or Lazer removal. Like chain waxing, those products might do a better job and require a lot less overall time/maintenance. Then we have ordinary shaving which is similar to ordinary chain lubing. Definitely requires more maintenance than the other methods and doesn't last as long. You'd think shaving would be the least popular method, but that's not the case. I wonder why?
I mentioned hair removal in this post, but haven't got a response yet.
#245
Quoted: 3956 Post(s)
Liked 7,304 Times
Likes For base2:
#247
Quoted: 4806 Post(s)
Liked 3,932 Times
I've been thinking the same ting since this thread started. Total immersion - face, legs and anywhere else I care about stays shave free for how long? Could be a real time saver. And if you are going to fill the tub with wax, you might as well bring your chain. (Sounds kinky but we do this to keep our chains kink-free, right?)
#248
Liked 9,456 Times
Frankly, I don't know what the upper bounds of cleanliness with waxing looks like, and I'm not interested in finding out. I don't bother with wiping down my chain immediately after waxing, or anything like that, and the wax that I use is black/gray, so the plates certainly aren't sparkling. Does the chain run smooth? Yes. Can a grab the chain barehanded without getting grubby hands? Yes. Is there any buildup of road grime? No. Does my drivetrain look like I just pulled it out of an ultrasonic bath? No. IOW, it's functionally clean with minimal work, but it's not showroom sparkly.
I can think of a few guys IRL and on the forum that keep immaculate wet lube drivetrains (I like being on the wheel of one of the guys in my club - his cassette is so mesmerizingly shiny that it distracts from uncomfortable efforts). I shudder to think about the amount of work that I'd have to go through for that - I suspect that that's a different kind of obsessiveness than what would make waxing appealing. Maybe some people that wax are obsessed with cosmetic cleanliness, but I can't say that I can recall any; most seem to be interested in it for functional/practical reasons.
#249
Liked 7,304 Times
You can define it however you like. But, your statement was "the most fastidiously clean drivetrains that I've seen have certainly not belonged to people that wax." So, if the cleanest drivetrains were non-waxed, doesn't that nullify the most commonly cited advantage of waxing?
#250
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
