Immersive waxing / it should be more popular
#427
Quoted: 3241 Post(s)
Liked 2,512 Times
The longer the thread goes, the less likely I'll ever try waxing. I think the OP got his answer as to why it's not more popular.
Likes For seypat:
#428
And yes I do consider the question thoroughly answered!
Likes For yaw:
#430
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
That said, I am wax-curious and may even try it sometime in the future. But I am also quite lazy so it may never happen.
#431
Bikes: SL8 Pro, TCR beater
Quoted: 989 Post(s)
Liked 586 Times
Both are clearly for cyclists that likes to spend time in their garage and do mechanics. There are others who simply want to ride and not rack their brains with this kind of stuff.
#432
Liked 2,512 Times
https://www.wd40.com/products/roller-chain-lubricant/
#433
Quoted: 3953 Post(s)
Liked 7,300 Times
Likes For tomato coupe:
#434
ignominious poltroon
Quoted: 2241 Post(s)
Liked 3,443 Times
Likes For Polaris OBark:
#435
Liked 8,927 Times
Likes For datlas:
#436
carbon is too light
Bikes: Yes.
Quoted: 103 Post(s)
Liked 250 Times
Ehh, you literally degrease the chain, rinse, dry, drop your chain in the hot wax and swish it around, then pull it out and let it hang dry. It's not a technical job at all. I suspect I overheated my wax at some point, in fact I seem to remember finding that crockpot still on 3 months later after the last time I used it. Whoops. I didn't realize it would overheat. It used to come out solid white / opaque and much less visible wax on the chain. That said, I rode a couple of hours today on it and wiped off the excess wax, and it seems to be ok. I'll just strip it after this weekend and get some fresh wax on it.
#437
Quoted: 1163 Post(s)
Liked 442 Times
I left my crock pot on high for two days one time accidentally with clear gulf canning wax in there and it turned brown like that. It sounds like this weekend will be a good time to start fresh.
terrymorse thwnks for adding the chart and introducing the concept of “Jump Point”. Those of us who wax surely know the feel and the noise of a wax job that has ceased to be protecting the chain, I know I do.
…also, Polaris OBark - I’m astounded that you claim 3x the life out of a chain (compared with wet lube?). My experience so far is that chain life is about the same. My Wippermann and Campagnolo chains seem to stretch the slowest, the KMC and SRAM chains stretch the fastest. I’m not a big ring power rider yet I can wear out a KMC chain in 1,500 miles.
#438
Liked 2,512 Times
The thread keeps on giving.
#439
Quoted: 338 Post(s)
Liked 408 Times
The various chain waxes add in, essentially, PTFE and other additives and it reduces wear and losses compared to straight up paraffin wax.
#440
Quoted: 2333 Post(s)
Liked 2,097 Times
You anti-waxxers don't know what you are talking about. In the last 1200 miles, I have been lazy after putting a newly waxed chain on. I have applies liquid wax (Silca or Squirt) three times. Then, I removed the chain, turned the crockpot on, threw the chain in for an hour, removed and installed. I cannot imagine an easier (effective) chain regime, If you think wiping a chain down with a cloth helps, there is no helping you.
#441
Liked 3,443 Times
I believe you, but it matters what you're comparing it with - many lubes are really dire in tests, and more or less the only drip on lubes which give good results are wax emulsion based, the rest test more or less horribly.
I think the fundamental flaw with the analysis is that it measures how much wear you get from pure lubricants. What is relevant, at least in my experience, is how much wear occurs when the lubricant is exposed to sand and grit. If it is adhesive, it makes a grinding paste. If it is wax (pure, or with additives), the grit doesn't stick nearly as much.
#442
Liked 3,443 Times
I think on a pristine paved road, the difference between wet lube and wax is probably minimal. (I have a Campy chain and drivetrain I use wet lube on, mainly because the Campy guy at Sea Otter told me never to use a quick link with their stuff, and waxing just isn't worth the trouble, since this bike only sees paved roads).
On my all-road/gravel bike, the chain will get covered with very abrasive dust/grit after a single ride. If I use a wet lube, it all sticks, and grinds everything down very quickly. With wax, I find things last at least 3 times longer. Perhaps a more accurate way of looking at this would be to say that the wax preserves the expected drive train life, even under very abrasive dust/grit conditions, whereas wet lube under these conditions shortens the expected life by about 3X.
#443
Liked 2,097 Times
I've gotten 10,000 miles out of waxed 11 speed shimano dura ace chain but typically I toss then at 4-5,000 miles. Not enough 12 speed data on KMC, Campy, and YNB. I did not like the Campy and took it off the bike. YNB off after 4,500 miles with no measurable wear hanging the entire length under tension. The KMC shifts better and will stick with them.
Likes For GhostRider62:
#444
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
Hi everyone, how's the thread going?
Oh, I see. Maybe the reason that waxing is not more popular is not because of waxing itself. Could be wrong...
#445
Liked 8,927 Times
Likes For datlas:
#446
Liked 7,300 Times
#448
Liked 2,097 Times
