For the love of English 3 speeds...
#951
Bicycle Repairman
How about a chrome Raleigh "Boss Bike"?
It's only a single speed but it is English and appears to be a DL-1 variant. It has rod brakes, rear carrier, full chaincase, Dunlop 26 x 2.0 balloon tires (tyres), a B-33 saddle, heavy rear dropstand, and it's ALL chrome.
I've posted this on some forums before and nobody has been able to positively ID what model this is. I'm guessing it's early to mid-60's vintage. It has two serial numbers (one on the seat lug and one on the side of seat tube.) and neither appear on any of the charts. No date codes on the hubs either. This may have been for the South African market although it has a Nottingham headbadge.
it gets a lot of attention at car shows too.
#952
Quoted: 7359 Post(s)
Liked 2,496 Times
Wow, Kingsting. I think you should get a different bike tray, the kind that lets you mount the bike upside down. Then the setup will look like you can flip it and carry the car on the bike.
#954
perpetually frazzled
Bikes: 1977 Bridgestone Kabuki Super Speed; 1979 Raleigh Professional; 1983 Raleigh Rapide mixte; 1974 Peugeot UO-8; 1993 Univega Activa Trail; 1972 Raleigh Sports; 1967 Phillips; 1981 Schwinn World Tourist; 1976 Schwinn LeTour mixte; 1964 Western Flyer
Quoted: 5 Post(s)
Liked 6 Times
So, kingsting, which is heavier?
#956
Liked 8 Times
Kingsting,
in one of life's random twists, you have just blown me out of the water.
i have recently returned to NZ after a year in UK. I have 2 choice Raleighs following me in a container (1955 Sports, and 1939 loop frame).
Just 24 hours ago I saw this for sale in my home town,
https://www.trademe.co.nz/a.aspx?id=317636872
and i thought it a bitser. With the separate seat stays I judged it an old 28" wheeler that someone had put later 26" Westwoods and fat tyres on.
Then, chrome aside, from the other side of Planet Raleigh I saw your post - the two appear to be the same model, but what that model is I know not .
Can anyone Shed the Light?
#957
Bicycle Repairman
Kingsting,
Anyway... Back to the bike you found. The frame and wheels definitely look to be the same as mine, however - it looks to be a lower end model with a hockeystick chainguard and mattress saddle. It also appears to be older judging from the black reflector housing.
After a so-called expert told me that this bike was something that someone made out of a DL-1, I measured my frame and compared it to my Dawn and DL-1. The dimensions are different so this is a model of it's own.
I found a few short articles that mention the balloon tire roadsters and that they were mostly for the South African market.
#958
Bikes: 1970Raleigh DL1
I cannot believe it has been a year and a half since I last signed in on the forum.
This is my pride and joy. 1970 Raleigh DL1 and 40 years old this year of which ten have been with me. It is my daily ride and now my only bicycle. I am soon to replace the original Brooks B72 saddle with a more plush Brooks B135.
Of all the modern and vintage bicycles I have owned through the years, this one has been the most reliable, easiest to maintain and easiest to fix.
#959
Liked 8 Times
Hey! A New Zealand guy on the forums! You probably recognized my Mini. It came from New Zealand originally and it still has the original dealer sticker in the rear window. I'll have to go look at it tonight and see what town it came from... I think the dealership was John King cars LTD...
https://www.trademe.co.nz/Sports/Cycl...-317335706.htm
..a bit like buses, 2 or 3 come at once.
Does anyone know what this model is?
#960
Bikes: 1973 Raleigh Superbe
What kinds of maintenance items would be atop your guys' lists if you were unsure of the maintenance record of the 3-speed Raleigh you just acquired. I was thinking of looking into the repacking the bottom bracket, flushing the SA hub and refilling w/ 10W30. What about the front hub? Repack? Anything else that comes to all of you English bike owners?
#961
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
However...whenever I get a new to me 3 speed the first thing I do is take it for a short spin and see what works and what doesn't.
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Likes For wahoonc:
#962
Liked 2,496 Times
A lot of what I do is visual. But at the bare minimum, I repack the BB, front hub and headset. Rear hub I dump some oil in and if it shifts okay, let it slide. I almost always replace brake pads with Kool Stop Continentals. I may oil cables or replace if they are rusty and ugly. If the bike is in really rough shape I do a complete tear down and clean up.
Aaron
Aaron
I do oil the rear hub. I replace the cables if needed. Sometimes, they just need oil. And sometimes, I replace the brake shoes. Basically, I do as little as possible on these machines. I like to true wheels, though, so I do that if needed. They often have cotton rim strips, so be ready to replace them. Sometimes, they fall apart from age when you take the tire off.
Obviously, you'll inspect the tires and replace them if needed. The tubes are usually OK. My 1967 had old tires, not original, and they were seriously dry rotted. I rode them for a while, but they recently gave out, so I am replacing them.
#963
Rustbelt Rider
Quoted: 261 Post(s)
Liked 372 Times
That is surprising. It seems 99% of the old bikes I have found had bearings in very poor shape. Most of the time I find them adjusted very tight with a mixture of sand, gunk and bugs in the bearings.
#964
Liked 2,496 Times
Yeah, but oil will flush all that cr@p out.
#965
Bicycle Repair Man !!!
If the cables and housings are good I give them a little lube... many of these bikes have spent their lives in warm dry garages so corrosion is not an issue.
Likes For Sixty Fiver:
#966
Liked 8 Times
I am with 65er.
Remember, all these English hubs/BBs were originally intended for oil, and the older ones have oilers on both hubs and the bottom bracket.
Having said that, modern grease is good stuff and will tend to keep the rain out of bearings.
But never grease a 3 speed hub! Strictly oil.
It is not hard to have a sneaky-peak in a 3 speed - pop off the retaining wire ring for the sprocket, take off sprocket, undo lock nuts and ease the drive side of the hub out for a look. If all clean and no rusty oil or grit, slosh in some 30W oil and put it back together. I recently did this to a 1939 AW hub, and it was pristine inside after 70 years and didn't need stripping. It changes perfectly and never slips.
I prefer a bike that is mechanically OK but perhaps looks a bit scruffy, than vice versa
Likes For AL NZ:
#967
Liked 2,496 Times
Upon reading your comment, Al, I guess I prefer scruffy bikes. Nearly all of my bikes are scruffy. I don't enjoy cleaning them. But they work extremely well. This is also a useful strategy, as it makes the bikes less of a target.
Likes For noglider:
#968
Quoted: 5 Post(s)
Liked 6 Times
I do a complete overhaul of all the bearings as even if they are smooth I want to see what is in there... rear hubs get a little drink of oil and if they run smoothly I don't do anything else and this is the case for 99% of the three speeds I work on.
With any new 3 speed (just did this with my sister's Schwinn sporting an AW hub), I shoot WD-40 into the rear hub until it's profusely running out the sides, then ride it (not using the back brake!) for 25 miles or so (not necessarily at once). I'll then switch to ATF and do the same thing once or twice, then clean it up, drop on a teaspoon or so of ATF (I have an old "dinka dinka" style oil can for this), and off I go. The Phillips got a greased BB and head, but the hubs are both oiled - with the front, once every 6 months or so, I'll take off the wheel, loosen the nuts, and shoot liberally with the same ATF the rear hub gets. The BB will probably get regular anointing with the same after the first couple years, because I bent my cotter press trying to get out the damn cotters on my UO-8 (cutoff torch is your friend with those bastards...).
#969
I am with 65er.
Sometimes a bike just gets a clear coat to protect it from the elements and preserve the original decals and patina and in other cases I might be looking at a tear down and total re-finishing job.
Just picked up a custom made mtb that was built here and the paint has seen better days so it will be going out to the shop for powder sand blasting and powder coating.
It was a three speed for about 30 minutes today too...
#970
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
That is like my philosophy for my FrankenVega, the bike I take into town and leave locked up for hours at a time, i.e. "scruffy" on the outside, but clean on the inside.
#971
Thanks to everyone for the insight. My bike arrived today and it is really stellar, at least appearance wise. Seems like it's spent a lot of time sitting in a comfy spot while not acquiring many miles in it's 38 years. I still need to reassemble the front wheel, handle bars, lights, etc. Then I think I'll take a look at the bb, front hub and headset. Pour of few drops of 10W30 into the SA and see from there. I hope to have it going by early next week. It's already begging me to be ridden. I will soon abide. Thanks again.
#972
Liked 8 Times
Jedge, I am no oil expert, what I know is just from car oil changes.
Californ-i-a is fairly warm no snow, yeah?
So 10W-30 is good for cold engine start up, and probably good for bicycle bearings in frozen climes, but you probably don't need it in warm ol'CA
4-stroke lawnmower oil is 30-viscosity and, I understand, almost the same as the original-spec singe-viscosity oil as specified by Sturmey Archer 'back in the day', as they say.
Having said this, I personally think we all fret way too much about what is the best oil/grease/etc, and anything is better than nothing, and regular attention and the occasional clean of the bearings probably exceeds the original design parameters.
None of us can generate the loads that a bog-standard home-handiman trailer's wheel bearings are subjected to, so even the cheapest modern grease should be ample for all cycle bearings.
Main thing is, never grease the Sturmey 3 speed (but maybe just its outer bearings to minimise water ingress)
#973
Quoted: 70 Post(s)
Liked 15 Times
I have one Sturmey Archer AW hub that has somewhere over 30,000 miles on it. It is the best shifting of all of my hubs and is still ticking along after 35 years of pretty minimal maintenance.
Aaron
Likes For wahoonc:
#974
Liked 8 Times
interesting, your use of the phrase 'ticking along'.
Its origins are probably obscure, but it is the perfect description of a good Sturmey Archer hub, and maybe that is the source..
#975
