How To Use Naphtha For Stripping Factory Lube From Chain?
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1953 Post(s)
Liked 1,475 Times
Yeah, at the local Home Depot there is a bottle which supposedly "replaces" or "is the equivalent of" toluene and MEK, I forgot the exact wording. But toluene and MEK are not the same thing so I don't know how one product can "replace" or "serve as the equivalent" of two distinct organic solvents. (I spent so much time in Home Depot yesterday studying organic solvents on my phone.)
Klaatu..Verata..Necktie?
Quoted: 10445 Post(s)
Liked 11,929 Times
Although HomeDepot.com lists the CARB version as being in stock, it is unfortunately not for sale anywhere in the South Coast Air Quality Management District. I discovered this yesterday at the third Home Depot I visited.
BTW, I can see a use for isopropanol IF you used an aqueous degreaser, to remove/replace the water in the chain with something that dries faster and more completely. But not after an organic solvent.
Liked 11,929 Times
Oh, and speaking of solvents, guess what the Army recommended to its watchmakers as a solvent for final rinse of watch parts, back in 1945?
Gasoline.
Gasoline.
Quoted: 6201 Post(s)
Liked 4,816 Times
I worked with a painter on a summer job years ago that used gasoline to clean brushes and rollers because typically it's cheaper than paint thinner or mineral spirits.
He was a cheap SOB but was a darn good painter. Man, I hated working with gasoline. I just knew I was dealing with an undetonated napalm bomb once the stuff got saturated with paint. Plus he had those cans sitting around the back of his van fumigating the inside.
Liked 11,929 Times
Likes For genejockey:
Liked 4,816 Times
I used gasoline for most all degreasing and cleaning things up until my mid 30's. Paint brush clean up too. It was cheap and readily available anywhere.
Just because I got away with it doesn't mean I wasn't stupid for using it.
Gasoline is just too volatile and it forms a puddle of invisible vapors that eventually find a spark. Even when the spark is 20 feet away.
Which is why I quit using it in my mid thirties. My lesson didn't cost me much.
Likes For Iride01:
Liked 11,929 Times
I would not want to be their livers.
Liked 1,475 Times
How hard do I have to shake? I did this a few times with acetone yesterday. The acetone turned grey and contained a lot of black flecks or specks. On the chain itself, only the rollers are shiny; the plates are still dull grey and do not look perfectly clean? I am hoping not to have to clean the chain with a Sonicare toothbrush over acetone; that cannot possibly be good for my health.
...stick your hands in lacquer thinner, and pull them out about the time they start to sting!
I guess the original thread has been sufficiently hijacked by now.....
Liked 1,475 Times
Yes, isopropyl alchol to chase off (volatilize?) residual Purple Power or Simple Green.
Liked 1,475 Times
Liked 11,929 Times
Well, it was the mid-70s in rural Pennsylvania. Probably peak level of irresponsible environmental and occupational practices.
