Totally Tubular
#2876
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times
Got a pair of the 25mm. I believe 28 would fit, but didn't want to take the chance of them not fitting and missing out. Saw this earlier the day you posted, and pulled the trigger. Excellent price
Likes For Senrab62:
#2877
Bikes: Two Peter Mooney customs, a 1980 Trek 510 townie, a Marin Stelvio set up for TTs.
Quoted: 228 Post(s)
Liked 294 Times
Ummm... Based on a quick google, I don't think those are tubs. Nice text in some ads like "The ride of a handmade tubular with the convenience of a clincher." That doesn't sound like a sew-up to me. That also accounts for the price being far less than Vitt's sew-up tires.
#2878
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
Even more confusing when the clinchers are more expensive.
#2879
Bikes: 1981 Bianchi Specialissima, 1971 Bob Jackson. 2012 Kestrel 4000. 2012 Willier. 2016 Fuji Cross 1.1, 1950 Hetchins, 194X James Fothergill, 1971 Paramount P15, 1973 Paramount P12, 1963 Legnano
Quoted: 280 Post(s)
Liked 955 Times
Likes For SwimmerMike:
#2880
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
I can confirm @SwimmerMike's assessment. They are tubulars.
I just pumped up a pair of 28s and a pair of 30s. I do have a couple questions about them:
- They have black valve stems which seem removable with a 5mm wrench. Are silver replacements available? Can the black be sanded off?
- The page for these puppies on the Vittoria website goes to some lengths about the cotton casing and the graphene additive to the tread, but mentions nothing about the tubes. Are they butyl or latex? I don't really care (though figure for a top-of-the-line tire they should be latex). I just want to know how long I should expect them to hold air during a "leak down" test.
Likes For smontanaro:
#2881
Quoted: 279 Post(s)
Liked 326 Times
I am curious, did the 28 measure at 28? I'm considering getting a pair, but am worried about clearance.
#2882
Quoted: 4806 Post(s)
Liked 3,932 Times
Likes For 79pmooney:
#2883
Bikes: many
Liked 1,395 Times
Don't know. They aren't mounted on rims. I haven't even removed the hang tags yet. I only inflated them to 30psi to make sure there were no obvious defects.
#2884
Quoted: 280 Post(s)
Liked 955 Times
#2885
Quoted: 228 Post(s)
Liked 294 Times
Conti glue on the rim still has some tackiness, and I still have the piece of paper that comes stuck over the valve stem. Right now, I have the tire patched and waiting for sewing, but I had hoped to get at least a few hundred more miles on it before I had to do this, and I have no fresh sew-ups at this point. That flat was one of the last two.
Likes For MooneyBloke:
#2886
Quoted: 280 Post(s)
Liked 955 Times
Indeed. I may find myself taking advantage of this. I am having a spate of horrid luck. Yesterday, I plugged a slow leak in my front with Stans, and today I was resigned to twenty miles of gusty headwind for the first half of my ride, and suddenly at about 3km out PSSSSS!!!!! I figured my sealant hadn't done the job, but no!!!!! It was a relatively new Veloflex on the rear rear that got eaten by something. I didn't glue it that long ago, the
#2887
Quoted: 228 Post(s)
Liked 294 Times
Agree. That's why I have the patient open and patched and awaiting the needle. Stan's might get me home without needing a roadside change if I get that sort of puncture, but it won't hold the 6.9bar front and 7.6bar rear that I run in my 23s. So now, both the front and rear tires on that wheel set have little blue Sharpie marks (another good reason for gum sidewalls) indicating leak locations. Chafing tape's back in place, so now let's see if I can get this beast stitched back together without making it horridly lumpy.
#2888
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
Likes For L134:
#2889
Quoted: 228 Post(s)
Liked 294 Times
Got the beast (Veloflex Crit) sewn back together and glued on; it seems like it's not lumpy. No idea whether the tire gremlins will smile on the effort or not.
Edit the next day: sadly, the tire gremlins were angry at my hubris, and I'm home, but I'm out one CO2 cartridge. Don't know if it's a new hole or a patch failure. I'm just happy, the nasty spare from under the seat didn't go pop on the way back.
#2890
Quoted: 228 Post(s)
Liked 294 Times
Dumb question time: at what point do you strip the old glue from your rims?
#2891
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Had a front flat yesterday (Vittoria Rubino Pro G+ 28mm).
The wheel was bent in a collision 1 month back, but I thought the tyre was OK (I rebuilt the wheel after the forks were fixed).
Tried the frame pump, then walked it home (1 mile).
Installed more Orange Seal and flat gone
The Orange Seal was the same bottle I used 13 months (and about 2k miles) back when I first discovered sealant.
I think I lost some fluid while fixing the wheel, or I've had several punctures I didn't notice,
either way I'm quite impressed with sealant
#2892
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,197 Times
Bob
Bob
#2893
Liked 3,932 Times
I said this in past tense. I'm back to tubulars and Tubasti after 25 years off. (First run was about 25 years.) So all my wheels are pretty new without great glue bases and I don't yet have the confidence to fully bomb corners. (I'm also 70 now so there's that also.)
#2894
Quoted: 228 Post(s)
Liked 294 Times
So yesterday, I wound up stripping the rear. I miss the old dichloromethane strippers that would quickly turn any sew-up glue into easily removed snot. Evidently, someone asphyxiated himself by using one in an enclosed space to strip a piece of furniture, so the only strippers now available do a mediocre job of loosening the mastic, and one needs to do several attempts. Now the thing is stripped, wiped down with acetone, and reglued.
Sadly, the victim (tire) had to be opened three times. After the first patch, I heard a snick I though was a twig only to have my tire go soft at eight miles down the road. Happily my spare and CO2 cartridge came to the rescue, and the spare despite rubbing up against the saddle rails held until I got home. So open the beast and replace the patch. Once again I heard the snick when I went out to see how lumpy my stitching was. Damn! Open and look carefully at the patch (1 sq-in latex bit), and there's a hole in the patch at the same place the original puncture occurred. I look carefully at the injury to the casing, and I think there are three or four threads cut, and I think there's just enough room for a latex tube to stretch out and pop when the tire flexes. Now, as an experiment, there's a 1 sq-in piece of duck cloth (boot) glued to the casing with E6000, and a third patch has been applied, and I think there's just enough bulk that the tube can't push out through the cut. No snick so far, but I'm a bit leery about how far this thing can roll. The tire seems no more lumpy than after my second attempt. I think the thing is to examine casing injuries, and assume that a small boot may be needed if more than a couple of threads are cut. I suspect a butyl tube would not have this issue.
#2895
Quoted: 228 Post(s)
Liked 294 Times
Tire with the duck cloth boot and patch survived 67Km today. Yes... a bit lumpy, but it did better than I expected. Examination of the exterior suggests the boot didn't protrude at all, and that was my main worry. I had filled the cut with E6000 (stretchy rubbery urethane adhesive), and even that seems to have stayed put.
#2896
I can understand, but it gets to a point where the base is quite visibly thick and has picked up junk from the times the rim has been tire-less. At our age, I think criterium corners are wisely a thing of the past regardless of glue job. There are plenty of other ways to wash out besides rolling a tire.
NOPE!
You convinced me not to, by reminding me of all the troubles I once had with them and how happy I was to eventually get some high performance clincher tires.
What was I thinking? I do not mean this as a put down, just my reaction to the posts. I selected MooneyBloke's post as representative of the cause of my reaction..
Enjoy riding whatever tires you care to use.
#2897
Liked 3,932 Times
I came to read some of this thread, starting at the end, thinking I might just try tubulars again.
NOPE!
What was I thinking? I do not mean this as a put down, just my reaction to the post.
NOPE!
My driving reason is that I had an older clincher blow, come off and jam in the seatstay. At less than 25 mph. Broken collarbone, ribs and a couple of acres of road rash. Haven't fully enjoyed a fast downhill since until I went back to the sewups that I used to ride to a stop after blowouts from 45 and it wasn't a big deal. (Well, I ride sewups better than my old $18 training tires. No longer a poor racer.)
#2898
Quoted: 228 Post(s)
Liked 294 Times
I'm not here to tell you what to ride, but I'm sure there are plenty of sob stories no matter what sort of tire ridden, 79pmooney's clincher crash story as one example.
#2899
Liked 3,932 Times
I think you drew the wrong conclusion from my sermon. This was indeed the worst situation I've had with sew-ups in decades of riding them. It really boils down to doing a sloppy repair and paying a price for it. If I had carefully examined the interior of the casing when I had the tire apart initially, I might have applied a boot as I did eventually. (Two rides later, and that boot still survives. Still feels a bit lumpy on smooth pavement.) Also, with sealants like Stan's and strong waterproof boot adhesives such as E6000, repair and avoidance thereof are far easier than they were in the early eighties when I started. It is also important to bear in mind that the tire of which I wrote was a Veloflex Criterium. This was a light road racing tire, and there are sturdier sew-ups out there. I might add that having four sets of sew-up wheels, I'm somewhat committed.
I am a big fan of Vittoria's various "G" tires. That graphene appears to make for a simply better tread. Been riding their (confusing!) Open clinchers for a few years and am really happy to report the tubulars are all of that quality, ride and reliability along with good, even stitching and well glued tape. Joys to mount and ride.
I actually wanted to post just because yesterday I went for a random fix gear ride on my Mooney, leaving with the mountain gears on. (Low gear from 2017 when I was considerably younger and stronger.) 46-14, a nice downhill gear, the ubiquitous 42-17 flat ground gear and 36-21 uphill. Decided to try McCormick Hill Road. Well, it became obvious I don't have the miles and fix gear strength to get to Mountaintop Road and Bald Peak so I stopped 2/3rds of the way up, admired the view, but it in high gear and sailed down. (Keeping it sane; the hill ends with a well into double digit blind off camber turn.) Did another 30 miles, foirst nursing the bike and body over several bumps in the big gear to have that fun roll on the other side, then back to the 42-17 and cruise.
All on the same 28c G+ tires I rode Cycle Oregon on last fall. The ribs are gone from the center of the rear tire, they weigh a little more with that latex but they still run as sweet as you could ask. Didn't note the pressure when I pumped them up but probably 88 +- 2 to 3 (I run rears 5-6 psi higher in back). Ahh! The magic carpets! And on a sweet beast in the tradition of a classic English road bike. (Well not totally classic. The brakes were unusually clean. I usually pay no attention to them but yesterday that front sparked in the sun and I kept getting reminded what great stoppers they are. (Shimano cantis that were stock on one year of Miyata 610s. So nice I swapped out the original Mafacs for them. Yesterday they got to do their work.)
So good to be back on the magic carpets (Are they still hand stitched by
#2900
Quoted: 228 Post(s)
Liked 294 Times
It sounds like things are going better in Thailand than when I bought a few Vitt CX tires. I remember the tires occasionally rather lumpy, and the Vitt tubes actually being thinner and smaller, and the base tape being nearly impossible to remove without tearing. It seems as if they've cleaned up their act considerably in the last couple of decades. Even those were far better than the tires I rode in my youth. I still have a couple of ugly orange Conti Sprinters I keep around 'cos they still hold air.
