Totally Tubular
#1601
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
Do Tufo tubular-clinchers count as semi-real tubular tires?
I just ordered a pair of Tufo S33 tubular-clinchers for the mid-90s Mavic Cosmic wheels I bought on CL last year. They are for my '93 Cannondale R600. I wanted to run tubular wheels, but the wheels were $85 and such a good deal.
Any experience here with Tufo's tubular-clinchers? I'd appreciate your insights.
Bob
Bob
#1602
Quoted: 765 Post(s)
Liked 660 Times
just glued my second set of tires on.......I followed vittoria's instructions for the first one and it when on but was a fiight, pretty sure I got the valve down and then went back to what yellow jersey as documentd.....this worked about 1000 % better
so for newbie gluers IMHO read this and follow and your will day....what is the big deal
Tubular Tire Mounting Cement Gluing Adhesion by Yellow Jersey; Thoughts on a Front Wheel
The YJ directions on repairing tubulars
Tubular Tire Repair at Yellow Jersey
are also wonderfully straightforward. Had I read them first, I might not have gone straight to sealant after my first flat. Which, I should add, arrived once I had a whacking 15 miles or so on my first set of new tubulars. Maybe that's better than average performance on Vermont roads--I guess I'll find out.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
#1603
Freewheel Medic
Liked 2,196 Times
jonwvara as we say, "YMMV."
In fear of bringing on a major tubular catastrophe, I've yet to experience a tubular flat!
Now that I've said this, I will have one 45 miles from home, alone, with no cell coverage, while a major thunderstorm rumblies over the horizan in VT.
Bob
Bob
#1604
only here for the "LIKES"
Quoted: 1643 Post(s)
Liked 2,240 Times
these are gluing instructions that i found posted on Paceline (i might have even posted them in this thread before). this was posted by a well regarded wheel builder/mechanic, ex-shop owner, etc. i had no problems using this method, pretty straightofrward, and it wasn't messy.
again, here and assuming a pre stretched tubular and solvent brush
PLUS my favorite glue is Panaracer.. a can of it is the best..doesn't dry out like can of Vittoria, but Pana cans hard to find..I just use tubes. USE in well ventilated area or you will 'take a trip without leavin' the farm''..
Emory paper on rim, and on tire(new rim and tire)..wipe off with acetone.
Wee bit of air in tubular..most will 'turn' 90 degrees.
THIN coats, edge to edge.
-Glue the tire-thin coat
-immediately glue the rim
-then glue the tire(no, don't wait a day-dumm)
-then glue the rim
-then glue the tire..NOW wait until glue on tire is sticky to your finger(about 20 minutes)..then
-Glue the rim, and then mount the DEFLATED tire(rim on ground, valve in hole..push, push, push down each side on sidewalls)..pull onto rim..never touching glued part.
-wee bit of air again, center tire..
-roll on ground, pushing down hard..particularly at valve.
-Wait- 24 hours, go ride.
-then glue the rim
#1605
Bikes: many
Quoted: 1446 Post(s)
Liked 1,395 Times
After centering the tire I inflate the tire well above the pressure I intend to use (say, 100psi if I'm aiming at 60-80psi ride pressures), then do the 24-hour wait. This (I believe anyway) makes sure the base tape is sealed all the way around and is pushed all the way into the well of the rim. I wonder if the "roll on ground" step is intended to achieve the same goal.
#1606
Quoted: 2338 Post(s)
Liked 2,827 Times
#1607
Liked 2,827 Times
Back wheel, different story, i had a huge high spot around the stem, such that it hit the frame on rotation. I attribute that to not having streched the tire on both sides of of the stem enough
so I learned that I can take the tire off without tools, which gives me more confidence for on road exchanges (I used tufo tape on tufo tires...and don't think i could have gotten those off on the road without tools)
I also get to reglue the tire and install so more practice
all good and all learning
#1608
Liked 2,827 Times
Thanks for posting that link. It can be that easy? One coat of cement on the rim, another coat on the tire, then mount ten minutes later? No multiple coats on both over multiple days? Had I read that before, I might not have defaulted to tape for my first experience with tubulars.
#1609
Quoted: 4806 Post(s)
Liked 3,932 Times
In my 27 years of tubulars, I never applied glue to the tire basetape. Always seemed to me like a lot of work and messy. I do examine the basetape to make sure I trust that the glue will stick well. Been known to wipe it with solvent like lacquer thinner. I just applied the glue over the old, well bonded glue, let sit for a while, then mounted the tire. Usually do a very gentle roll around the block on the freshly mounted tire. Let it sit for a day, try to roll the tire off and ride the heck out of it. Never cleaned rims. I would use a file or the like to smooth out especially lumpy old glue. (New, clean rims scare me. I don't fully trust the tire-rim bond until its the second gluing and I had to work to pull the first tire off.
Hardly rocket science or even difficult. For non-race wheels, I always used Tubasti (which I see is still made) because it did not set up hard and an on-the-road change done dry is well bonded in a couple of miles. (I still didn't corner hard but that spare would be solidly on when I got home.)
(This was my system when I didn't own a car and rode at times at night in sketchy neighborhoods. Loved that I could be out of there whatever happened to my tire in 5 minutes. Rain, snow, alcohol; didn't matter. Rip the tire off, stick the used spare on, pump up and go. I might get seasick looking at the tread waving around but that didn't matter. It was going to get me home.)
And yes, I am going back. My current clinchers get ridden until the rims wear out, then it's back to the good stuff. Again for security; not bad neighborhoods now but big descents, If I ever flat a tire at very high speeds (easily reached in western Oregon) I want to be on glued on sewups! Coming to a stop is so much more boring! (Yeah, I gotta admit, a real part of this I want to go back to riding the magic carpets. I got to race on Fiamme Ergal rims and Clement Criterium Setas. Doesn't get a whole lot better. I want that high again. I will settle for a little more weight now.)
Ben
Ben
Likes For 79pmooney:
#1610
Bikes: many
Liked 1,395 Times
Check the diameter of the valve stem hole w.r.t. the shoulder around the valve stem. In The Art of Wheelbuilding, Gerd Schraner bemoaned the fact that he basically always had to countersink the valve stem hole to get the tubular to lay flat. I don't recall if he was blaming the rim or tire manufacturers. Worth a check before attempting the second installation.
#1611
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
I gotta say though, my tires are damn hard to get off and I could probably ease up some without sacrificing any safety.
Likes For DiabloScott:
#1612
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
#1613
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 346 Post(s)
Liked 175 Times
I asked Veloflex and they responded that, yes, the Vlaanderen has been discontinued and that the 28mm ProTour is the best replacement. I would love to hear a ride report. I don't know how Veloflex marketed the Vlaanderen, but the ProTour is marketed as a "training" tire. I hope the casing and tread are similar between the two and that the ProTour doesn't sacrifice ride characteristics in the name of puncture resistance.
#1614
If I own it, I ride it
Quoted: 591 Post(s)
Liked 663 Times
@L134 Thanks for the report. Those will for sure get a look when I am in the market.
Allow me to add another high end choice. Specialized Turbo Hell of the North 28mm. These are pricey, but I snagged an unused set for less than half price. Oh my are they nice. I am a big boy, so I am running them at 70F and 80R but I think I can play with that. Yesterday was the best the CT has ever felt under me. I rode more than I planned and had my "best times". While out of the scope of this thread, I can say the clincher version of these are quite nice also.
EDIT: I am mistaken. I confused these with some FMB tubulars I bought. These can be had for not much more than the Veloflex. Not cheap, but not as pricey as I stated.
Likes For CV-6:
#1615
Liked 2,240 Times
Veloflex instructions that came with a pair of Vlaanderens I just bought.
#1616
Quoted: 1952 Post(s)
Liked 2,013 Times
Likes For Classtime:
#1617
Quoted: 1814 Post(s)
Liked 923 Times
I ordered one of those as I had a gift certificate to use up. More than I usually pay for tires,
but should be good for the winter/foul weather set up.
Have you got a padlock on that fence?
#1618
Liked 2,827 Times
Baby has new shoes.... Vitorria Corsa G+ Control. These are supposedly a a little tougher then the corsa g....we will see, I hope so as I had flat issues with corsa G+ clinchers.
30 mm, measure 30. For context replacing Conti GP 5000 clinchers. (tubed) which have been great tires
First impressions smooth, very smooth. and handled little bits of gravel and rough spots really nicely. Noticeable improvement from the cont's, but not night and day noticeable as when I went from some 25 mm bontrager clincher to 25 mm challenge elite pro on my other team miyata. Not sure if any faster, but handle well. Overall I am happy.
Interesting that it seemed like they "settled in" and go better as the ride went on, so will be really interesting to see if that continues for a bit
and of course DiabloScott fold for the spare
Likes For squirtdad:
#1619
Quoted: 835 Post(s)
Liked 2,135 Times
@squirtdad, looking good. I've got a set of the corsa g tubulars on my De Rosa. After ~6 months, I'm finding that they give a great ride, and are fairly resistant to flats. However, I keep picking up little bits of glass, thorns, and other sundry road debris in the channels on the tread. Nothing too serious: 2 slow leaks that have been fixed with sealant (happened again on yesterday's ride), and other debris that I removed before it pushed into the tubes. I do suggest periodically checking these tires, particularly those channels in the tread that run the length of the tire, to see if they've picked up anything unwanted.
Likes For gaucho777:
#1620
Freewheel Medic
Liked 2,196 Times
gaucho777 and squirtdad somehow we need to figure out how to mount rootboy 's tire wipers/flint catchers on brake calipers mounted with recessed nuts and bolts. I've had a great experience when using them with both tubulars and supple clincher tires.
Bob
Bob
#1621
Bikes: many
Liked 1,395 Times
#1622
Liked 2,827 Times
hmmmm. maybe an insert that can expand that fits in the hex hole**********?? almost like a mini velox bar end plug
#1623
Liked 2,827 Times
#1624
Liked 3,932 Times
Those are for recessed brakes. Narrow end is the recessed hut, Bigger end is threaded one size larger (and you may have to drill fenders, etc. for it). The large size is also milled for a 6mm allen wrench and goes on just like the regular recessed nut except that one size larger on the wrench. Pretty ingenious. I have them on two bikes.
Edit: if clearances are tight, you can run tiresavers backwards. IE front saver pointing back. (You'll have to re-bend the mount part but that isn't hard.) Drawback is that the saver will now scrape dust into hour headset. Either use lots of a marine grease on the lower bearing (so much it oozes out the first few rides) or cut an inner tube to about 3/4s of an inch and slide it over the headset (pulling the fork out). (Or use a mini fender except that won't work because of your clearance issues unless you are ready to jump though anther hoop, cut the mini fender and use a River City bracket.)
#1625
Liked 923 Times
Or just skip forward to where you take them off because of the annoying noise and no detectable benefit.
