For the love of English 3 speeds...
Bikes: Several
Quoted: 74 Post(s)
Liked 164 Times
Well done, 'Small cog'.
Where's there's a will......
I've been a motorcyclist for over 50 years and wouldn't have even considered doing that!
A lovely understated 'Lenton'.
Likes For Cyclespanner:
Palmer
Quoted: 1671 Post(s)
Liked 1,825 Times
Bikes: Several
Quoted: 74 Post(s)
Liked 164 Times
tcs, I'd call that rust just a flesh wound
Count Orlok Member
What did you use to clean it up? Someone gave me a rusted up AW. I soaked the parts in ATF, and finally got everything apart. I'm wondering if I need to buff or scrub some of the rusty areas, or just put it together with some lube...
Likes For gna:
Bikes: 1993 Diamond Back Sorrento, 1965 Schwinn Racer 3-speed, 1987 Schwinn High Sierra, 1990 Specialized Sirrus, 2020 Specialized Sirrus 3.0, 2013 Giant Seek 1
Quoted: 87 Post(s)
Liked 776 Times
Likes For zookster:
Bikes: Vintage Raleigh and more modern Roberts
Quoted: 55 Post(s)
Liked 148 Times
I am dealing with an AW in similar if not worse condition. All four pawl springs were just rusty bits once I got it apart. Does anyone know a source for them, other than the $6-$8 each (plus shipping) on Ebay? Will also need all bearings replaced. This is for a mid-70's Raleigh Sport a friend gave me.
Likes For Small cog:
Quoted: 7350 Post(s)
Liked 2,475 Times
I would get rid of all the rust on the internal parts of a geared hub. If you do that, there's no guaranty that it will work, but leaving some rust on reduces the chances further.
I once opened up an old hub and found the lubricant had turned to varnish and had hardened on the surfaces. It took a lot of scratching to get it off. In the end, the hub worked well.
Bikes: 1951-2 BSA 900E Roadster, 1961 Triumph Sports, 1953 Raleigh Sports, 1981 Raleigh Superbe, 1976 Raleigh Twenty, 1951 Taxandria, ±1950 The Gold Lion Tandem
Quoted: 40 Post(s)
Liked 14 Times
Here is a nice example (my biased opinion) of a 1950s Raleigh “Sports Light Roadster” model 22. Approximate vintage is 1955-1957 based on the excellent visual identification chart available
on the headbadge site. The model name variation is also lifted from this chart but can’t independently confirm. Alas, this one has a single speed SA freewheel rather than 3 speed.
But a very nice bike btw.
Peter
Bikes: Several
Quoted: 74 Post(s)
Liked 164 Times
Two pertinent questions....
1. AG Dynohub AG/AW weights
AW = 2.35lb
AG = 3.66lb
So the AG Dynohub is1.32lb heavier, plus a suitable lamp/wiring set.
For Sunday rides is the extra weight/clutter worthwhile?
2. What do you folk use to protect chrome steel rims and avoid contaminating brake blocks?#
AW = 2.35lb
AG = 3.66lb
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Learning To Fly
Palmer
Liked 1,825 Times
Campy High flange front hub = 1.27lb
Total = 4.93lb
AW = 2.35lb
GH6 = 2.50lb
Total = 4.85lb
Well, blow me down. It's about a wash.
In answer to the question, if the Sunday ride will be home before twilight (even with a flat tire repair) during the short days of winter and there's certainty a rainstorm won't blow up and if the cyclist has other bike(s) to ride at other times & conditions or if the battery lights are checked routinely for fresh/charged batteries, then certainly the weight/clutter of a dynamo light system can be dispensed with.
Likes For tcs:
FreedomRider
This past weekend I began hearing a clanging / metal on metal noise in the front end of my 1971 Raleigh Sports. I convinced myself that it was the front mudguard scraping against the front tire, causing a rattle.
Turns out, I had a bit of play in my front hub. I removed and cleaned the axle, cones, and hub. Repacked the 3/16" bearings with Phil Wood Waterproof Grease, and reinstalled the cones (as per Sheldon Brown's method). Smooth as silk, no more noise.
Axle, cones, washers, nuts, and bearing from the Raleigh Sports front hub.
Likes For bharrisonb:
Quoted: 55 Post(s)
Liked 148 Times
Looking through this thread I realise the Raleigh Twenty I renovated is also comes under this catagory so here it is, I had one as a child although badged as a Triumph and on a nostalgia trip bought this one for a tenner on Ebay and it was only a short train ride away. It is the rarer Sigma fitted with drum brakes which I like even if you have to make allowances when stopping especially on hills, this is another restomod which took 7 lbs off of the weight and the bmx wheels and tyres made it capable of some gentle off roading, although the Triumph I had as an 8 year old also did plenty of off roading at the time.
As I picked it up.
And after renovation and being put on a diet.
As I picked it up.
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
This is my current favourite three speed, not for the purist it is something of a restomod, a 1950 Raleigh Lenton that was picked up from the scrap pile at my local bike shop, my friend who owns the shop said "if you don't take it today the scrapman will take it tomorrow" I was on my motorcycle at the time and had a couple of straps so home it came. There was not much of any use, even the SA four speed was a solid lump of rust inside unfortunately but the frame and forks were still sound so I had them sand blasted and resprayed them with aerosols, it is not a standard colour but I like it and have badged it as a Clubman although it is not.
It has a lot of 1970s updates with a compliment of Sakae Ringyo components mostly bought cheap in poor condition and restored on my polishing wheel, a nos Shimano 3 speed hub and Bluemels mudguards from the same bike shop and a Brooks plastic saddle which is ok but get a bit firm after 30 miles. This has taken the weight down from about 35 lbs down to 27 so quite a reduction.
"I was neck-and-neck with this guy on an old 3-speed. I couldn't shake him. He must have souped it up, or something".
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Bikes: 2018 Focus Mares CX 105 // 1984(?) Guerciotti GLX 7600 Super Record // 2021 Giant Stance 27.5” // 2022 Poseidon Redwood
Quoted: 71 Post(s)
Liked 23 Times
Hi All, sorry if this question has been asked before…is there an assembly manual/book somewhere that has exploded diagrams or images for assembling/restoring a 1970s Raleigh Sport 3-speed? Thanks.
Bikes: Several
Quoted: 74 Post(s)
Liked 164 Times
Seriously though, Mr Google has a very big selection to choose from.
Then there's your new found friends here.
Ask a question.....it will be answered.
Probably
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 857 Times
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Likes For SirMike1983:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
Specific manuals for Sturmey Archer and exploded assembly diagrams are widely available online. Parts are often found on this forum.
Likes For clubman:
Bikes: Several
Quoted: 74 Post(s)
Liked 164 Times
UK ebay item...
A Raleigh Lenton Grand Prix 23'' frame set at a not unreasonable £40.
Very tempting. What would be involved, putting an AW hub into such a frame designed for a derailleur set-up?
Quoted: 55 Post(s)
Liked 148 Times
Bikes: Several
Quoted: 74 Post(s)
Liked 164 Times
Hello again 'Small cog'.
Your Carlton looks the business.
Is there much difference between the drop out measurements?
If so how is that accommodated?
This one I've highlighted is too big for me anyway. I have a 21'' 'Chiltern' which I'm going to have to get used to.
Depending where one looks a 21'' frame should suit my 30'' inseam, but no, it's a struggle if my attention isn't turned up to 10.
It's a shame they didn't do a proper lightweight using the roadster slack angles.
May be they did? (I don't mean the 'Clubman', Reg Harris types).
I've been doing some amateur research based on enlarging good quality photographs of the many and varied frames used on the roadsters and am finding the frame angles vary a lot between what look to be similar cycles.
Someone must have a collection to accurately measure these details from?
Quoted: 55 Post(s)
Liked 148 Times
Quoted: 3811 Post(s)
Liked 6,715 Times
Back to 5-speed Sprites for a moment, there's a nicely preserved specimen on Boston's CL:
https://boston.craigslist.org/gbs/bi...691843033.html
I particularly like that big-a$$ shift lever!
Palmer
Liked 1,825 Times
Sturmey offers a variety of 3-speed shifters and a collection of cable stops & pulleys to get the shift wire from the 'cockpit' back to the hub.
There are two different widths of anti-rotation washers: the 7.9mm (example - HMW155) and the 9.5mm (example - HMW494) for different width dropout slots. The derailleur bike probably needs the 9.5 version.
If you have the narrowest axle on the three-speed hub, you might need to move the anti-rotation washers to the inside of the dropouts to match your OLD.
Likes For tcs:
