How High Maintenance are Tubeless Tires Anyway?
#126
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
The point, however, was that if a person knows how to repair a tubed tire, then repairing a tubeless-ready tire with a tube in it falls within that person's skill set.
#127
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
Its not a big deal - been using them on my MTB for years --- have not flatted since using tubeless ----
I have a set on my big travel Yeti that seldom gets used and the tires are still holding air with the original sealant in them -- and the tires were installed Christmas Eve 2018.
PErhaps an extreme case and maybe a smaller 'cross tire might need to be refreshed more often , but 2 1/2 years without cracking open the bead to refresh the sealant is pretty good to me --- Its Stans Race IIRC
#128
Nope.
Tubed - mount starting at valve stem (least resistance), finish opposite valve stem.
removing tire - start opposite valve stem
Both ways put the least stress on the valve stem area of the tube.
Tubeless - mount starting opposite valve stem - tubeless valve stems take up space in the rim channel and increase the overall diameter needed to mount the tire.
removing tire - start at the valve stem - you won't agitate the tube/rim hole area like you would with a tubed tire. And again, a tubeless valve stem takes up space in the channel.
Likes For Rogerogeroge:
#129
Advocatus Diaboli
Quoted: 4736 Post(s)
Liked 1,533 Times
why not likely? I'd think that for a straight walled hookless rim, the primary factor coming into play would be the profile of the tire bead. If a TL tire is super easy to mount on hooked, why not a correlation that it's too easily unmounted on hookless?
Anyway these are the 3 rim brands I mentioned. Pirelli is the only maker that appears in all 3.
cadex hookless non-approved
enve hookless not approved
zipp hookless
zipp hookless
#130
Quoted: 20810 Post(s)
Liked 9,456 Times
Pirelli themselves doesn't recommend any of the P-Zero Race 26mm or smaller for hookless use, this may be because of the ETRTO PSI recommendations, but that's just my speculation. Above 28mm and above is approved. That addresses two of your three. I don't know and don't care about the Cinturato, but many of their TL offering were pointedly designed to be hookless compatible, so your statement was patently false.
#131
Advocatus Diaboli
Liked 1,533 Times
#132
Liked 9,456 Times
Not exactly, I'm not going to paste all of the approved lists now, but at least for Enve and Cadex, Pirelli (wider than 26mm) does not appear on either. So Zipp is the only brand where you could assume Pirellis are ok for wider. So your statement that above 28mm is approved, is only inferred as correct for one of the 3 brands.
Your theory that 'tires not designed for hookless are easier to mount' is shot down by the fact that the P-Zeros were designed for hookless use whereas the GP5k, which has a reputation for being one of the most ornery tires to mount, is not approved for any hookless use.
#133
Advocatus Diaboli
Liked 1,533 Times
We've been over this before. You've got no skin in the game and only do half-assed research in the hopes of appearing to be well versed enough to **** on it. Approved lists are not comprehensive. I have hookless Zipps on my bike. I have Pirelli (among others) on my parts shelf.
And nice misquote of mine of something I never said. I basically postulated that if a TL tire, as in Pete's case, was found to be the all-time easiest tire he's ever had the pleasure of mounting -- maybe that could be an indicator of compatibility with hookless, given that brand does appear in some form on all 3 rim makers site.
#134
Liked 9,456 Times
Go ahead and provide your own half-assed research then. Or better yet, drop a line to some of these wheel makers and tell them that you've determined that they can add Pirelli to their approved lists because Pirelli marketing has said so. As for Conti 5k, it's only the 25mm that appear on unapproved lists. Like Pirelli, other widths are non-mentions (except CInturatos). I don't doubt that every tire hasn't been tested, but to claim wider Pirellis are approved while wider Conti 5ks are not, is currently an unsupported claim.
Anybody that's looked at hookless rims in earnest knows that GP5k are on the strict no-fly list.
And, uh, say what now?
And with that, I'm done with this idiocy. I just wish you'd stop trying to ply misinformation on subjects with which you have no personal, practical interest.
#135
Quoted: 4414 Post(s)
Liked 4,867 Times
Interesting in that, while you're not running hookless, Pirellis is pretty common denominator that their TL tire offerings are not ok with a number of hookless TL rim makers (eg. Enve, Zipp, Cadex (aka Giant). I wonder if there's a correlation between easy mounting for one type, and no good for another type?
#136
Advocatus Diaboli
Liked 1,533 Times
btw, I'm pretty sure Petehski's reference to Pirellis was indeed the Cinturato, since he's prior indicated he runs them on his Defy. This is the one tire on Enve's list that was tested and not approved in any width that it's offered in, so I think my premise that a correlation could exist is certainly possible.
#137
Liked 4,867 Times
show me a hookless approved list (as tested by the rim maker) that has Pirelli on it.
#138
Nope.
Always install toward the valve. Always remove away from the valve. Tubed or tubeless.
Likes For freetors:
#139
Liked 9,456 Times
#140
HIFI ...
You make up your own reality. The only tyres on the approved lists are the tyres on the approved list. The tyres not on the approved list are not on the approved list no matter the amount of mental gymnastics you exercise.
#141
Liked 9,456 Times
Yeah, sure. ETRTO be damned, amiright?
Likes For WhyFi:
#142
Liked 9,456 Times
zOMG! They're running tires that aren't explicitly on the 'approved' list at Roubaix!!!
Yeah, Conti has a new tubeless tire on the way, one that's hookless compatible to correct their mistake with the GP5K TL and it has the markings that hint that it's ETRTO compliant, much like most of the new high-performance TL tires introduced within the last 18 months or so. As such, it should be hunky dory with wheelsets that are also manufactured to conform with hookless ETRTO standards.
#143
Advocatus Diaboli
Liked 1,533 Times
Wouldn't surprise me to also see other mentioned tire makers doing v2 versions of some of their TL offerings.
#144
Quoted: 768 Post(s)
Liked 1,744 Times
just looking at that pic, I just don't understand the whole quark tire pressure gizmo , but then again, not a racer, so maybe there are some benefits there, but, meh
#145
Liked 9,456 Times
That's just for extreme tracking/tweaking of tire pressure to optimize for road surface. The primary thing of interest in the pic is that the Conti is on a hookless rim - they were the last manufacturer of significance to not have a hookless compliant, high-performance road tire.
#146
Liked 9,456 Times
Woof. In fitting with the the (supposed) thread subject, I just checked my sealant ahead of a destination ride tomorrow, and I was runnin' on empty up front and on fumes on the rear. I just added sealant less than 5 weeks ago, but it goes to show you that mileage can and will dramatically affect maintenance intervals. Often, I can get away with 6+ weeks before topping off, but in that five weeks since the last refresh, I put on something around 1300 miles, and it seems as if I've taken quite a few cuts that needed sealing over those miles.
#147
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Keep the chain tight!
#148
Quoted: 768 Post(s)
Liked 1,744 Times
I am surprised someone has not created a carbon fiber sealant dipstick for easy sealant checks, , or some kind of bluetooth based phone app electronic device
#149
Quoted: 383 Post(s)
Liked 690 Times
I had an oil furnace and the tank was rather large/deep. I needed a seven foot molding strip to serve as a dipstick. It was a 600 or so gallon tank.
#150
Liked 9,456 Times
I saw the other thread on needing to top off sealant. But your comment on a dipstick seems like a good place to jump in. How does one measure the amount of sealant or determine if a top off is needed? I gather you have to remove a valve core - you lose all the air?
Oh, one thing on using one of the above syringes - it seems like half of the valve stems out there have a narrow spot internally that blocks the syringe and keeps it from fully inserting, so you need to get valves that'll pass 'em. I use the MucOff lightweight aluminum stems - they're pretty easy to find, at least at shops around me.
Edit: PS - whether you're using a dipstick or syringe, your bike/wheels should be suspended in a stand. A few years back, a, uh... friend of mine... put his bike on the ground, deflated his tires, removed the cores, spun the valve to the 6 o'clock position and put the wheel back on the ground, at which point sealant came spewing though the stem an all over m- uh, his floor.
Likes For WhyFi:
