Help with and opinions about Shimano Front Freewheel System
Old 04-24-12, 10:01 PM
dedhed
SE Wis
dedhed's Avatar
Quoted: 2747 Post(s)
Liked 3,401 Times in 2,058 Posts
I just did a "fix up my bike from when I was a kid" Ross Eurosport with an Ashtabula FFS. I did take it apart and replace the bearings and use the better crankarm I had - wouldn't do that again. Bearing preload in the freewheel was set by different thickness shims and was a pain to set. I've heard you can use newer freewheels they just have more freewheel to it and extra slop to take up when going from coast to power. It didn't have positron so I gave it an upgrade to some low end suntour stuff rather than try to clean up a bunch of rusted parts. Added some alloy wheels from a donor too.
File Type: jpg
File Type: jpg
dedhed is offline
Old 04-25-12, 12:05 AM
Captain Blight
Captain Blight's Avatar
Bikes: -1973 Motobecane Mirage -197? Velosolex L'Etoile -'71 Raleigh Super Course
It's seriously cool to be able to shift while coasting. Mechanically, FFS has a couple good things gouing for it and if you think of it as a proto-Octalink system it starts looking better. The funky cones were an attempt to get the bearings further outboard. IMO the worst thing you can say about it is that it didn't sell and you probably don't want to use one with a coaster brake.
Captain Blight is offline
Old 04-25-12, 12:17 AM
poke em
For the casual rider, getting a toe caught somehow would mean certain amputation.
poke em is offline
Old 04-25-12, 05:30 AM
Esteban32696
Quoted: 8 Post(s)
I have owned a couple of those & everything worked well on them. I left them just as they were & sold the bikes, later. As long as it works fine, I would leave it as is.
Esteban32696 is offline
Old 04-25-12, 05:46 AM
TNDave
TNDave's Avatar
Bikes: 2008 Gary Fisher Monona, 1997 Univega Alpina 550, 1980 Nishiki International, 1993 Specialized Epic
I think I have decided to leave it as is and just drip some oil into the FFS to make sure it is lubed up good. The BB needs to be cleaned and re-packed so I am trying to figure out how to get to it with the FFS chainring. I have the cranks off and can't see/figure out how the chainring/FFS system comes off the spindle to allow me to service the BB.
It does seem pretty cool, and I'm looking forward to trying it out "for real" once the proper rear freewheel arrives courtesy of Cattywompus. I had heard they had some freewheeling in them to prevent getting toes cut off if the chain stops?
Thanks for all the info and advice, I'm getting kinda excited again about this bike and looking forward to riding it once I get it ready.
TNDave is offline
Old 04-25-12, 09:57 AM
mikeinroch
mikeinroch's Avatar
Bikes: 1982 Team Fuji, 1992 Nishiki Backroads, 1999 Diamondback Topanga SE
I had this same bike as a kid / younger man. Built like a tank. Weighed about as much as one too.
I used to occasionally get my shoelace caught in the chain. It would mangle the lace pretty good but never sever it, and it always stopped the chain, the friction freewheel at the back would do its thing. As long as your toes are tougher than shoelaces they should stay attached.
mikeinroch is offline
Old 04-25-12, 11:11 AM
shipwreck
shipwreck's Avatar
Quoted: 141 Post(s)
Liked 9 Times in 7 Posts
I have that bike, changed it to a non positron derailer, kept the FFW system, put some alloy wheels on it. I just lay it down and dribble some thirty weight into it from time to time. The rear cogs will spin if your pants leg gets caught, but not sure about a finger. I like to shift while walking the bike across a street, or lifting the rear and giving it a spin to downshift if caught at a light or something. Its a nice bike to ride around for coffee or light shopping. Would probably not want to do a ten mile commute, but thats just me. I figure that as long as it works I wont change it. If it ever breaks, I will put a different drivetrain on, then give it away or sell it. The FFW is the interesting thing that keeps it in my fleet.
shipwreck is offline
Old 04-25-12, 02:58 PM
jacksbike
Bikes: Trek 7.5 Hybrid, Trek 1.1 Road, Holdsworth touring,Raleigh International,Ritchey Commando,Italvega Speciallissimo,et.al.
Quoted: 23 Post(s)
Liked 11 Times in 11 Posts
My 2 cents: I sold a lot of these FFS/PPS equipped bikes from Schwinn, Raleigh , Pansonic and Ross. The upside was that they were virtually indestructible, bombproof, and perfect for folks that did not understand how to shift. You had chainguards on the crankset and on the freewheel, so it was impossible to derail the chain. Yes, the downside was that these bikes weighed a ton, and the parts were proprietary. Replacing the stiff rear shift wire is really not that difficult, and front freewheel/crankset problems were rare. You really want to avoid, like the plague, disassembling the bearings and freewheel for the front freewheeling system. As states, Shimano learned a lot about index shifting from this equipment, and went on to create systems that were a lot lighter and worked better.
jacksbike is offline
Old 04-25-12, 03:11 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1565 Post(s)
Liked 1,296 Times in 866 Posts
"You really want to avoid, like the plague, disassembling the bearings and freewheel for the front freewheeling system."
+10
So far I have yet to hear any suggestion on how to remove the FFS from the spindle, to allow a bb service, and was surprised to find that this wasn't an Ashtabula crank fitment or that the FFS wasn't part of a crankarm assembly.
A picture of the FFS w/o crankarm in the way might be helpful at this point.
Has anyone Googled this yet?
dddd is offline
Old 04-25-12, 05:34 PM
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times in 70 Posts
Point taken, but the rear freewheel would probably mitigate the damage to a mere laceration. I don't think there's any reason or likelihood that anyone would try to build a fixed rear cog with the FFS, so amputation is probably not an issue.
old's'cool is offline
Old 04-25-12, 06:37 PM
sailorbenjamin
sailorbenjamin's Avatar
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
Liked 12 Times in 12 Posts
I hear lawn mower throttle cable will work for shift cables.
My neighbor's FFS drive side crank is just cottered. Comes off like any cottered crank.
I helped him rebuild that bike last year. No issues, reliable and easy to work on. No need to open up the rear freewheel or the crank unit. He thinks it's fun.
sailorbenjamin is offline
Old 04-25-12, 06:56 PM
TNDave
TNDave's Avatar
+10
Both cranks come off with a 6mm bolt. I'll try to get the cranks off and take a picture later tonight and post it.
TNDave is offline
Old 04-25-12, 08:43 PM
TNDave
TNDave's Avatar
Got some pictures. The cranks come right off no problem with a 6mm attachment for my socket set. Then there was a cover plate that popped right off leaving this:
There are definitely holes there for a spanner (or a punch and hammer) but I DON'T know if this is to get the FFS off the spindle or if this opens the FFS up. I DON'T want to open up the FFS - not ready for that headache yet! I don't know if you grab ahold of the teeth with a tool or carefully with a wrench and just spin it off the spindle either.
Any ideas? I have not been able to find much online. Have found a guy that had to get the special Shimano "Boss" tool to remove the BB threaded cups, but didn't see any info/detail on how he got everything off to get to the BB.
File Type: jpg
File Type: jpg
TNDave is offline
Old 04-25-12, 09:42 PM
dddd
dddd's Avatar
If you loosened the bb adjustable cup 6 or 7 turns, and hammered the drive-side end of the spindle, perhaps this would have the same effect as "pulling" this FFS mechanism off of the spindle.
Perhaps then it is lightly pressed on a different (slightly larger-diameter) spline(?).
dddd is offline
Old 04-25-12, 10:57 PM
dedhed
SE Wis
dedhed's Avatar
I pulled it apart to swap in the better crank arm I had and replaced the bearings while I was at it. I have another Ashtabula one at work that I used for the donor crank arm, if I get a chance and find time I'll pull it apart and take pictures. I would never again pull apart the crank freewhweel.
dedhed is offline
Old 04-26-12, 12:24 AM
poke em
Hmm. The bike I rebuilt with FFS was a late 70's Schwinn Caliente and it was equipped with a fixed rear set of cogs. 5 speeds. It would chop a stick in half on the workstand.
poke em is offline
Old 04-26-12, 12:31 AM
dddd
dddd's Avatar
That donor crankarm looks like one of the fully-polished Schwinn cranks. Quite an improvement!
dddd is offline
Old 04-26-12, 06:42 AM
mikeinroch
mikeinroch's Avatar
They must have belatedly realized the danger in that, by the early eighties they were using "friction freewheels" at the rear - they had enough drag to keep the chain moving through a coasting shift but if the chain jammed on something (shoelace, cuff, body part...) they would spin. Startled me a bit first time it happened.
Old 04-26-12, 08:43 PM
old's'cool
curmudgineer
old's'cool's Avatar
Quoted: 263 Post(s)
Yikes! You mean the early FFS did not have a rear freewheel! Then again, that was the era of lawn darts (which I survived, for the better or worse, of society as a whole).
Shimano really missed an opportunity there. Instead of adding a rear freewheel to the FFS, they should have developed and introduced new drivetrains, for handicapped cyclists with various amputations (due to fixed rear/FFS). A growth market, if there ever was one. j/k
Old 04-27-12, 04:44 PM
dedhed
SE Wis
dedhed's Avatar
OK took some pictures today of the actual pawl internal mechanism. This is on a 1 pc crank unit.
It looks like the unit threads onto the crank arm spindle area. There is a removanle bearing race which is adjusted by different thickness shims, then a tabbed lock ring.
File Type: jpg
File Type: jpg
File Type: jpg
dedhed is offline
Old 04-27-12, 05:00 PM
Chombi
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times in 27 Posts
Seeing that pic, one wonders why Shimano bothered to use an Ashtabula crank with it. It kinda blunts the attempt at being "tech-forward" and cyclists had been running away from the "Astabulator" cranks when FFS was coming out.
Chombi
Chombi is offline
Old 04-27-12, 05:09 PM
dddd
dddd's Avatar
So then the non-ashtabula FFS unit is on a spline or there would have to be thin wrench flats behind the FFS to apply loosening torque to the inner hub of the FFS.
Have you tried to pull off the FFS by driving the spindle inward after loosening the adjustable cup? I'm almost certain now that it has to be pressed onto a spline.
Worst case will be that there are lugs for a freewheel puller type of tool hiding behind the FFS bearing cone, but I really doubt that the FFS cannot be removed intact from the spindle.
dddd is offline
Old 04-27-12, 06:12 PM
TNDave
TNDave's Avatar
I'll take a look at it tomorrow - I'll start from the non-drive side and see if loosening some of that gives it some play to look at, and/or trying to drive the spindle in.
Thanks for the tips!
TNDave is offline
Old 04-27-12, 06:23 PM
repechage
Quoted: 3464 Post(s)
Liked 2,831 Times in 1,997 Posts
Injured, yes, not as bad as you state. The rear cluster of a FFS equipped bike did come with a clutch, a very stiff freewheel that was designed as a safety feature of things went horribly wrong.
repechage is offline
Old 04-27-12, 06:49 PM
poke em
I was breaking sticks in half with my Schwinn Caliente, just to test it out. Just the inertia of a spinning rear wheel was enough on the workstand. Mine had a fixed 5 speed cluster, no clutch.
poke em is offline
