Addiction 2022.3
#2401
Quoted: 8281 Post(s)
Liked 9,052 Times
I used to go through these double tunnels often. There is rarely any car traffic but one time the fog was so thick I couldn't see the ground or the curbs. We got off and walked. I don't know the rider in the pic.
Likes For big john:
#2402
Silver Comet Fred
Bikes: 1
Quoted: 8840 Post(s)
Liked 2,988 Times
#2403
Liked 9,052 Times
Likes For big john:
#2404
Mostly Harmless
Bikes: Have two wheels
Quoted: 13714 Post(s)
Liked 4,531 Times
Likes For rjones28:
#2405
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12777 Post(s)
Liked 7,694 Times
I saw him perform at Gammage in the early '80s. No songs by The Doors were played.
Likes For LesterOfPuppets:
#2406
Quoted: 18420 Post(s)
Liked 15,564 Times
Tricky.
Wordle 409 4/6
Wordle 409 4/6
#2407
Quoted: 3361 Post(s)
Liked 3,638 Times
That's pretty much the same gearing I ran at 30x18. I had sliding dropouts though
#2408
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
I suspect the Chorus setup does not have the same problem. This seems to be a problem with SHIMANO shifters.
I know the pic looks dirty but that's because I included the black plastic extension on the ferule/cap of the housing when I installed the cable, it was all gooey so for the replacement I got rid of that. I don't think it was a big player in the process, however. I am willing to consider other cables but have very low expectations.
see below for pics of housing ends:
I had used the lower type end initially but now using the upper one.
We know you're thrifty and all, but use the top end Dura Ace polymer coated cables. That coating does a lot to reduce friction and will have your cables lasting much longer. You could even spray some Teflon dry lube into that end of the cable housing a few times before assembling the shift cable to add a little dry lubrication to the inside of the housing. A wet lube won't function the same and will add drag to your shifting.
#2409
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,927 Times
I actually do think this is a PTFE coated cable, it's the one that came with the R8000 groupset.
#2410
Bikes: 79 Trek 930 is back on the road, 80 Trek 414, 84 Schwinn Letour Luxe,87 Schwinn Prelude, 92 Schwinn Paramount PDG 5
Quoted: 3196 Post(s)
Liked 1,844 Times
Wordle 409 6/6
#2411
Liked 15,564 Times
#2412
Liked 1,844 Times
My long ago gf is a big George Winston fan .
#2413
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
#2414
Liked 8,927 Times
#2415
Liked 8,927 Times
I have a couple bolts that are a challenge to remove so I think I need a bolt extractor. These include the bolts to my cleats and the 4mm crankarm fixing bolts.
I don't see that Park Tools makes a bolt extractor. Any suggestions for a budget bolt extractor for bicycle-sized bolts?? Most of the ones on ScamBay seem to be designed for autos and are too big.
#2416
Liked 9,052 Times
Wordle 409 5/6
#2417
Quoted: 1400 Post(s)
Liked 1,882 Times
I honestly don't recall if that cable is a PTFE coated cable or not, but I have used those fancier cables in the past and I can say for my usage, it does not extend cable life.
you are riding too often - ride less
or go downtube shifters ... and even better when paired with 7spd or 6spd (double bonus)
#2418
Liked 1,882 Times
next similar series after Walking Dead ... Lost Tunnel People
#2419
Liked 9,052 Times
Are the crank bolts the Shimano style with 2 pinch bolts? Those are probably hardened bolts. Are they stripped? You might be able to pound a bigger Allen wrench in there, maybe an SAE size.
Cleat screws might need a good soaking with a penetrating oil. Are they Allen head or slotted? An impact driver might help if you can borrow one.
12 Piece Easy Out Small to Large Screw Extractor Kit Set Easy Out Screw Remover Set (Case Included): Other Products: Amazon.com: Tools & Home Improvement
#2420
Quoted: 9653 Post(s)
Liked 6,365 Times
#2421
Liked 1,882 Times
two thumbs up on George Wilson
any CD in particular recommended ?
( yes - still often listen to CD's lol )
#2422
Mostly Harmless
Liked 4,531 Times
#2423
Liked 6,365 Times
#2424
Liked 9,052 Times
#2425
Quoted: 365 Post(s)
Liked 122 Times
