Need New Shifter Cables
Just Pedaling
Bikes: YEP!
Quoted: 336 Post(s)
Liked 524 Times
https://www.ebay.com/itm/29506088377....c101112.m2109
If this link works, otherwise, there are lots of other sellers with the same cables and pricing. It states standard shipping, but the lemon seller actually uses Speedpack and I got my order in less than 2 weeks.
Likes For SpedFast:
Just Pedaling
Bikes: YEP!
Quoted: 336 Post(s)
Liked 524 Times
https://www.ebay.com/itm/36338701640...Cclp%3A2047675
Here's a link for shifter cables @$8.US for 10
Likes For SpedFast:
Quoted: 18386 Post(s)
Liked 4,520 Times
It has been a while since I've purchased shift cables. And, I don't remember having any issues with the old Nuovo Record shifters.
I did have to grind down the ends for using with my 11-speed Campy shifters.
I have a little diamond grinder from Harbor Freight (chainsaw sharpener) that I use for gently reducing something like the shifter cable slightly. I've found it to be quite handy, even if it doesn't have a tool rest.
I usually buy in bulk.
I only purchase stainless now.
Campy shift Cables: $2.80 each for 10 pack.
https://www.ebay.com/itm/224088459389
Shimano (oversized) shift cables: $0.90 each for 10 pack.
https://www.ebay.com/itm/384105255246
https://www.ebay.com/itm/363387016401
Likes For CliffordK:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3893 Post(s)
Liked 6,492 Times
Searching "10" next time. Thanks for the links!
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 636 Times
Fibrax make a gear cable that works just fine with Campagnolo , Simplex levers with the sligthly smaller than Shimano end .
NO filing needed !
I bought a boxfull a while back ( 100 )
The Fibrax number for a box is FCG3102
If you can find a stockist they would have singles ?
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 647 Times
FWIW, I've converted standard "in-line barrel" cable ends to functional Huret disc-type cable ends by squeezing the barrel in a vise until it fits into the slot on the Huret shifter. Often, a little touch-up with a file is needed to get the proper fit. It seldom takes more than a couple of minutes altogether to modify the cable end.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
My thanks to everyone.
One issue I'm having with the links you've helpfully provided is I do not use ebay, at all.
With your help, I bought a kit via Amazon. It has all 4 cables (2 brake & 2 shifter), for $30. It seems steep but the cables would otherwise be $10 each, so I "saved" $10.
The kit comes with two different types of housing - LEX-SL L3 Cable Housing - LEX Reinforced, L3 Slick Lubed Liner and CGX L3 Low Compression Housing - CGX Reinforced, L3 Slick Lubed Liner, BLACK color.
I'll need an engineering PhD to understand the difference and figure out which housing goes where.
Quoted: 3519 Post(s)
Liked 2,932 Times
I can’t help you with the housing nomenclature from that particular vendor, but I can’t recommend compressionless brake housing highly enough.
Bikes: a couple
Quoted: 563 Post(s)
Liked 863 Times
Any port in a storm?
Last cable set I bought was this one. It came with stainless cables and really decent shift housing. All the housing brake and shift was lined. for 10 bucks you could do worse.
https://www.walmart.com/ip/Huffy-Bik...-Set/605952726
