Braking Techniques
#51
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
Actually the LBS when I was a kid told me to use the rear brake first, as a "backup" to the front brake to avoid going over the bars. I think most people ride like this, which is part of the reason why I think people have a tendency to overuse the back brake when sh*t hits the fan and aren't used to slamming the front brake without the back.
#53
Expired Member
Quoted: 3675 Post(s)
Liked 5,441 Times
My first thought was to be concerned that you were giving out stupid dangerous advice. Then I realized the number of folks asking for "Larry Cycling" advice is zero. Rumor has it promoting wrong riding was one of the things that got the other one removed. We can only hope.... Edit- referring to the other prolific troll who disappeared. AFAIK there is only one "Larry" though it's likely other user names stem from the same source.
Likes For shelbyfv:
#54
Should Be More Popular
Quoted: 22601 Post(s)
Liked 8,928 Times
#55
Klaatu..Verata..Necktie?
Quoted: 10441 Post(s)
Liked 11,914 Times
If there were two of you,
Or, God forbid, a few or you,
Too much is what it would be!
Likes For genejockey:
#56
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1949 Post(s)
Liked 1,473 Times
#57
Liked 11,914 Times
"But that was yesterday!"
#58
But to the moral lesson of story is avoid getting yourself in situations where you need to emergency brake in the first place. Practice your crash rolling skills but don't crash in the first place.
I won't recommend practice hard braking where your rear wheel is about to lift off because it might actually end up lifting off. Older riders might even break a bone.
#59
Quoted: 850 Post(s)
Liked 344 Times
Practice your stopping. If you're afraid of falling, you can do it with flat pedals and a lowered saddle. It's really not that bad. Just remember to let go of the front brake if you feel yourself flipping. You have more time than you think.
Likes For smashndash:
#60
Eh. If you're doing any sort of performance riding, you should know what the limit of your stopping power is. I've had to emergency stop a few times. A couple times in races, once to avoid a head-on with an SUV.
#61
Quoted: 1083 Post(s)
Liked 687 Times
When I learned to ride a motorcycle, I was taught that you ALWAYS use both front and rear brakes together, even if you're just slowing down or braking gently. That's because you want to have the muscle memory of applying both, when you actually do have to stop suddenly. You don't want to have to "remember" anything. The other thing I was taught is to actually practice your panic stops. You need to know how you and the bike respond under hard braking, and how to apply proper modulation between front and rear brakes.
I've always applied this to bicycles. Even if I just want to slow down a little, I use both brakes. Then when I have to stop suddenly, that's what I'm going to do naturally. And because I do practice sudden stopping, I understand how my bike handles and what the limits are. I practice again whenever I change anything, like brake pads. A lot of the practice is getting used to the way your body weight shifts forward during hard braking and how to maintain control when that happens. A lot of people aren't prepared for that weight shift, and crash.
This "front brake only" thing is maybe for people that aren't skilled riders or who have cheap brakes with poor modulation. If you want to fool around and practice front-only braking just to see what those limits are, fine. But for maximum stopping and minimum stopping distance, learn to use both front and rear, and of course practice.
#62
Liked 8,928 Times
The OP does not have a back brake (at least that's what he said in post #1), which I think is not so good and not so reasonable. But it's his choice.
Likes For Zaskar:
#64
Quoted: 4260 Post(s)
Liked 1,364 Times
And, even still, motorcycles have some of the same braking dynamics as bicycles.
https://bigapplemotorcycleschool.com...ing%20at%20all!
https://www.bestbeginnermotorcycles....-a-motorcycle/
On a bicycle, at the fastest braking (braking at the limits), the rear brake is doing very little and it's easy to lock/skid (there's enough info about this from experts).
The issue isn't "just using the front brake". It's what you do at the limit with the rear brake doesn't matter very much.
If you are below the limit, the rear brake does more in stopping (but the front brake is still much more effective). But you still have to take care not to lock the rear brake (this, contrary to some people here, is easy to do).
Most people rarely (if ever) are braking their bicycles at the limit. It's all they know.
Likes For njkayaker:
#65
Quoted: 850 Post(s)
Liked 344 Times
There's a lot of hoopla in this thread about theory. All I was trying to say is that the best thing you can do is practice and develop that muscle memory. Being able to drop anchor without panicking is far more important than the specifics of your technique.
#66
Quoted: 29 Post(s)
Liked 9 Times
After reading this thread, I started stopping only with my front brake(road riding). Did I stop in a shorter distance? Probably but I got the dreaded rotor ping and a ton of front tire compression/fork bend affecting handling/steering. Also, if you MTB you're going to learn bad habits that will kill you.
#67
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
At max braking under ideal conditions there is approximately zero input from the rear brake. There is an argument to be made that, at least when beginning to brake from speed you should use both brakes, and the rear brake is certainly useful on loose surfaces esp. when cornering, but if you need to immediately 'drop the anchor' on a hard surface then the front does all or almost all of the braking.
you can definitely stop faster using both brakes, provided your weight is distributed correctly. Push your weight way back, i.e. butt over rear wheel, torso pressing on the seat, and you can have the front brake at the threshold of lock up, and enough traction on the rear wheel to add significant braking force from the rear tire.
your ability to slow the bike is limited by the size of the contact patch with the road, and the coefficient of friction of that contact area. Twice the contact patch is better
this CGN video demonstrates:
You could get lost and die.
You could hit a tree and die.
#68
When I went to motorcycle race school we were told that none of us are good enough to touch the rear brake.
On a modern sport motorcycle there’s enough braking power to get the rear wheel in the air with two fingers so you’re not getting extra stopping power from the rear brake. You’re getting different braking, drag the rear brake to compress the front suspension before putting the fronts on so you dive less, upsetting the back end so you can back it in, etc. But all this assumes you have suspension and since this is the road bike forum not very applicable.
So while some fancy people may be able to optimize braking by simultaneously shifting their weight max aft while perfectly modulating their front brake lever so the rear tire is skimming above the ground (MotoGP riders do this routinely) I certainly cannot.
So given that the front brakes on a bicycle (to me at least) don't feel so over powered that I could easily find and control the point of lifting the rear, nevermind controlling the lever that precisely while dangling my ass in mid air behind the saddle, I’m always going to get at least some benefit from applying the rear brake as well.
The road ain’t exactly lab conditions and I'm no Tour rider, so the theory of the front brake generating all the stopping power is true for the few, but not for most!
