Short Cage on a Triple - Check My Derailleur Math
#101
Thanks for the suggestion. I don't believe that would get the job done however. By my math, I need to shed 4T for the capacity to work out by the book, without relying on the 2T extra capacity that some folks say is built into Shimano derailleurs. My second cassette cog is 24T which barely gets that job done coming down from the 28T at the top.
#102
I recently bought the only two decent, NOS 7-speed cassettes that I could find on eBay for a price that I was happy with. HG-50-7. I'm pretty committed to using them so I'd not be changing gearing unless it's a simpler/cheaper thing to find alternate cogs than I've been imagining.
#103
I do already have an expensive new Sugino crankset in hand although I probably could find an alternate big ring for it. I like the idea but I'd probably just cave and use a long cage derailleur before executing that.
#104
Likes For Harold74:
#105
Quoted: 405 Post(s)
Liked 430 Times
I'd say the best hack is a combination of your original hack and the smaller big ring hack.
Swap the 48 for a 46.
Size chain for the 46/28.
Don't ride in the granny on smaller cogs. Which you'd never do intentionally, because on just about every road triple I've ever seen, any cog smaller than #3 on the granny is a duplicate gear, and feels like garbage anyway. And if you land in one of those gears by accident, say by upshifting the rear when you wanted the front, you won't crash or break your bike.
Set up this way, (which is definitely a hack,) you're only exceeding chainwrap by two teeth in the gears you're actually going to use. Good gear range, good shifting, and you get to keep your short cage rear derailleur... what's not to like?
And, hell... if you're not exceeding some specs, are you really hacking?
--Shannon
PS: Detailed descriptions of your hack, both on the stand and on the road, with pictures, are required for all bike hacks.
--Shannon
#106
Quoted: 1324 Post(s)
Liked 927 Times
I've just remembered something that I did decades ago to get a slightly larger rear cog to work with a derailleur. I took out the B-screw and put it in form the opposite side. I'm not sure if I used the original B-screw or if I used a front derailleur adjusting screw that was longer. What it did do as move the upper pulley of the derailleur further away from the cogs. This was before index shifting and I don't think it affect the shifting much.
Cheers
Cheers
#107
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Cheers
Cheers
Personally, I like to go the other direction regarding the B-screw: dial it out, and often remove it entirely for more chain wrap angle around the cogs.
