Off Brand (Way Off) Question
Old 11-11-22, 10:55 AM
  #51
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
Liked 522 Times in 348 Posts
Originally Posted by Milton Keynes
Yeah, that's what I want to do, spend a lot of time having to replace my cassette/freewheel because the chain wore off the teeth. Maybe you should carry an extra one or two along with you on your bike so you can change it on the side of the road after it fails...
If it takes you a lot of time to simply swap out a cassette, you're missing the finer art of owning a bike, unless you're just savoring the experience. On the other hand, maybe I should be looking for a 'cheap' trailer to tow behind so I can carry all my 'cheap' parts with when I go riding because surely they're all going to fail.
SpedFast is offline
Old 11-11-22, 10:57 AM
  #52
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
I went ahead and ordered one, I'll post back here in the far distant future and let everyone know how it is.
SpedFast is offline
Likes For SpedFast:
Old 11-11-22, 01:28 PM
  #53
philbob57
Quoted: 715 Post(s)
Liked 613 Times in 377 Posts
It'll be great. Vendor has 99.2% positive feedback.
philbob57 is offline
Likes For philbob57:
Old 11-11-22, 03:40 PM
  #54
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
https://www.ebay.com/itm/175122659037?var=474310290974
Here's another good deal that I couldn't pass up. I reuse my links (a lot) until they don't 'snap' any longer because I rotate and wax my chains almost every 2 weeks because of the miles I put on them. Just can't resist a bargain for the parts bin.
If anyone has a good source of inexpensive 11spd chains, please share it. Thanks, Smokey
SpedFast is offline
Old 11-11-22, 09:51 PM
  #55
Jan Feetz
de oranje
Jan Feetz's Avatar
Bikes: ItalVega, Guerciotti SLX, Litespeed T1, Oma Fiets
Quoted: 33 Post(s)
Liked 24 Times in 18 Posts
I will to add to my arsenal......
Jan Feetz is offline
Likes For Jan Feetz:
Old 11-12-22, 08:02 AM
  #56
Miele Man
Quoted: 1324 Post(s)
Liked 927 Times in 640 Posts
I love that the ad calls a cassette a "Flywheel" and calls cogs "Discs".
How long will a carbon steel quick link last?
Cheers
Miele Man is offline
Old 11-12-22, 10:48 AM
  #57
Milton Keynes
Milton Keynes's Avatar
Quoted: 2281 Post(s)
Liked 1,710 Times in 936 Posts
It's not that it takes a lot of time swapping out one cassette, but just the hassle of having to swap them out often because they keep getting chewed up by the chain. I'd rather be riding my bike than having to do a bunch of unnecessary maintenance on it.
Milton Keynes is offline
Likes For Milton Keynes:
Old 11-12-22, 02:23 PM
  #58
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
Then we agree on something, because I don't like unnecessary maintenance either, but ONLY when it interferes with my riding.
SpedFast is offline
Old 11-17-22, 09:35 AM
  #59
Lombard
Sock Puppet
Lombard's Avatar
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times in 573 Posts
Nope.
Lombard is offline
Old 11-17-22, 09:53 AM
  #60
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
I've been running cheapo Chinese cassettes on our tandem for a long time, not ebay but Amazon, probably no difference. They've worked out fine, haven't worn faster than anything else, shift fine, etc. For that money I'd try one. As said above, it takes like 15' to swap out a cassette. If it works out fine, you made good wages. I dunno. My cassettes never get chewed up by the chain. They mostly work fine. True, they do wear but over thousands of miles. Nabobs of negativity.
Results matter
Carbonfiberboy is offline
Likes For Carbonfiberboy:
Old 11-17-22, 09:56 AM
  #61
sjanzeir
BF's Resident Dumbass
sjanzeir's Avatar
Bikes: 1990 Raleigh Flyer (size 21"); 2014 Trek 7.6 FX (size 15"); 2014 Trek 7.6 FX (size 17.5"); 2019 Dahon Mu D9; 2020 Dahon Hemingway D9
Quoted: 792 Post(s)
Liked 1,494 Times in 496 Posts
Originally Posted by 70sSanO
“High quality:Made of high quality steel, anti-corrosive, good heat resistance, do not worry about the long-term use of friction heat, affecting its life.
No noise:This freewheel characterized by smooth rotation without much noise, high precision internal thread, ensure close connection with bicycle hub, smooth operation.
Accurate shifting:The effect of the guide chain is accurate, allowing smooth riding and accurate shifting.
Easy to clean&maintain:It adopts the design of chain guide groove and mud drain hole. The design of the chain guide slot makes the speed change more sensitive, and the mud drain hole is easier to clean and rarely get grubbed up on the inside.
Application:This kind of flywheel is one of the most durable and long-lasting flywheels of multi-speed bicycles.Suitable for mountain bikes and folding bicycles,road bikes ,city bikes,and so on.”
If the English copy I wrote way back when I started off my career fresh out of college in 1997 was this bad, my life probably would've been very different today.
sjanzeir is offline
Old 11-17-22, 09:59 AM
  #62
Trakhak
Trakhak's Avatar
Quoted: 2482 Post(s)
Liked 2,955 Times in 1,678 Posts
Liked for the apposite Agnew quotation.
Trakhak is offline
Old 11-17-22, 10:04 AM
  #63
Carbonfiberboy
Liked for vocabulary - and good memory.
Results matter
Old 11-18-22, 01:15 PM
  #64
SpedFast
Just Pedaling
SpedFast's Avatar
Bikes: YEP!
Quoted: 334 Post(s)
The cassette arrived today and I have to say I'm quite impressed. Yes, it is an 11spd and came with all the loose parts pictured. The 9 smaller cogs are screwed together with Phillips head screws, not riveted like most cheap cassettes and freewheels so you could take it apart and replace individual gears if needed. I wrapped an 11spd chain around it and the fit seems good. I'll report again on the shifting at some point in the future. For 9 bucks and free delivery I feel like I scored. Smokey
SpedFast is offline
Likes For SpedFast:
Old 11-18-22, 03:44 PM
  #65
Koyote
Quoted: 6963 Post(s)
Liked 10,963 Times in 4,688 Posts
You might want to make sure they put threadlocker on those screws.
Koyote is offline
Likes For Koyote:
Old 11-18-22, 09:36 PM
  #66
rosefarts
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times in 490 Posts
So I’ve mentioned this before. I’ll do it again.
Almost everything on your bike is made in China.
However, they are able to make items for a certain price point. Even using the same factory sometimes.
Sometimes it doesn’t matter. I got a bunch of $1 Lithium batteries for a camera years ago that were 100% as good as the $40 ones the thing came with. Other times, it’s total junk, as stories in this thread have mentioned.
That extra money is quality control.
$9 vs $40 just isn’t an issue for me, since I’d only be needing one. For others, this might be a totally different equation.
rosefarts is offline
Old 11-18-22, 09:46 PM
  #67
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1562 Post(s)
Liked 1,734 Times in 974 Posts
Even if you left out those screws the cassette would function perfectly fine.
icemilkcoffee is offline
Likes For icemilkcoffee:
Old 11-18-22, 09:58 PM
  #68
Koyote
Yeah, good point. Get that lockring torqued down sufficiently and it should be fine.
Koyote is offline
Likes For Koyote:
