Show us your Cinelli! Lots of pics! :)
#76
There may have been others.
#77
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,410 Times
Mystery solved. Turns out the pictured frame was made in 1990 and was likely a Mens Sana before the Spectrum restoration work. I also own another Mens Sana and the serial number on it indicates it was made in 1991. Which kind of makes the information published elsewhere that the Mens Sana bikes were only made in 1989 less than fully accurate.
Still, both are lovely bikes to ride. Kind of wish my 1980 SR group was on a 1980 frame, though...
#78
I'm fairly certain that all the information on the Mens Sana Corpore Sano came from this one blog post:
Cinelli Only: Mens Sana In Corpore Sano
#79
My late 1977 SC. The bike was custom-built for the original owner after Cino took his measurements. The bike was built up like Cino wanted since the owner said that he would accept whatever Cino thought was appropriate. Many seemingly unique features on what must certainly be one of the very last frames where Cino was personally involved in the build process. This is NOT a stock frame, nor a stock build.
Radial front wheel built with special "ridotto" rims and early Phil Wood hubs (Cino was the distributor for Italy of Phil Wood parts.) Frame built for 175 mm cranks (came with two sets of pedals: one set of Campagnolo Superleggeri and another set of Cinelli M71's). First generation 1R stem. Chainset with light drillium treatment. Universal brakes (the model had just come out in 1977). It also has a proper Super Record twin bolt seatpost, not the later Nuovo Super Record seatpost with single bolt.
Since it is far too small for me, I have often thought of selling it but then always change my mind.
#80
Quoted: 12 Post(s)
Liked 7 Times
My 1978 Cinelli SC; I was running it with modern clinchers but decided to overhaul the original wheelset and I'll be running it like this this year--just waiting on an overhauled Regina freewheel (I'll just stash the original--along with the original seatpost, toe cages, straps, handlebar tape, tires and cables) and rubber.
#81
Bikes: 2014 Cinelli Experience, 1995 Carrera Podium, 1984 Kuwahara Pulsar, 1982 Murray MTN. Bike
Here is my 2014 Cinelli Experience Veloce
It's a European spec bike, I got it in Ireland, the setup is different from what was available back in 2014 here state side.
Compagnolo Veloce group set with Miche wheels, crank, and breaks make for a nice setup which keeps it all Italian.
#82
I'll add my late '77 63cm SC to the mix....New silver compact bars are on the way to replace the black B-Grooves!
#83
Bikes: ’71 Cinelli SC;‘ 72 Cinelli SC ; 2011 Baum Corretto Ti; 2007 BMC SLC01; 1986 Pinarello Team Bike; 1983 De Rosa Professional; 1959 Bianchi TdF; ’78 Masi GC Ca
Quoted: 15 Post(s)
#85
But internal brake cable routing didn't exists on Cinelli SC in 1971. If it's not the mod you are referring to. The very early ones had it (like 50s), then the design changed. It didn't come back until much later, don't have the date now. Someone else here can probably fill in.
#86
Quoted: 378 Post(s)
Liked 1,410 Times
Beautiful. I've been looking at the new black ones....
#87
Quoted: 15 Post(s)
Nice!!
#88
Quoted: 15 Post(s)
#90
Quoted: 79 Post(s)
2016 bump!
What is the widest tire that folks are running on their Supercorsas? I am reasonably confident 700x25 will fit but am unsure of 700x27 (e.g., Vittoria Open Pave). Thoughts?
#91
enginerd
I'm running 25mm Michelins on my Neuron SC. They measure closer to 27mm and fit fine.
#92
Quoted: 2588 Post(s)
Liked 4,826 Times
My circa '83 Supercorsa shortly after I bought it around 2003 from Recycled Cycles in Seattle:
I sold it frame-only on Ebay some years ago. Why? Interestingly enough, it just didn't do anything for me. It was the heaviest bike I owned, too - by far. I have no idea why. However, would I own another? Sure - I'd like to know if mine had some sort of issue or something...
DD
DD
#97
Liked 4,826 Times
Here's a pic of it in its show form with a Concor saddle:
DD
#98
Quoted: 79 Post(s)
I think there is still room for 700x27 Open Paves, though they might introduce toe clip overlap (I am pretty close right now).
#99
Bikes: 2006 Bianchi Pista Concept, 1994 Pinarello Gavia, 1984 Bridgestone 300 Mixte, 1990 Trek Multitrack 750, 1989 Trek Singletrack, 1980s Bottechia Professional, 1984 Nishiki Prestige
Greetings to the Tiramisu owner. I'm curious about this bike, going to look at a used one tomorrow that seems really similar. Can't find much online about them. Did you keep it? Alter it? Any idea what they are worth? From the miserable photo the seller posted on CL it looks really similar, tons of decals, Cinelli saddle, Sachs drivetrain and hubs, etc.
Thanks!
[QUOTE=ItsTimeToBike;17151265]I purchased this early this season and its been simmering till I decide what to do with it. I doubt it has collector value but then again it could be rare enough to keep unaltered in good shape. I'd be interested in hearing from anyone with info on this model. Original owner said all his buddies bought Stumpies and he bought this. Think he stood out a little?
Thanks!
