I got a good deal for an old Rockhopper :)
Quoted: 1119 Post(s)
Liked 2,255 Times
It's 1990 which is the only year they did that outlined Specialized lettering on the top tube. Also the base model Rockhopper that year came in black and was equipped with M400 stuff.
Congrats on the acquisition- I have a Sport and a Comp from '93.
Likes For Clang:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
That is a great deal! One of my two bikes is a slightly older (late 80s) RockHopper. I got most of a bike for $50 about five years ago. At this point I’ve pretty much rebuilt the bike fron the frame up and it’s a great ride. It even taught the care and feeding of a U-brake, which I hadn’t seen before. Enjoy yours! Here’s a pretty recent shot of mine…
Otto
Otto
Likes For ofajen:
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
Did the serial was helpful or just for a few details you got the exact year?
Quoted: 333 Post(s)
Liked 168 Times
Otto
Otto
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
Is it cleaned up? Can we see?
Edumacator
Quoted: 2441 Post(s)
Liked 3,136 Times
I’m with most of the crew here. Plop a new saddle, pedals if you wish, and cables. Use a gentle polish and the paint will look brand new.
if the bars are Specialized pearl chromoly you can get the rust off easily. Bar keeps friend maybe. Careful with tin foil method on those...ask me how I know...
Check the pads. if the pads are worn, Dia Compe has Cantipads you can get for 8-10 bucks and they are actually very good.
There is a good seller on eBay that has Jagwire kits for around $16-18 if you wish to bling it up a bit.
Then have fun.
I think RSX brifters would work if you go drop bar...if bar ends, lots of options.
Then have fun.
Likes For jdawginsc:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
It also ate a nice RM20 rim in that time, oh well. It. stopped. fine.
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
U brakes take a lot of flack but I went all 'Marquis de Sade' on a DX version for 4 years in deep, salty, winter commuting and it just needed flushing when the the crud froze into every crevice. A few pad adjustments/replacements too.
But overall the brakes just work. In five years and 20+K miles, I’ve only had to pull and lube one of the arms. The other thing is they are more fussy when running SS because if you change gearing, the horizontal dropout means the axle moves the rim closer or farther from the brake pads.
Otto
Likes For CrowSeph:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Thanks! Clearly, I can’t criticize anyone for putting new parts on an old MTB frame!
First I don’t like straight bars at all. Also, I didn’t want the wide Q factor so I swapped in old road cranks.
Ran it first as a drop bar 1x but eventually decided to run SS and then found the drop bars didn’t give enough width, control and climbing leverage, so I switched to the touring bars.
Finally, I like really good tires. I wore out a set of Compass (RH) RTPs but found them hard to deal with so I replaced them first with Contact Speed 26x2.0 and now have a Race King in front and a Speed King in back which is just about perfect for our local trails.
Otto
Otto
Likes For ofajen:
Likes For CrowSeph:
Happy banana slug
Liked 1,530 Times
Quoted: 333 Post(s)
Liked 168 Times
Very nice! I can't quite tell; is it black, or very dark blue?
This has some good tips for shining up your bike:
https://www.youtube.com/watch?v=C4n2S7-SC4Q
Happy banana slug
Liked 1,530 Times
Quoted: 333 Post(s)
Liked 168 Times
It really did. FYI, he's since converted it back to flat bar and, shockingly, had fun taking it on trails.
https://www.youtube.com/watch?v=QXrirAI3vEA
About the flat bar video is interesting because he said a shorter stem will improve the bike handlings since the bike geometry is too long. For me the stock stem will help distributes the body weight and help climbing with the posture but a shorter stem will totally change the bike overall.
Happy banana slug
Liked 1,530 Times
Yea i saw that video too.
Likes For Korina:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
I think it depends on your proportions; in the early-ish '90s everyone went to a longer top tube for stability going downhill; add a long stem and drops, and you need gorilla arms to ride the thing comfortably. Also, I despise flat bars with a burning hatred; they're great for bombing down hills, what they were designed for, but not for actual riding. I much prefer swept bars for the more natural shoulder/elbow/wrist position. YMMV, of course.
I really like the combination of the North Road style touring bar with a 150mm stem. The forward bend is about like the hoods position on a road bike, but the bars come back just behind the steering axis, a great reach for keeping your weight back and maneuvering, hard climbing in the saddle or easy cruising, depending on the need.
Otto
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
However, I’m always riding it on one of our local trails and while they are fairly tame, it’s just a happier time for me with my touring bar rig. The brakes are easier to deal with using flat bar levers.
And once you go SS, it’s very nice to have the much more comfortable and useful bar locations for riding out of the saddle. YMMV.
Otto
Likes For ofajen:
Quoted: 333 Post(s)
Liked 168 Times
Swept bar , touring and other bars that let your back more straight definitely are comfy but for me kills all the aesthetic. Meanwhile a riser bar and a dropbar change the look in a better way. A already tried a riser bar but is in aluminum (that bar came up from a folding bike, on that bike i swap with a flat bar for a more low position since the stem can't be lowered, but looks kinda fragile since is very thin and as already mentioned in aluminum too).
i found very nice as aesthetic the bullmoosebar , but as comfort improvement is still the same, but the problem with that bar is that i must add a cable hanger for cantilever, and also adding a 800grams bat seems quite wrong since the bike is already not feather light.
for now I'll clean the original and repaint to make it looks new since i don't think only cleaning the rust spots will leave the bar perfect.
Quoted: 333 Post(s)
Liked 168 Times
I love it
Happy banana slug
Liked 1,530 Times
Likes For Korina:
Quoted: 333 Post(s)
Liked 168 Times
The most damaged area is the fork...
Ps. During the crankset clearing ,when I removed the chainring some pieces felt. There was some little spacers on the crankset's bolts. Are those very necessary? May i have lost a few 🤣
Quoted: 333 Post(s)
Liked 168 Times
Bike is nearly completed , i still had to clear the brake calipers and the front mech and restoring the saddle. Everything else is completed and mounted.
I had a few parts standing by , those skewers are definitely not vintage but i like how they fit. I already ordered a few colored crank bolts to add a bit of details there and here.
Also I customized a bag , the logo may not be super precise since is handmade but is another detail that I'm proud.
What do you guys think?
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
I'm loving this project every second more i spent during the rebuild. But is not perfect as may appear.
If you assemble everything, and everything stays tight, and there is no play in the rings, "probably" OK. (consider that free advice on the internets....)
I've received three free RockHoppers (one complete, one frameset, and the latest in a state of disrepair).
The first was all stock - a 60cm top tube with a REALLY long flat stem, just not gonna happen. So I went drop bar and riser stem to start. Then switched to Jones-risers. Very swept back, but pretty good for camping/touring/commuting/kicking around
- the drop bar mod
- approx. current set up with Jones bars
the riser stem was the first comfort mod.
- the freebie, spring project
That dark purple version cracked around the bottom bracket, which is when a friend gifted me his light purple version same size as mine. And I moved the parts over.
Quoted: 333 Post(s)
Liked 168 Times
- possibly the previous owner added spacers because the chain ring bolts were not achieving a clamp force when the bolts were tightened. Kind of the fasteners were bottoming out and the bolts were still spinning around.
- the drop bar mod
- the drop bar mod
Likes For CrowSeph:
