Rear facing safety lights. Red or White ?
#101
Quoted: 4260 Post(s)
Liked 1,364 Times
Whut??
Drivers don't seem to have much trouble judging the distance because, where it matters, their headlights work for that.
The point of flashing lights is to be recognized as a cyclist from a far distance.
Likes For njkayaker:
#102
Quoted: 3450 Post(s)
Liked 420 Times
Just to throw this conversation off on a tangent.
For LEGAL reasons in Australia, Don't ever remove the standard red rear facing reflector, the front facing white reflector, the orange wheel reflectors and likely the orange pedal reflectors from your bike.
This isn't necessarily for safety reasons so much as if a car hits you while cycling and you don't have a full compliment of reflectors, then a good (wicked) lawyer can get the driver off the charges because of your lack of reflectors.
Additional lights DON'T count on their own.
Don't remove standard reflectors from a new bike. Make sure you ADD reflectors to any custom build that you intend to use for recreation or commuting. The Law is an ass.
If you ride a competition bike on the road without reflectors then you're taking a chance.
#103
Quoted: 7653 Post(s)
Liked 3,483 Times
However, the flashing light tends to grab more attention because the brain associates a flashing light with motion and motion with threat (or food.) Also a solid light seen at a distance, when growth is slow, can as @njkayaker nots, be mistaken for a static roadside light, like a light or a reflector on a mailbox.
Whatever ... follow local laws, I guess, particularly in Germany or Australia, it seems ....
Likes For Maelochs:
#104
#105
#106
Liked 1,364 Times
It is harder to judge closing speed (which is how one judges distance while approaching) if the light flashes because each flash registers as a discrete event in the brain. A solid light will visibly grow in size and brightness and the brain can more easily make comparisons over time.
Even so, there doesn't seem to be any real issue with drivers dealing with cyclists with flashing lights.
Where drivers really need to judge distance, they are close enough to see the rider in their headlights (and the rider should probably be using reflective material and, maybe, even an additional solid light to help with that).
It's also hard to estimate the distance of small point lights that are far away, So, using solid small lights have the same problem you think only flashing lights do.
It's really uncommon to have small flashing red lights be used by anything other than cyclists.
#107
Driving in to work this morning, I passed a bike going the other way, and it had the very largest and brightest headlight I'd ever seen. From a distance I'd assumed it was a motorcycle!
A couple thoughts:
-What kind of headlight was it? I don't ride at night but if I did, this is the light I'd want.
-If the headlight was mounted on the rear of the bike and the guy was on my side of the street, I'd have been inclined to swerve out of the way to avoid a potential head-on with a motorcycle.
A couple thoughts:
#108
Quoted: 381 Post(s)
Liked 145 Times
If you ride a competition bike on the road without reflectors then your taking a chance.
#110
A couple thoughts:
A couple thoughts:
Likes For subgrade:
#111
Quote:
8-1592. Lamps, brakes and other equipment on bicycles.
(Light/lamp visibility specifications)
(a) Every bicycle when in use at nighttime shall be equipped with a lamp on the front which shall emit a white light visible from a distance of at least five hundred (500) feet to the front and with a red reflector on the rear of a type approved by the secretary of transportation which shall be visible from all distances from one hundred (100) feet to six hundred (600) feet to the rear when directly in front of lawful lower beams of head lamps on a motor vehicle. A lamp emitting a red light visible from a distance of five hundred (500) feet to the rear may be used in addition to the red reflector.
500 feet. roughly a tenth of a mile.
at 60mph, the car will reach you in six seconds (well, a bit longer if you're also moving.) Not a heck of a lot of time from the initial 'WTF is that', to recognition that it is a bicycle in the road, to muscle input and vehicle reaction.... I'd prefer to be seen from a greater distance... So I feel that anything I can do to grab a driver's attention is a good thing!
Then we get to people that walk in rural unlit areas... Here in Ohio, one is supposed to walk facing traffic, yet I see some people walking with traffic, dressed in dark colors at night... Seems like a Darwinesque way to go through Life...
#112
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Likes For GlennR:
#113
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2589 Post(s)
Liked 5,650 Times
A couple thoughts:
A couple thoughts:
PS it had a focused beam. More focused than the rider.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
#114
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
Peds with lights is getting more common, with cheap stuff available I guess. Attached to ankles and shoes.
I suppose it also has a neato cool dimension. They are putting them on dogs too.
Likes For GamblerGORD53:
#115
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
I very much like people who put a (non-blinking) light on their dogs. Especially when they either have a long leash or one of those retractable ones.
#116
Quoted: 2281 Post(s)
Liked 1,710 Times
#117
Liked 1,710 Times
We got a collar for our dog that lights up, mainly because he's a black dog and we have a hard time seeing him in the yard at night.
#118
Quoted: 356 Post(s)
Liked 323 Times
I really don't even care about the colour of the dog light, but as the eye is very sensitive to green light, I would recommend something with a green light because you can then use a less powerful one (more battery life) yet be seen really well.
I am quite happy to see a light going from side to side erratically, stop and go, and so on. I will then have a pretty idea that it is a dog and cut my speed right down, hands on brakes and whatnot before passing.
#119
The obvious answer would seem at first glance to be to use red as a tail light but I have noticed that for any given choice of lights, that for a given run time until battery discharge that the white "supposedly" head lights have about triple the amount of lumens as the red lights. Therefore I think a rear facing "white" light would be way more visible than the much dimmer red light.
#120
Liked 3,483 Times
at 60mph, the car will reach you in six seconds (well, a bit longer if you're also moving.) Not a heck of a lot of time from the initial 'WTF is that', to recognition that it is a bicycle in the road, to muscle input and vehicle reaction.... I'd prefer to be seen from a greater distance... So I feel that anything I can do to grab a driver's attention is a good thing! ...
However .... how many roads are straight and level for much more than 500 feet? Not a lot, where I ride.
Also, I assume that I will know the car is coming (cars are loud and headlights are bright) and I assume that the car will not hit me .... but I still get over as far as i can safely. The driver doesn't need to 'react" as if a semi-trailer with no lights pulled across the road a few hundred feet away. The driver needs to be aware of a potential obstacle on the side of the road. Often the driver does not need to respond at all, or perhaps will have to ease a few feet to the left for a second or so.
The fact that we all ride with such lights or less and so few of us are hit from behind tells me that the prescribed lights are fine. In fact, not many cyclists are hit from behind, and when it does happen, it is usually huge driver error--not invisible cyclists but distracted drivers.
I prefer tail lights as bright as possible, and red .... and flashing, because they work. A rearward-facing 500-candlepower light is a liability, and any light which could be seen farther than 500 feet but can't because the road isn't a highway .... is overkill.
I still opt for very bright tail lights, but anyone thinking a few extra candlepower are the difference between life and death, is deluded ... in my opinion.
Likes For Maelochs:
