Pics of fast bikes with triples?
#151
Quoted: 1079 Post(s)
Liked 1,899 Times
I'm not sure why the three ladies are dancing in the background, but I thought some of the folks in this thread might appreciate this t-shirt.
#152
Thread Leader suggested posting my Tommasini in this thread. It's a 56 cm Sintesi ( 56.5 Center to Top) that probably was converted to a Chorus Racing Triple by the previous owner, who like me, found he didn't have enough gears on the double. It was suggested by a member to be of a late 90's vintage. It's full Chorus with 170 cranks, 52 x 42 x 30 Rings and 13 x 28 Cassette. I bought it from a local lady whos since deceased father was an avid collector from S. California. The bike has always been stored inside and well cared for. It's a bit too small for me otherwise it would stay in my collection. As it is, I'll probably sell it and would take offers.
Likes For Boisecyclist:
#153
Boisiecyclist, I'm glad I just bought a horn; otherwise, I'd have to make the painful decision to part with either my Colnago, my Bianchi, or my Vespa to help finance that great-looking Tommassini. And it's just my size, too. Love, love, love a steel triple--really miss my Grand Jubilee, but it was just too big.
#154
#155
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
The Day I completed 500 Miles on The Indy Speedway Rack Track
Fred "The Real Fred"
#156
Quoted: 4512 Post(s)
Liked 6,387 Times
#157
I'm a little surprised that not one example of the Dura Ace 7803 triple crankset has shown up here... imho, the pinnacle of Shimano's bike jewelry design trend. (I realize that it's on the late side for most C&V bikes.) (And also that it's likely not to everyone's tastes.)
Tried to post an example photo but I'm still too newb to be allowed. :/
#158
Bikes: 2008 Rodriguez Adventure, 1995 TiCycles, 1995 KHS Montana Pro Custom, 2012 Surly Troll, 1976 Azuki Gran Sport Custom Frankenbike, 1974 Schwinn Sports Tourer, 1976 Schwinn Superior, 1989 Kona Cinder Cone
Quoted: 17 Post(s)
Liked 54 Times
Dura Ace triple
[img]blob:https://www.bikeforums.net/f1c1f661-25d7-4cbd-a99f-51e23639941c[/img]
#159
Quoted: 96 Post(s)
Liked 30 Times
Well it's fast if you can spin the 60t Duralum chainring! Early 1960s Desiree, also has a granny(28t) for going not so fast uphill, middle ring is 50t.
L. Magistroni cottered steel crankarms. Sheffield pedals
Brian
Brian
Likes For calstar:
#160
Quoted: 355 Post(s)
Liked 345 Times
Can’t say how fast I am anymore but this 72 Italvega Super Speciale served me well in 3 Eroica California’s so far. It has a modified ‘74 Campagnolo NR double crank drilled for 74bcd inner, currently a 28T Sakae Platinum chainring drilled for 10mm bolts, have been advised not to use 26T or 24T inner due to potential chain suck between the inner ring and Campagnolo crank arms. This doesn’t seem to apply to the Avocet / Ofmega Triple cranks pictured in some
bikes in this thread and which I’m going to use on a couple of future builds.
Overall front rings are 52-42-28, 52-42 are drillium rings from an Italvega Superlight. I’m using a 72 Campagnolo NR rear derailleur with SOMA long cage (I don’t consider it ugly at all, either anodized or polished) with NOS Bulleye pulleys, Suntour 14-18-22-26-30 freewheel but seriously contemplating moving to a 14-18-22-28-34 for Eroica’s Cypress Mountain climb for the >10% sections which I just couldn’t hack in 2019. Doing a lot more hill training and feeling relatively stronger but at my age and 210# weight, I need all the gearing help I can use. Have used KMC Z51 or newer equivalent 6-7 speed chains although some have mentioned SRAM / Sedis chains are also quite good in these applications. Had to install a Campagnolo 70-SS-X3 125mm wide spindle to get sufficient inner ring / chainring bolt clearance.
My use of larger / taller Compass / Renè Herse Bon Jon Pass Extralight 700c x 35 tires effectively increases total wheel & Tire diameter larger which makes my gearing a bit higher than if on normal 25’s so getting a bit more gear ratio would help. But with these tires, less vibration and floats a lot better over rutted dirt and gravel at 50-55R / 45-50F psi tire pressures depending on road and temps.
AFAIK, Bob Freeman in Seattle still drills and spot faces the crank arms and can help with fitting inner rings.
As ridden August 2021 Velo-Retro ride
#161
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3889 Post(s)
Liked 6,488 Times
Likes For SurferRosa:
#162
Quoted: 1608 Post(s)
Liked 2,216 Times
Just finished converting from 2x8 to 3x8. Crankset and RD are Racing T, FD is Record triple. Front rings are 52/42/30. Rear is Shimano DA with 12,13, 14, 15, 17, 19, 21, 23.
P1050224 on Flickr
P1050227 on Flickr
Replacement rear rear wheel with Campagnolo Record hub will be 13, 14, 15, 16, 17, 19, 21, 23. If and when I can find a 9v rear Chorus or Record hub the cassette in hand will is 13, 14, 15, 16, 17, 19, 21, 23, 26.
P1050224 on Flickr
P1050227 on Flickr
#164
Le savonnier
Bikes: I can count 'em on one hand
Quoted: 729 Post(s)
Liked 602 Times
Posted elsewhere: Newly acquired Motobecane Grand Record with various customizations, running a Specialities TA triple and a Super Record RD with Rally long cage. Just discovered yesterday, however, that my 34 chainring is bent and will require replacement. Probably go with a 30 or 32, anyway. Now I just need a freewheel worthy of that long cage.
#167
Quoted: 1324 Post(s)
Liked 927 Times
MIELE Suprema Columbus SLX frameset with the iridescent Neapolitan paint scheme. Campagnolo Mirage 9-speed Ergo levers and front derailleur, Veloce the rest of the components. Campy Evolution rims. Veloce crankset is 30 - 42 - 52 but only because at the time I ordered it I could only get those rings not the 30 - 40 - 50 I wanted.
I would have gone with Veloce Ergo levers and front derailleur but they were quite a bit more than the Mirage ones.
I should bew looking for those 9-speed Veloce Ergo levers and front derialleur. I by far prefer the silver colour over the black.
Cheers
Cheers
Likes For ShannonM:
#170
Liked 2,216 Times
@Miele Man - Have you tried to source the 50 and 40 lately? I was interested but am put off by the prices.
#173
Liked 927 Times
Cheers
#174
Quoted: 3241 Post(s)
Liked 2,512 Times
9 speed.
#175
Quoted: 2324 Post(s)
Liked 4,992 Times
Well I took this fast triple in on trade a couple of months ago. It's one sweet ride with the Racing T setup.
And then this local pickup. It's only 20 years old so probably not C & V yet. Still sorting it out but right now has a 52/42/30 crank and I managed to get the RD to work with a new 11-28T cassette.
Steel is real...and comfy.
