Addiction 2021.2
#2851
he said member
Bikes: yes please
Quoted: 2789 Post(s)
Liked 1,951 Times
Okay, it's official. I have too many bikes. I can no longer fit them in the corner of the garage. I can get 6 in there, but the 7th, I end up putting in the workstand.
I need a new garage. Or maybe for Mrs. GJ to clear her crap out of it, so there' ONE ROOM in the house that's mine, even if it's not in the actual house.
#2852
he said member
Bikes: yes please
Liked 1,951 Times
#2853
he said member
Bikes: yes please
Liked 1,951 Times
#2854
VFL For Life
Bikes: Velo Volmobile
Quoted: 28635 Post(s)
Liked 1,858 Times
#2855
Quoted: 10238 Post(s)
Liked 5,188 Times
#2856
he said member
Bikes: yes please
Liked 1,951 Times
Went to look @ a potential home today.
Every room. The basement, garage and part of the backyard.
With a full 20yrd dumpster in the driveway.
#2857
Quoted: 9656 Post(s)
Liked 6,366 Times
#2858
Liked 5,188 Times
I think this is the cleanest the drive chain has been since I bought the bike. Got it all back together, wheel is not bent so that’s good.
About a week ago I got it in my head the my C2 felt off. Something about the fit felt different, so I checked the things that made since. Handle bars were good, but I am not sure about my seat post. I can see the pencil mark, but it’s not in the middle of the circle, but I am also not sure it was ever in the middle of the circle. m If it did slip we are talking about a .5 of 1 mm so would I even notice that? I’ve ridden it a couple times since then, and once on the colonial parkway it hasn’t moved at all, and when I checked the torque of the clamp it is solid.
I am at the point where it might be in my head and I am trying to convince myself something is wrong when nothing is wrong, but now that the thought is there I can’t seem to shake it.
Don’t really expect to get any advice on this, just felt like sharing.
#2859
Liked 5,188 Times
#2860
Quoted: 20810 Post(s)
Liked 9,456 Times
#2861
Klaatu..Verata..Necktie?
Quoted: 10443 Post(s)
Liked 11,920 Times
And just like that, I feel MUCH better about our amount of clutter!
#2862
Liked 11,920 Times
That worked great! It's comfy out to at least 100km. Then I got the Circuit, and I did the same, which was harder because it's a smaller frame than I'm used to. And now I've done it for Mrs. Peel.
My point is, I don't have to depend on witness marks that was away the first time I give a bike a bath. If it feels funny, I can measure it again and check against the spreadsheet.
#2864
Liked 5,188 Times
Ah, but I DO have advice! I wanted to set up the Canyon, I measured the Bianchi, the Battaglin, and the Ritchey exhaustively, and entered the numbers in an Excel spreadsheet. Then I set up the Canyon as close to them as possible. I ended up measuring all of them on the kitchen floor (flattest place in the house), backed up against the garage door, and then the handlebars leveled, with the righthand drop hooked over the dishwasher's handle. Then I used the floor and the door as fixed points and made all measurements from them, and calculated everything from there.
So when I got the Ritchey I used measurements from my C2 to set it up. Basically all I cared about was seat height so measured the center bolt of crank arm to the seat post rails. That worked really well, and if I go off the Ritchey back to the C2 currently they match.
Still feels like it slipped, maybe it’s my brain that slipped.
#2865
VFL For Life
Liked 1,858 Times
#2866
Bikes: Shmikes
Quoted: 10176 Post(s)
Liked 5,873 Times
Any mini pump recommendations from the panel?
#2867
Liked 6,366 Times
Likes For Mojo31:
#2868
VFL For Life
Liked 1,858 Times
How's the stretching going? Do you have a proper yoga mat?
#2869
Liked 6,366 Times
Daughter ballooning in Mexico. More brave than I am
#2870
Liked 9,456 Times
My Lezyne Alloy Drive did pretty well yesterday... twice. It's a high volume model, so it'll "only" get up to 90psi, but does so in much fewer strokes than I'd expected. Just make sure that your valve cores are tight (keep one of those little core tools in your saddle bag) or the hose will unscrew the valve... which is why I had to use it twice.
Likes For WhyFi:
#2871
Silver Comet Fred
Bikes: 1
Quoted: 8845 Post(s)
Liked 2,995 Times
#2872
Silver Comet Fred
Bikes: 1
Liked 2,995 Times
#2873
Mostly Harmless
Bikes: Have two wheels
Quoted: 13720 Post(s)
Liked 4,532 Times
#2874
Mostly Harmless
Liked 4,532 Times
Likes For rjones28:
#2875
VFL For Life
Liked 1,858 Times
