Rigid or Shock fork
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
If you ride with the pressure so low there is a lot of give, it requires more effort to pedal. So you need the pressure high enough so there is little give.
The bumps absorbed by a fat tire is way less than suspension. Let's say you hit a large rock, the tire gives half an inch, and suspension gives 4 inches. It is nowhere near the same.
There are benefits of full suspension bikes, but I settle for front suspension, because it is easier to put a rack on the back or a rigid bike.
The way you balance yourself, and therefore, the way you land/encounter obstacles is what accounts for a smoother ride. Rider skill.
If you find to be already well balanced on your bike, the rigid fork will help take advantage of this.
For the majority of riding, this is how you'll be best off. Its only during the toughest of singletrack where floating over the bumps will pair well with rider skill.
Likes For Moisture:
I owned a carbon Bucksaw for a while. It is such a niche bike that I sold it after a year or so. It was super capable on single track mountain bike trails as far as climbing and traction in the loose stuff. I had built it with a gx Eagle and the gearing as well as traction with the 3.8 Nates made one hell of a climber. I could clear stuff that I’ve never been able to on my FS Sight. But... the crappy Bluto fork and the added wheel/tire weight made for an exhausting trail bike. It also couldn’t fit wide enough tires for the sand riding I do. Can’t say I really miss it other than when I see them listed for almost double what I sold mine for.
I think a fatty with full suspension makes sense in a few (very few) situations, a hard tail fatty with a decent fork makes sense if you use it all year and trail ride with it. But for snow, sand and general riding with very few trail outings the weight penalty of those huge forks just isn’t worth it... not to mention the taller stack height on bikes that are designed for a shorter fork.
Location: '16 StumpJ, Salsa Mukluk, Soulcycles SS, Dean Colonel HT, BMC FourstrokeTrail, Dean Torres CX, Santana Visa Tandem, Trek T2000 Tandem, Cupertino MTB Tandem, FreeAgent26"Xtracycle, Dirt Drop Dingle, Jamis Dragon Dingle, Airborne Skyhag SS, SSDean Cols
Quoted: 70 Post(s)
Liked 116 Times
Spend the extra and get the 9 speed Sora for only one reason... gapping.
Fortunately the 9 speed 11-34 doesn’t have the more worthless 12t Sitting between the 11 and 13 and that gives you better overall gapping between the cogs.
The 8 speed 11-34 has wider gapping.
Obviously you can swap out the cassette to improve it. Sunrace makes a nice 8 speed 12-34. But you’ll lose the ability to spin out that 50/11 which is so useful (lol) when BITD, 53/12 was a racers ratio, but I digress.
John
John
1. Self steer at low pressure.
2. Increased resistance at low pressure.
3. Fat tires do not behave like a suspension fork and or a suspension rear linkage.
As a fat bike rider I know these characteristics to be true. I still ride a fat bike some of the time and I love it, but it is the slowest and most difficult bike I have to ride. It takes a certain amount of air pressure to be just right for any given situation. And the rider has to be willing to power the bike even though it's a bit harder to pedal.
For me the rigid fork is the way to go. Putting more weight on it is not worth it to me.
Although I do think a Lauf carbon leaf spring fork might be awesome on one. But I'm not going there.
If I want to ride an easy going full suspension bike, it's my Stumpjumper.
If I could have only one bike, it wouldn't be a fat bike.
Still, there's a soft spot in my heart for these fat bikes. Mine is what it is, warts and all, and I love it.
Drip, Drip.
Liked 193 Times
1. A suspension fork can sometimes be barely any heavier than rigid. Thats not the problem. The extra length is.
Ive tried a 700c front 26" rear configuration before. Didn't like it much. It raises the front end by another inch which you don't need unless maybe you do serious singletrack.
Advanced Slacker
Quoted: 2763 Post(s)
Liked 2,537 Times
The frame is designed around a rigid fork that is longer than it needs to be so that a swap to an appropriate suspension fork will not screw up the geometry.
Drip, Drip.
Liked 193 Times
Lets be honest here, how much can you really compensate for a longer fork? Manufacturers end up needing to steepen the seat tube angle in order to make up for it. The entire geometry of the bike ends up changing somewhat in order to compensate. The head tube is typically left alone because the slacker angle can help with stability and the increased fork trail will make up for that anyways. Maybe the bottombracket is lower slightly since the longer fork can raise that up a bit. This sort of altered geometry can work well on singletrack, but its not ideal for most types of riding.
Quoted: 70 Post(s)
Liked 116 Times
Moisture, you're right!
Advanced Slacker
Liked 2,537 Times
When a company produces a rigid bike with suspension corrected geo, they spec it with a rigid fork that is roughly the same length as then intended suspension fork AT SAG..
This is well established, incredibly common, and widely accepted by people who understand bike geo.. I suggest Googling “suspension corrected geometry” and try to understand it before continuing here.
I have a carbon Trek Farley. Putting 100mm Mastodon on it really made the bike much more versatile, a go anywhere trail bike, and with. the 29x3.0 wheels it rips. If I only rode it in snow or beach or gravel, rigid would be fine. But I like that I can head off piste and deal with anything I encounter. I also like riding it when I go out with buddies on faster trail bikes that may be slower riders.
Drip, Drip.
Liked 193 Times
How much can you compensate? Completely.
My point is, that whether youre talking rigid or suspension, shorter forks tend to offer better handling and agility.
My other point is that rigid forks tend to offer better control and speed over most obstacles you may encounter.
Advanced Slacker
Liked 2,537 Times
Yes, cabbage, I know what suspension correction is. 425mm fork designed to correct in length for 100mm suspension, etc.
But to address your first point: if you knew what a suspension corrected fork was, you never would have claimed that a suspension fork would screw up the frame’s geometry.
I’m going to try just walking away.
Drip, Drip.
Liked 193 Times
There is so much wrong with this on so many levels I don’t even know how to start unpacking it.
You want the fork to be designed around the geometry of the frame, not the other way around. When manufacturers begin to tinker with angles and bottom bracket heights etc to make things work with a long ATC length fork, for whatever the reason maybe, they are in some ways compromising the handling of the bike, perhaps for some sort of benefits elsewhere.
This is a good thread topic. I want people to understand the differences in performance and why one may work better for you over the other without any bias. If someone thinks the suspension is better but never tried a rigid fork, i think their input is complete nonsense.
My point is, a bike designed around a 395mm atc fork will certainty handle better than one designed around something longer, suspension corrected or not.
Advanced Slacker
Liked 2,537 Times
If you do not understand why this is true, then you don't understand bike geometry. You are simply wrong about this. You can either go and do some research on this, or keep repeating this false information.
Complete nonsense for the reason stated above. And is yet again proof that you do not understand what a suspension corrected fork (and the frame designed with it) is for and how it works.
Quoted: 2997 Post(s)
Liked 1,192 Times
You'd do yourself a favor by not even commenting anymore on this thread since you have no clue what you are talking about.
meh
Quoted: 1111 Post(s)
Liked 1,013 Times
Two things about some of the recent back-and-forth:
1. This thread is in the Fatbike forum and many of these comments seem to be more general MTB related comments. Not a bad conversation, but if you're talking generally about suspension or fatbike specific suspension, please make it clear.
2. This Toad is an old-head, I like rigid MTB (& bikes in general). But that said, I've rented suspended bikes from time-to-time, and I have a comparison (not apples-to-apples, but a comparison):
I'm lucky to live with somebody that LOVES the North Shore of O'ahu and loves me enough to let me play bikes while on vacations. The resort we go to has single-track trails and rental bikes. I've ridden this loop 19 times over 7 years: Turtle Bay Beginners Loop. Most years, I ride a rental full suspension MTB (see pic below); early this year (in The Before Times), I brought my Breezer gravel/adventure bike with me (see pic below). I use my Breezer for CX, single-track, but mostly for ultra-endurance rides. I know this bike very well and it's well equipped - my best lap with the Breezer was 4:08; with the rental MTB, I got 3:17 ... and that MTB has 6 times on this lap that are faster than my Breezer.
To be clear: drop-bars are not the right choice on single-track; the Breezer has a long wheel base, making tight corners more difficult; the MTB has more aggressive knobby tires; and so many other reasons that this is not an apple-to-apples comparison.
All that said, IMHO a full-suspension MTB is the right tool for the fastest laps on single-track trails. OTOH you can enjoy single-track trails on most bikes, so if you're not racing ... run what you brung & have fun!
My Breezer Pro Radar gravel/adventure bike:
One of the rental MTB:
For those that are interest: I brought the Breezer to do some adventure rides on the North Shore, but was a little limited - the hills above the resort are military property that normally sits unused and can be ridden on weekends, but during our stay they were doing exercises the whole time and I couldn't take the ride I was planning. (edit/afterthought) - the Breezer did bring home some Strava glory and was faster than the rental bikes, but only on the gravel road segments ... so IME the a gravel bike is faster than a MTB on gravel roads.
Advanced Slacker
Liked 2,537 Times
Likes For Kapusta:
Bikes: Aurelia*Bianchi*Cannondale*Colnago*Dahon*Giant*Haro*Lynsky*Monkey Faction*Origin8*Panasonic*Paramont*Peugeot*Ross*Schwinn*SE*Specialized*Trek
Quoted: 58 Post(s)
Liked 26 Times
I see a lot of valid points on both sides so i think I’ll just get a F/S Fatty and a rigid Fatty.May the best Fatty win............my heart.
Likes For 7up:
Drip, Drip.
Liked 193 Times
Absolutely an untrue statement.
No. Rigid forks offer less control and speed because the fork/and bike get bounced all around the trail. Suspension allows the tires to stay planted to the ground for better control and speed over obstacles.
If you like to have suspension on singletrack that isn't too challenging, you're simply using the extra shock absorption to tackle terrain instead of sheer riding skill. Nothing can replace rider skill when it comes to getting that front axle over obstacles yourself.
in terms of speed and agility, on gravel, pavement and most types of singletrack, you will never come close to a properly balanced rider using rigid.
And the axle to crown distance on a fat bike, eg, Trek Farley is 531mm w/out sag correction (511mm with).
Liked 1,192 Times
how often does the average person come across singletrack challenging enough to call the need for suspension? 1%? Less?
I do agree that one needs to evaluate the terrain one rides and choose the tools accordingly.
Where I live there's only trail riding. I used to think that typical mountain biking is riding technical single track, but then someone decided that's trail riding so I guess I'm a trail rider. What suprised me was that apparently XC happens on fire roads and easy singletrack. From my perspective that's gravel riding. And for gravel a fatbike is massive overkill and also a pretty slow choice.
So the tool I find to be best suited for the type of riding I do is a front suspended fatbike with 120mm travel. I tried 140mm travel, but that's just too much. Actually a full suspension fatbike would be even better, but I only have a front suspended one. I suppose that objectively for some trails a 29er hardtail would be better and for some a 140mm full suspension 27.5", but I only have space and energy for one mountain bike so the front suspended fatbike is that bike.
Likes For elcruxio:
jj
Quoted: 140 Post(s)
Liked 110 Times
I’m definitely on board with the specific purposes thinking. Rigid Fat for slow sloppy rides, dual sus for the rest.
Since you’re only planning on needing the fat tires a few times a year, we’re it me, I’d just rent one on those days and put my money and garage space into a regular duallie.
