Where to buy tubes for cheap?
Uh-uh. Wind it up folded in half starting opposite the valve but pausing occasionally to push the stem and let the accumulated air out. Then close the valve, cap it and rewind folded in half starting at the valve. It's pretty easy to get them as tight as a new tube when you get the hang of it.
THE STUFFED
Bikes: R. Sachs Road; EAI Bareknuckle; S-Works Enduro
Quoted: 361 Post(s)
Liked 20 Times
In bulk from alibaba con mis amigos.
Bulk/ bulk packaging is the key word here. Who needs the box anyway?
Quoted: 26 Post(s)
Good call on Pricepoint, Jenson and AliBaba. I wouldn't check on these sites since I don't shop at those sites.
Thanks.
Thanks.
My rule on patching is 1-2 patches per tube. Then I replace with a new tube. Too many issues with a patch failing (due to handling), or a bad valve to bother trying to infinitely reuse a $5 tube.
I typically buy tubes 3-4 at a time and stick them on a shelf. When I put the last new tube in saddle bag, I'll get more when convenient.
Quoted: 14 Post(s)
Liked 13 Times
I get tires, tubes, and misc other items from Ribble in the UK. Great prices and very reasonable shipping, free over $100. Shipping time to the US can vary from less than a week to rarely three+ weeks due to things getting hung up at the US port of entry.
Cycle Year Round
Regardless if you pay $3 or $7 a tube, a 10 to 20 cent patch job is much less expensive.
I have tubes with as many as 15 patches before the valve stem fails. Cost to me is $5 tube + $3 max patches = $8 for me and $25 to $40 for you.
Land of the Free, Because of the Brave.
If your patching jobs are failing, then you need to learn how to patch better.
Quoted: 10 Post(s)
Originally Posted by [URL
https://www.jensonusa.com/Bicycle-Tubes/Duro-Road-Presta-Valve-Tube[/URL]
Certifiable Bike "Expert"
+1 on pricepoint.
However, I have found that really old tubes will dry rot and crack at the corners. I don't know if I've had this on factory new tubes, but I have seen it on used-patched-tightly coiled tubes.
Quoted: 8 Post(s)
Not mentioned here, though not always available online, there are fairly regular sales from Performance Bike where their house brand Forte tubes are only $3.
