Best puncture-resistant 45C road tyre instead of WTB Riddlers?
Quoted: 4560 Post(s)
Liked 2,802 Times
If you're still looking, check out Michelin Protek Cross Max. Most bombproof tires I've ever ridden, nary a puncture in more than five years. I've plucked out staples, brads, small screws, shards of glass, radial tire wires, etc., from the tread and none of it got through the 5mm Aramid fiber puncture shield (comparable to Kevlar). Even cuts in the tread didn't get through the puncture shield.
The main advantage I can feel over various Continental and other tires that use rubber puncture shields is a better ride quality. The Michelins don't feel as harsh as, for example, my Conti Contact Speed II tires with an equally effective but harsh feeling puncture shield.
The Protek Cross Max is heavy and runs a bit wider than nominal specs, so the 700x40 runs closer to 700x45. The errand bike I run 'em on could handle the 700x47 version which probably runs closer to 700x50. That errand bike weighs nearly 35 lbs, so the heavier tires don't matter much. There are lighter options for lighter weight bikes.
To quickly sift through Michelin's nomenclature for their various Protek tires:
So the regular Protek tires would have a 1mm Aramid puncture shield, thinner (but still substantial) chevron tread, and will be lighter and presumably ride a bit better. Protek Max would have the thinner tread but thicker puncture shield. I don't know whether Michelin still offers the Protek Cross, minus the thicker Max 5mm puncture shield, but it might still be available as new/old stock somewhere online. Check Bike Tires Direct, Jensen USA, Amazon, etc.
If I got a set to replace the harsh riding Conti Contact Speed tires on my other hybrid, I'd probably go for the regular Protek tire with 1mm puncture shield and thinner tread.
- "Cross" usually refers to thicker chevron pattern tread.
- "Max" refers to their thickest 5mm Aramid puncture shield.
Quoted: 144 Post(s)
Liked 119 Times
Am yet to make up my mind. I took the new bike out with its unaltered 45C Riddlers for its first serious (non-gravel) ride today, and really liked the feel of them. The idea of swapping them out for heavy Marathons, or inserting Tannus Armors with their added weight, is getting less appealing.
Until I get a puncture...
Quoted: 668 Post(s)
Liked 529 Times
Tire liners will make a noticeable difference in ride quality.
The good thing about them is they are easy to remove again.
I have a set of Mr Tuffy tire liners I would gladly give to you. But at only $12 new shipping might be as much as a grabbing some from a local walmart. If you want to experiment and have an old tire cut off the bead/sidewalls and use that as a liner. Probably will work as well and the Tannus units
