Racer Tech Thread
#3101
I've never heard this myself and don't worry or think about the location of the plug when installing the stem. That said, most carbon fork manufacturers specify a relatively low maximum spacer stack for safety reasons.
#3102
i don't know anything about cannonade headsets, BUT, i've been told that the "expander plug stops the stem from crushing the steerer tube" myth isn't actually true. that being said, it's pretty easy to adjust the location of the expander plug in the steerer tube, no? not like the star plug on a metal steerer that can go down but not up.
#3103
OMC
Bikes: Specialized Allez Sprint, Look 585, Specialized Allez Comp Race
Quoted: 461 Post(s)
Liked 116 Times
FWIW, my 2010 Look 585's fork uses no expander plug, and I think current ones are the same way. Proper use of the torque wrench is what keeps you from messing up your steerer.
Regards,
Chuck
Demain, on roule!
Regards,
Chuck
Demain, on roule!
#3104
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
I think the advantage of an expander plug is that it spreads the load inside the steerer tube compared to the star nut. Nothing to do with the stem.
Anyone tightening a stem enough to damage a steerer tube should be tested for steriods.
#3105
meow
Bikes: 2016 Parlee Altum, 2013 Cannondale Super Six Evo Hi Mod Di2 only, 2011 Cannondale Super Six, Dura Ace 7800, 2007 Cannondale System Six Dura Ace 7800, 1992 Bridgestone RB-1, MB-2, MB-3, MB-5
Thank you all for your replies to my headset question!!
#3107
meow
#3108
Bikes: Yes
Quoted: 9 Post(s)
Oh, you mean so you don't crush the steerer? It would take a heck of a lot of torque to do that. The main reason you want to use an expander plug is that star nuts cut the inside of the steerer, but expander plugs don't. Use carbon paste on the plug and torque to spec. Then set your stem height where you want it, tighten down very lightly. Set the preload to remove all play. Make sure there is no binding lock to lock. Straighten the stem and torque the steerer bolts to spec. It took me longer to type this than it would take to do this job.
#3110
Bikes: nagasawa, fuji track pro
Quoted: 26 Post(s)
and it looks sweet with no spacers....
#3111
Bikes: Trek Madone, Blue Triad SL, Dixie Flyer BTB
Quoted: 160 Post(s)
Cervelo actually uses an aluminum inner sleeve glued inside the carbon steerer tube, with a star nut. Seemed a little strange to me, and made cutting the steerer tube a little more work, but I guess it works fine. Their manual also states no spacer needed above the stem.
#3113
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
I see nothing in my 2015 Tarmac's manual about that, but I'm sure they'd still take extreme issue with the stack I've got going on.
#3114
Rides too much bike
Quoted: 232 Post(s)
On a side note: I once took a cut piece of steerer tube and attempted to crush it with a stem and a torque wrench. I maxed out the torque wrench, then went gorilla on it, it never broke.
#3117
yeah i'm pretty sure the crushing the steerer tube thing is a total myth.
speaking of steerer tubes, i cut my first one yesterday. granted, it was steel so not that complicated/high risk. roommate now thinks i'm a psycho after he walked into the kitchen and caught me hacking away at it.
#3118
W**** B*
Bikes: Several
Quoted: 103 Post(s)
On a related note, I love my Giant Propel, but damn, it's _super_ hard to find decent stems/spacers/microspacers for the 1-1/4" steerer in the US.
#3119
meow
Everyone, I can't thank you enough for the many comments about the Cannondale steerer and their topcap and expander system. Indeed, Cannondale wants the stem to be aligned with the expander.
However, it sounds like many are suggesting that the alignment is not critical because it is hard to imagine that the stem would crush the steerer were it overlapping a space where there was no expander.
I could go with a different brand expander and top cap system. Although, I have the Cannondale SI as pictured by jdms, and, I wouldn't mind using it.
#3121
Quoted: 693 Post(s)
specialized now supplies as default it's longer expander plug...so unless someone is doing something very weird with spacers, everyone should be good to go. you don't really NEED the expander plug, but it does distribute the forces on the stem and prevent slight/accidental over tightening from instantly ruining the steerer. one could even do some JRA with a huge spacer stack to dial in position before cutting...if one is careful.
#3122
Quoted: 693 Post(s)
i've done that with a few bikes and it is a noticeable change.
star nuts aren't generally used on a carbon steerer (unless you have a metal insert); expander plugs can be used on steerers of any material.
did you cut the stem with the sleeve in place? ugh. it's not really different than cutting a steerer as normal, but it's unfortunate if that was glued into place before you chose the steerer length.
#3123
FYI if you overtighten a stem it doesn't crush the steerer right away, but it will leave indents in the steerer after a while. At that point it becomes a bit tricky to adjust a different stem, like if your original stem was a bit cockeyed or something.
Hm. This may have been a seatpost. But I don't think so.
"...during the Lance years, being fit became the No. 1 thing. Totally the only thing. It’s a big part of what we do, but fitness is not the only thing. There’s skills, there’s tactics … there’s all kinds of stuff..." Tim Johnson
#3124
Bikes: i may have bike(s)
Quoted: 46 Post(s)
Sort of OT: I'm on a Cdale Evo which I had the stem slammed. Then I switched to a different stem which was a little taller where it clamps to the steering tube. I was in a very gentle crash, basically laid the bike over and when it was checked out, the steering tube was cracked. I am not sure if the crash caused the damage or if it was caused by tightening the stem onto a steering tube that was essentially a few mm too short.
@tetonrider: I have never heard of those sleeves; is that a diy type of thing or can they be purchased?
#3125
Quoted: 160 Post(s)
those sleeves are often found on pro bikes--you epoxy it to a (cut) steerer, and it stiffens up the front end.
