Nishiki Serial Number Database
#2351
Quoted: 4722 Post(s)
Liked 3,039 Times
Picked up this super red and Shiki international 4130 CR MO And found this thread hoping to find some more info. Pick it up from the gentleman at a garage sale he didn’t have any info. Anything that you guys could give would be super appreciated! I tried uploading photos, but it saying I can’t because I haven’t posted enough on bike forums. The bike is white with a splattering of black and it’s a change number one made in Taiwan. Has the red and blue does Shiki emblems and it says it’s the performance equip
Based on the logo style and the Shimano 105SC components, this should be a 1990 model. By that time the ATB trend had pared Nishiki's road line down to four models. The International was 2nd in the road line with an MSRP of $599 US. Tange #1 tubing is good and would have been 2nd in the Tange line at the time. The 105SC components were 3rd level for Shimano. I notice that it's TIG welded construction, which was just starting to take over from lugs as a more economical and flexible method. Taiwanese manufacture was becoming typical for the price point, taking over from the Japanese. It would be consisdered a decent, mid-range, sports model for its era.
#2352
Nishiki Comp III WE18822 (18,882nd frame produced in 1985 for the US market, according to the first post)
The bike is brick red with a silver seat tube and yellow decals. Scrapes on chainstays, seat stays and fork reveal chrome under the paint.
"Hand crafted by Kawamura 100% Chromoly" painted on the left chain stay. Seat tube stickers say "Tang 1 Cr-Mo Seamless Double-butted Tubing" and "Criterium Racing Frame Geometry." Fork sticker says ""Cro-Mo Steel Tang Fork Blade."
Suntour Superbe Pro derailers (front BG=July'85, rear BH=Aug'85), Suntour Superbe downtube levers.
Suntour Sprint brakes, Suntour aero levers.
Suntour Sprint 175mm crank 53/42.
Horizontal Nishiki forged dropouts, w/ adjuster screws.
Suntour Sprint sealed bearing hubs, 36-spoke araya 700C rims.
Suntour Winner 7-speed 7-21 freewheel, Ulra-6 chain.
Nitto Olympiade bars, Technomic stem.
Sugino seat post, Selle RoyalGel saddle.
Weighs 22lbs (w/ tires, w/o pedals).
Attachment 204012Attachment 204013Attachment 204014
thanks for the answer
#2353
Liked 3,039 Times
To properly answer your numerous posts on the subject, we need to known exactly what you have. Given that you are in Indonesia and each market has different model names, photos would be helpful. At the very least, we need to know the outer diameter of the seat tube, the construction method and the tubeset.
#2354
The seat post on the subject bicycle would be 26.6mm. However, I recently answered another inquiry of yours regarding the seat post size on a 1986 Nishiki International LD, which would be 27.2mm. These two bicycles use different versions of Tange #1. The Comp III uses standard, imperial diameter, Tange#1 and stock construction, while the International LD uses large diameter Tange #1 with internal lugs. Consequently, they use different seat post sizes.
Now i use 27.2 but seatpin is to tight like this, maybe the catalague is wrong?
outer seattube diameter is 31.8
Likes For baguslho:
#2356
Liked 3,039 Times
I don't believe the seat post is undersize by much, if at all. Looking at the picture, the problem appears to be overtightening of the cinch bolt, to the point where the mounts have deformed/bent and are touching each other. If you look at the cinch slot itself, there is still a very noticeable gap at the top, about 2/3 the width of the slot at the bottom. Typically, cinch slots are cut about 3mm wide, so this one appears to be about 1mm narrower at the top. Even with a correct size post, proper tightening will result in a cinch slot narrowing by about 0.6mm.
So, the frame might accept a 27.4mm post but it doesn't look like it would accept 28.6mm (and it definitely won't take 31.6mm), which are the most common sizes for oversize frames. 27.4mm isn't a common size, so it was most likely designed for 27.2mm. The current post might be slightly under its listed size or the lug may have been aggressively reamed.
#2357
Centurion le Mans
Hi T-Mar, many thanks for what you are doing here! I now have my two daily rides accurately dated, thanks to you. I picked up a very smart Centurion Super le Mans a few days ago in great condition but with a large frame, with the intention of swapping to a smaller one. Found the frame for a much older le Mans the next day and I am impressed with its smart brazed-on cable stops and chromed socks. There's one number, stamped on the seat tube, at the back and just below the pinch bolt B622. It was once a metallic red and bears the remains of a decal stating "Designed by Mitchell" and another "Guarantee". Might there be a clue? Photos below, and the Super le Mans that shares the same FD and RD is here: https://www.bikeforums.net/classic-v...l#post21980270
It once was red metallic.
Guaranteed?
Guaranteed?
A bike is the closest I can get to a magic carpet . . .
#2358
Liked 3,039 Times
Guaranteed?
Guaranteed?
#2359
Thanks so much!
Hi T-Mar, thanks for replying so quickly. I didn't see any date codes on the FD or DR, but both show 4532 as in the photo. The drive-side crankarm has 906 on the back, it's a Tourney. Hope this helps further - even if it's a rough date range.
#2360
Liked 3,039 Times
#2361
And more!
Hi T-Mar, i am ashamed that I thought the circled numbers to be trademarks. So here they are!
#2362
Liked 3,039 Times
So, the date code is QB, which represents, February 1974, which should make the frame a 1974 model. The 2nd photo says JIS, which is the symbol for Japanese Industrial Standards.
#2363
T-Mar, thank you so much, and apologies again for not knowing about the date letters. This is great to know and allowed me to determine more about the frame. If of use to your many readers, I found a recent website for Centurion enthusiasts here: Vintage Centurion Bicycles. Sheldon Brown's site has a contribution from one of his successors at https://www.sheldonbrown.com/centurion.html, which quotes you at length, something that will never, ever happen to me. Thanks again!
#2365
Would you like the serial no. of the second of my frames? I still have it hanging in the garage awaiting better days.
#2366
Liked 3,039 Times
I've had two of those Nishiki Internationals with the oversized tubing and both took a 27.4mm. The catalogue states they are 27.2 but I suspect some overly excited reaming in the factory has caused them to be too big. Both frames had cracking in the lugs/tubes from the clamps being tightened too much with the stock 27.2 in there. One I had repaired and later sold, the other I got used and fitted a shim right away so the cracks haven't spread far enough to weaken the clamps.
#2367
The first bike I got was the blue and silver one, which had the 27.2 spec seatpost. I had problems with it slipping and probably should have shimmed it, but anyway ended up cracking the clamp area. When I took it to get repaired the frame builder (who did a nice job brazing a new lug up) said that the tube measured out much closer to 27.4 than 27.2 which would have caused the issue. I bought a 27.4 seatpost and rode the bike for a couple of years before selling.
I then found the current one on the facebook trader, cheap as it had no groupset. I bought it knowing the possible issues, and sure enough found that it was starting to crack by the clamps. I made a shim for a 27.2 seatpost and rode it for a while before buying a 27.4 seatpost which fits very nicely.
I should add that I am in New Zealand, maybe bikes for the Oceania/Asia market were finished differently in a different factory or it's just they were made on a friday afternoon just before clock-out time
#2368
Bikes: 71 American Eagle Olympiad, 03 Trek 5200 P1, 2013 Trek 6 series Domane, 83 Apollo branded Kuwahara, 78 Trek TX 300, 73 Nishiki Intl. 86 Nishiki Prestige, Nishiki Olympic, 72 and 73 Nishiki Safari', two-speed Electra BMX cruiser 1, 87 Nishiki Linear
Quoted: 32 Post(s)
Liked 65 Times
American Eagle saved from the trash bin
Saving this old beast from certain death....
Old tank with bent front fork
KB -Kawamura Built
Another serial number for T-Mar
KB -Kawamura Built
#2369
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Went by our (usually closed) co-op to check on the dumpster this week and found this tall Backroads MTB from the '80s hanging out by the dumpster. I don't mind dumpster diving but this technically wasn't in the thing so I left it alone but posted about it. Another forumista inquired about getting it so I phoned the co-op and was told that stuff around and in the dumpster is fair game so I grabbed it. Originally sold by The Unicycle in Blacksburg VA the serial number looks like it has a misstrike.
First character looks like a bad 6 (Maybe a C?) followed by 690003. Hope this helps.
#2370
Liked 3,039 Times
Likes For T-Mar:
#2371
Liked 3,039 Times
#2372
CL Addict
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Quoted: 85 Post(s)
Liked 96 Times
Nishiki Century
Serial# 4009466
Dia-Compe front brake caliper date code: 1283M
27” wheels
Frame is in very good shape. Red paint has nice sheen. I’m going to build it up with updated components and alu wheels for my daughter.
27” wheels
#2373
Liked 3,039 Times
The subject bicycle appears to be a 1984 Nishiki Century, manufactured by Giant of Taiwan. There should be a date code on the other dropout, format Gmmyy, where mm is the month and yy is the year.
#2374
CL Addict
Quoted: 85 Post(s)
Liked 96 Times
#2375
Bikes: 1981 Raleigh GP, 1985 Norco Bush Pilot, . . .
Quoted: 241 Post(s)
Liked 187 Times
The first and last characters on this frame were not struck cleanly. I would suggest that the serial number reads as: G6900030.
This is a Giant of Taiwan serial number from later in 1986. This is the time when Giant was changing the format of serial numbers stamped onto the frames. Giant was no longer stamping a date code separate from the serial number.
This format has only one letter: G for Giant the manufacturer.
The first number, "6", is for the year of frame manufacture: 1986.
As stated previously this is a 1987 model Nishiki.
It appears that this format of Giant serial number was only used for a few weeks.
Later in 1986, Giant added a second letter into the serial number and removed a digit from the end.
