Birdy thread
#1576
Quoted: 573 Post(s)
Liked 118 Times
No spacer. It's a square taper bottom bracket, so I might be able to add a spacer or replace that BB with a hollow one like above, but before going ahead, I wanted to check if someone had sucessfully installed a double crankset (clamp, BB, derailleur, crankset, shifter).
#1577
Quoted: 802 Post(s)
Liked 249 Times
To know if it will work, you need to measure the chainline.
R&M adapts the chainline of the Birdy according to the rear transmission, its different for the different Birdy with different IGH and Birdy with derailleur.
Likes For Jipe:
#1578
Bikes: 2021 Birdy GT Rohloff, 2007 Birdy Mark 2
Quoted: 18 Post(s)
Greetings from sunny Singapore! I have not done the conversion myself, but a local bike shop has done it on 50/34T using Shimano Claris R2000 Braze-On FD.
Oops I'm not allowed to post links. You can search for the LBS name, Green Basikal on facebook.
#1579
Quoted: 802 Post(s)
Liked 249 Times
What model of Birdy do you have ?
What is the brand of the front derailleur mount used for the conversion ?
You could maybe post some pictures of it.
#1580
Quoted: 18 Post(s)
I have a Birdy GT. Let me clock 10 posts and I can attach pictures of my bike and the link to the double chainring Birdy.
The brand of the front derailleur is Shimano.
I had tried to upload a picture of the Birdy with dual chainring in my album. Can you check if you could see?
#1581
Quoted: 802 Post(s)
Liked 249 Times
The Birdy GT is a derailleur Birdy, it has the chainline distance of a derailleur bike which is compatible with a front derailleur
There are several bike pictures, b do not see any Birdy picture on the FB page of Green Basika.
#1582
Quoted: 14 Post(s)
Facebook Post
https://www.facebook.com/theGreenBasikal/photos/pcb.4530392330317803/4530392216984481
" data-width="500" data-show-text="true" data-lazy="true">
https://www.facebook.com/theGreenBasikal/photos/pcb.4530392330317803/4530392216984481 " class="fb-xfbml-parse-ignore">Facebook Post
#1583
Quoted: 18 Post(s)
Over here, we have 5 Birdy models (excluding the P40), they are the new classic (with tubular frame), the City, GT, R20 and the Rohloff (all having the same monocoque frame). All the above models only have single front chainring.
#1584
Quoted: 802 Post(s)
Liked 249 Times
The Birdy with internal gear hub like the Birdy Rohloff and the R&M Birdy City have a different value of chainline and it might be more difficult to fit a front derailleur on hem than on Birdy with a rear derailleur like the GT, Standard, Touring...
#1585
Quoted: 18 Post(s)
Thanks for attaching the screenshot! Looks like there are some extensive modifications needed to install a dual chainring.
I will be sending my Birdy for Rohloff conversion by next month, will ask more about the amount of modifications required.
#1586
Quoted: 802 Post(s)
Liked 249 Times
On the Birdy Rohloff, the dropout is different and the chainline too to accommodate the wider chainline of the Rohloff hub (+ of course the rotating grip and dual cables furnished with the Rohloff hub).
#1587
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
I wonder about absorbing the chain slack on a Birdy with a double ring in the front. The somewhat unusual tensioner on Brompton absorbs plenty of slack and I was able to get away with a triple ring in the front without essentially any modifications regarding the slack - I can actually fold the bike with the chain on the smallest ring in the front. However, when I replaced the rear Brompton derailleur with a regular one, like on a Birdy, I ran into problems with the slack for a folded bike. I made a chain catcher, such as one I saw in photos of some Birdys, but it only helped with one ring in the front. Two or more rings were turning into disasters. You could always fold, of course, exclusively with the chain on the largest ring, but it is a hassle.
#1588
Quoted: 18 Post(s)
Just curious, do you guys do a lot of climbs? I find the stock 10-speed with single chainring more than sufficient for my commute. The only mod so far is to upgrade from 52T to 56T Oval.
#1589
Quoted: 802 Post(s)
Liked 249 Times
The titanium Birdy is factory equipped with a 52-36 front and Shimano 105 front and rear derailleur (rear is a RD-5800-GS, front FD-R7000, the frame has a front derailleur mount for a braze-on front derailleur).
It has the current Birdy chain tensioner around the crankset chainring.
Folding is OK whatever the chainring with, as always for BIrdy with a rear derailleur and cassette, the chain on the smallest cog.
Now, the frame geometry of the TI Birdy is different from the Birdy 3 and I do not know if it will also work with a Birdy 3 with double chainring?
About the choice of the front 52-36, with the small wheels of the Birdy, 36t front gives really short gears, I never need the 36t front + 32t rear I have. A 53-39 combination is probably better.
The original gearing of the Ti Birdy (and R20 SP 11) with only a 11-28 cassette is not a good choice (gearing too long for hills on the 28t, too short on flats with the 11t). Its probably the reason why Pacific Cycles mounted a front compact crankset and front derailleur on the Birdy Ti. The 9-32t cassette range of the R&M Birdy touring is a much better choice.
#1590
Quoted: 573 Post(s)
Liked 118 Times
In particular see https://www.facebook.com/theGreenBasikal/photos/pcb.4530392330317803/4530392216984481 (note the comment about a longer axle).
It depends where you live, and/or if you use the folder for touring (= heavy bike) like I do.
#1591
Quoted: 14 Post(s)
15% hills need a good gearing range. I can just get up a 15% hill in 3rd gear on my Birdy Rohloff and like to have a couple of gears in reserve for headwind / extra load / tired legs.
#1592
Quoted: 802 Post(s)
Liked 249 Times
Even in cities, there are places with short but very steep streets where the 52x32 2.21m, the lowest gear of the Birdy Touring, is too long
For those places, the Birdy Rohloff with 1.55 - 8.27m goes everywhere while the Birdy Touring with 2.21 - 7.86m can have problems on steep hills.
For me, the Birdy City with its cheap and limited Nexus 8 is a very bad choice. I wonder why at his price, R&M doesn't install an Alfine 11 hub on the Birdy City instead of the low end Nexus 8 ?
#1593
Quoted: 18 Post(s)
I see. Come think of it, there's hardly any hills here in Singapore, hence generally 7-speeds onwards is sufficient for most of our commuting needs.
I'll be swapping out my SRAM X5 10 speed to the Rohloff hub next month, looking forward to the modification!
#1594
Quoted: 802 Post(s)
Liked 249 Times
One benefit you will also have when swapping to a Rohloff is longer gears because with a 11-32t cassette and a 52t chainring, 52x11 is quite short, the R&M Touring Birdy has a 9-32t cassette with the same 52t chainring which provides a much longer 52x9 gear.
#1595
Quoted: 14 Post(s)
Note also that Rohloff hub gears improve with use but are very low maiintenance except for the oil change every year or 5000km, whichever comes first.
#1596
Quoted: 18 Post(s)
Most of the Birdy owners I know use the bike for leisure speed rides. Hence they focus on weight savings (eg lightweight cranks) and highest gear ratio available.
I'm likely to retain my existing 56T oval chainring with the Rodloff hub before deciding if I need a smaller chainring.
I also read that the Rudloff hub can be noisy at gear 7, did you observe that?
I agree. While the Alfine 11 is more than double the cost of the Nexus 8 this difference is a relatively small proportion of the total bike cost. I briefly considered putting an Alfine 11 onto a Birdy City but quickly crossed off that option because I knew that it wouldn't have the gearing range I wanted (I've got another bike with the Alfine 11 which is waiting to be re-homed).
The standard Birdy Rohloff uses a 52T chainring and 13T sprocket (the smallest available). I'm planning to fit a 14T sprocket to get slightly lower gearing for my hills but if you don't have steep hills then you may want to investigate fitting a bigger (56T but even bigger if feasible) chain ring. Otherwise you'll never be using the bottom gears and be wanting another gear at the top end.
Likes For Huggable:
#1598
Quoted: 14 Post(s)
Any of gears 1 to 7 of a Rohloff hub are noisier than gears 8 to 14 as an extra set of gears is used to create the low range. However, 7 tends to be the noisiest as it is effectively overdrive low range and involves both the low range gears and a freewheel mechanism. The sound difference between 7 and 8 provides a useful way of knowing which gear you are in without looking at the shifter. The gear noise reduces with use. My No. 1 Rohloff bike is approaching 10,000km and the gears have become much quieter which is very noticeable when compared with the much newer Birdy Rohloff.
Probably the best English discussion about Rohloff hubs is at Rohloff Internal Hub Gears .
#1599
Quoted: 802 Post(s)
Liked 249 Times
Current Rohloff are less noisy on their 7 lowest gear than older ones. I have two bikes with a Rohloff, he first one of 2021 even if it now has a lot of km remain noisier than the second one of mid 2016.
The break-in time of current Rohloff is also much shorter that it was with the first models.
If somebody will build the wheel for you, it is strongly advised to add the flange support rings
#1600
Quoted: 18 Post(s)
Thanks for sharing! I'll slowly read up the discussion threads.
I agree that if you've already got a 56T chainring and no very steep hills then it would be best to keep that chainring.
