The For Trade Thread
#1676
Sneaky Fast....
Bikes: 2007 Specialized Epic Expert, 2005 Giant TCR C3, 1996 Specialized Stumpjumper M2Comp, 1986 Raleigh Capri 10spd, 1982 KHS Turbo 12spd, Wife's: 2010 Specialized Safire Comp Komen, 2007 Specialized Dolce Elite, 2005 Giant OCR3, 2000 Trek 6000 WSD
Have: Fizik Aliante Sport
Want: Shimano 105 (double) front derailleur, braze on, BLACK to match the rest of the 105 stuff on my '05 TCR C3
Chris
Chris
#1677
BOATS AND HOES!
Bikes: Madone
Have Shimano Ultegra 10sp 12-27 cassette less than 100mi
Want Shimano Ultegra 10sp 11-23 cassette low miles.
#1678
Bikes: 1983 Schwinn Paramount, 2006 Cannondale Six13 Pro, 1987 Schwinn Voyageur 1986 Fuji Regis, SSR Fixed Gear
want: shimano sora 7 brifters or ultegra 8 bar end shifters
have: a ram-shamble of parts, forbidden
#1679
Roadie
Have many handlebars:
FSA K-Force Carbon(2008) 31.8 44cm
FSA K-Force Carbon K Wing 31.8 42cm-internal cable routing
Deda Elementi Newton 31.8 42cm gunmetal grey (x2)
Easton TKO Carbon Pista track bar 31.8 40cm
Oval Concepts R950 Carbon 31.8 42cm
Ritchey Carbon WCS 31.8 42cm (~200g)
Ritchey Pro 31.8 7075 T-6 31.8 44cm c-c
Ritchey Comp 6061 T-6 31.8 42 c-c
ITM The Bar 26.0 44cm
ITM Super Over 330 31.8 44cm
ITM Millenium Ultra Lite Strada 26.0 46cm
3T The bar 26.0 46cm
Bontrager Select 31.8 40cm
Control Tech Formidable CL Wing 31.8 44cm
Stella Azzurra Profi 31.8 44cm c-c
Deda Velocita Steel 26.0 40cm c-c (stamped 'Bianchi')
Profile Design Airwing 26.0 42cm
Want:
48-54 road frame, open to any type/style
TT bars
Yellow Swiss Stop pads
9 speed rear wheel
1" full carbon fork
Time or Zipp 110cm stem
Schwalbe Ultremos or Vittoria EVO CX
warm winter gear
many other things (see post #1611 for more complete list)
Want:
TT bars
9 speed rear wheel
1" full carbon fork
warm winter gear
#1680
Bikes: 2011 Chinese Carbon Road, 2012 Giant Talon 1 29er, 2018 Mongoose Salvo Supa
Have:
Used 53-38 Dura ace 7800 crank set in excellent condition
w/ ceramic bearing bottom bracket
used Dur ace 11-23 9-speed cassette - excellent condition - ~
Use Dura Ace 7600 brake set - excellent condition
Want -
High end used compact crank set (similar quality to the one listed above) with 50/34 rings
Ultegra long-reach brake set
54 cc top tube used aluminum frame set that has at least a carbon seat stays, but preferably carbon chain stays as well
Want -
Have:
DA 9-speed groupo w/ 7800 crankset and ceramic BB - $500
https://lh6.ggpht.com/_mcTwcdpez38/SU...0/PC190048.JPG
7800 Crankset - $150
Ceramic Bottom bracket - $50
https://lh6.ggpht.com/_mcTwcdpez38/SU...0/PC190040.JPG
7700 shifters (they are scraped up but work great) - $125
https://lh5.ggpht.com/_mcTwcdpez38/SU...0/PC190043.JPG
7700 rear derailleur - $50
7700 Front derailer - $25
https://lh4.ggpht.com/_mcTwcdpez38/SU...0/PC190044.JPG
7700 Brake set - $75
https://lh4.ggpht.com/_mcTwcdpez38/SU...0/PC190045.JPG
Recently purchased 9-speed DA chain - $25
11-23 9-speed DA cassette - $25
Want:
Rival 08 or 09 shifters
Rival/Force 08 or 09 derailleurs
50-34 compact crankset w/ 172.5 length cranks & BB (Rival or Force preferred)
Used 09 or 08 full rival groupset
54 or 53 length top tube road frame
Thank green stuff -make an offer
#1681
I have this Raleigh Olympian Frame. Not sure year, the color is not black, its got like a hint of dark purple in it. Overall good condition a hint of surface rust here and there, top tube is 21 inches, down dube is 20.5 in. Also have a matching fork and some odds and ends from the original setup.
Looking for forbidden and maybe some deep v's.
#1682
moving target
i have a clamp on bottom pull ulterga front derailleur.
I need a braze on bottom pull, does anyone have one,
#1684
Should be out Riding
Bikes: Bob Jackson Vigorelli
Orbea Aqua 51cm FT
I would like to trade my Orbea Aqua for a steel bike. The frame probably has less than 100 miles on it. Check out the craigslist post.
https://richmond.craigslist.org/bik/964546092.html
#1685
Not actually Tmonk
Bikes: road, track, mtb
Quoted: 2640 Post(s)
Liked 3,153 Times
Want:
27.2 Carbon Fiber Seatpost, pref. short (<300 mm)
Have:
25.0 carbon fiber LOOK ergopost
Have:
#1686
Bikes: Waterford 1200, Redline Monocog, Redline Conquest Pro, Surly Long Haul Trucker, and a Sunday BMX bike!
Have: 53c Lemond Alpe d'Huez frameset. Reynolds 853 Frame, carbon fork.
Want: Open to anything really. Forbidden would be good too.
#1687
Don't mess with Texas.
Bikes: 2006 Bianchi 1885 w/ 105 10 speed and 2006 Jamis Coda Comp Commuter
I hope to go from carbon back to steel...
Have: 2008 Fuji Team Frameset 58cm excellent condition OR Burley Solo Trailer
Want: Salsa Casseroll frameset (53cm) or something similiar
#1688
Bikes: Windsor Fens '07
Have: Ultegra Clamp on Front Deraileur off a Motobecane -- It is NOT 34.9 size.
Want: 34.9 front derailuer clamp on
#1691
Have:
105 double crank with integral bottom bracket axle - Not compact !
Phil Wood Fixed Gear hub, 120mm, 36 holes, almost new (less than 50k !!!)
Want:
Make me an offer I can not refuse ! (Sturmey Archer AM/FM, 126mm phil wood hub or something interesting ...)
Want:
#1693
Bikes: Titus Modena
Have:
Moots Titanium 27.2mm x 350mm seatpost - no setback
Track wheelset: phil wood hubs, low flange front, high flange rear, dt swiss double butted spokes, mavic open pro 700c rims.
Want:
Significantly less valuable track wheels, or ???
Want:
#1694
tarck as ****
also:
ok, i need to move some combination of some or all of these, minus the xtra
local pickup in NY hudson valley area on this one below
full sram rival (mostly)
serotta is 54 or 55cm
specialized is 56cm
dirt is 18in
specialized is 56cm
dirt is 18in
#1695
Knowing's half the battle
Bikes: 2009 Cannondale CAAD9 BB30, SRAM Red, Fulcrum Racing 3s
Have: 2008 Campy Record ergo shift levers (some use, installed this year)
Want: 2009 Campy Centaur ergo shift levers
#1697
tarck as ****
also have:
700c silver open proto 105 hub
dura ace rear derailleur, not sure which model but works with 9 speed
ultegra 9 speed front der
dura ace 9 speed cassette
dura ace 9 speed DT shifters
ultegra 9 speed Brakeset
brand new shimano 105 level wheelset
campy threaded headset
campy brake levers
cinelli criterium bars, 26.0
dura ace BB (i might need this)
1in threaded nashbar carbon fork
3ttt stem, 110mm 26.0
campy brake levers
#1698
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Have: Shimano 105 outboard bb cranks with bb (little use). 172.5mm
Ritchey Pro Handlebars 40cm
Want: Compact crankset compatible with octalink bbs. Prefer 172.5mm
#1699
have:
Deda Track drops from Bianchi Pista
Shimano 600 ax rear derail NOS
Bianchi Fremont 59cm
Fender Stratocaster in Sunburst
forbidden
want:
6600 Ultegra 53T (or around there) Chainring in new or very lightly used (<300mi) condition.
600 stuff. Maybe ultegra stuff. Let me know any groups you have to offer. (nothing too cheap or in bad shape)
nice steel, aluminum, or titanium road frames in 57-59, maybe 60. (nivachrome or something nicer would be great)
fizik arione in celeste or black
san marco concor in black (a light model preferably)
other great saddle
CANE CREEK VOLOS! CLinchers or tubular. Black or silver. Let me know what you've got. Need a track rear wheel definitely.. but I imagine the fronts are the same for both wheelsets.
Great wheelset for my track or road bike!
Dura ace/Ultegra/Chris King headset 1" threaded
Dura ace aluminum wedge for dura ace quill stem
Thomson black seatpost 27.2 (250-300mm ish)
or...a great offer
forbidden
want:
other great saddle
or...a great offer
