The For Trade Thread
#1726
Have: Pearl Izumi Octane Jacket. Goes for $200 new. Wore it once for 45 min and decided I had bought the wrong jacket. It really is only good if you ride in the rain and snow a lot. I used it at night when it was 38 degrees out and I was about to roast. Size small in red. Description here.
I'll get a picture up tomorrow.
Want: Mostly green paper.
#1727
WV is not flat..
Have- Specialized Sport MTB shoes w/SPD cleats, size: 11.5/45 (they seems to be sized small/narrow) used but in great shape.
Need: Dual pivot brake calipers (105,Tiagra grade) for 700's, I'm not picky on brand as long as they work.
27.2 seatpost , 250-300mm
Rear alloy wheel with freehub for 7 or 8 speed
#1728
Bikes: 1983 Schwinn Paramount, 2006 Cannondale Six13 Pro, 1987 Schwinn Voyageur 1986 Fuji Regis, SSR Fixed Gear
Have: Shimano Sora Right 8 speed STI lever
Want: Shimano Sora Right 7 speed STI lever
#1729
Indiana roadie
Have: Windsor Tourist 54cm touring bike 2008 year tiagra/ deore 9speed , fenders,rack,rack trunk with 300 miles . Perfect shape no scratches ,dings or dents.
Want: 29er mtb , road bike of = value ,or forbidden $
#1730
Looking to trade a 11-23 sram 1070 cassette for 12-25. Cassette has less than 100 miles and has nearly no visible wear.
#1731
Have:
Shimano RX100 (BR-A550) front brake caliper
Shimano 105 (BR-1055) front brake caliper
NOS Pink Dia Comp brake hoods - non aero, still in package
Black 1" threadless Aheadset
120mm 1 1/8" adjustable Dimension stem
120mm 3T quill stem
40t 110 bcd chainring
NOS nylon straps
1 small Christophe chrome toe clip
Replacement track axle
Take offs from Windsor Hour:
Stock front wheel
Black 170 Truvativ Touro cranks & BB
Black 27.2 seatpost
16t 3/32 cog
Lock ring
Quando flip flop hub - stripped fixed side, never used freewheel side
Want:
165-170 track/singlespeed or square taper road cranks
Dual pivot brakeset or rear brake caliper
Aero brake levers (preferably with white hoods)
Pinup for Cinelli Alter (120mm)
White brake housing
ACS Claws (or similar) freewheel
120mm 3T quill stem
NOS nylon straps
Stock front wheel
Black 27.2 seatpost
16t 3/32 cog
Lock ring
Want:
White brake housing
#1732
ub3r n00b
Bikes: Bianchi Via Nirone, Trek 6000SS, Zebrakanko FG
have:
-taken apart rear brake, road caliper off a Bianchi Via Nirone
-Functional front brake off Bianchi Via Nirone.
want:
trainer tire
want:
trainer tire
#1733
Have: NOS 1983 Peugeot PSV10... absolutely stunning bike. Has been ridden under 50 miles in the 25 years it's existed. Drilled rings and fluted cranks. This was one of Peugeots nicest rides that year. Whisper me for full details and photos.
Want (Desperately. Whisper me if you've got anything, even if you've no interest in the Pug): Steel roadie. 54-55cm. Mid-late 90's. Preferably Specialized, Cannondale, Klein and the like. Whachu got?
#1734
Have: Road Stuff:
- Thomson Elite Seatpost - 27.2, 410mm long, black, no setback
- Thomson Elite X2 Stem - 100mm, +/-17 degrees, 31.8 bars, black
- Crank Brothers Quattro pedals with cleats (shoe platforms are beat up, rest in good condition)
- Tektro long reach brakes (521 AG Long Reach, take-offs from a Giant OCR, ~3,000 miles of use)
Have: Cyclocross Stuff:
- Avid Shorty 4 cantilever brakes (~2,500 miles of use, pads less than 500 miles old)
- 2 Vittoria Cross XG Pro tires - 34c, silver (<300 miles of use, center knobbies darkened a bit)
- 1 Hutchinson Piranha CX tire - 34c, silver (brand new, still in packaging)
- (gone)
Want:
- Thomson Elite X2 Stem - 90mm, +/-10 degrees, 31.8 bars, black
- Ultegra 9spd STI levers
- Ultegra 9spd front derailleur (clamp on)
- Ultegra 9spd long cage rear derailleur
- Specialized Avatar Gel or Alias saddle - in white 155mm wide
- Fizik white bar tape - the chalk white, more durable kind
- You know
edit: traded conti tire
edit: traded touring wheels
- (gone)
Want:
- You know
#1735
Direct Hit Not Required
Bikes: Leopard DC1, Ridley X-Fire, GT Zaskar 9r
The spacing between cogs on 7-speed and 8-speed cassettes are same.
The 8-speed cassette is when Shimano widened the cassette to its current width.
Between 8, 9, and 10-speed cassettes is where the cog spacing gets narrower.
#1736
You know an 8-speed shifter will work perfectly with 7-speeds right?
#1737
Bikes: 1984 Schwinn Super Sport, 1988 Trek 1500, 1978 Raleigh Competition Gran Sport, 1986? Nishiki Cresta
#1738
Dropped
#1739
this portrait of karma
want: DA 7800 175mm crank
don't need the BB or chainrings
have:
10sp ultegra short cage rear der - new
tt/tri cockpit stuff - new
have:
#1740
Bikes: cannondale caad 8 custom
have: fsa energy compact front derailleur 32 clamp, and shim 28.6
want: same in braze on or 35 clamp
#1741
HAVE: Newish 36-hole century finish Centaur rear rub, used about 200 kms on the road and about 20 hours on a trainer indoors.
WANT: Two used 32-hole rims such as Mavic Open Pro, Velocity Aerohead or Ambrosio Excellight. Or something comparable.
#1743
Bikes: Cervelo Soliost
Have
SRM Amateur Unit 175mm cranks campy splined bb, black PCV, front and rear sensor
2008 Cosmic Carbone Wheels not Premium with zipp skewers clincher 700c campy freehub
2008 Record 10 speed hubs built on Noubium rims with Sapim spokes, built by troy watson, weight is 1480grams
Deda newton deep drop bars 46 (outside-outside)
Want:
Zipp 404 or comparible
54-56cm crit usable frame
Lots of Cera
Want:
Lots of Cera
#1744
Have:
Complete Ultegra SL Groupset (takeoff from new bike, probably 20 miles on it) includes:
- Left and Right Shifters
- Brakes
- 175 mm standard crankset with bb
- Front and rear der
Want:
- Carbon basebar for tt bike (i.e. zipp, oval, hed)
- Deep carbon wheel(s)
- Surprise me
I am in 92618
- Brakes
Want:
- Surprise me
I am in 92618
#1745
Quoted: 378 Post(s)
Liked 1,410 Times
ISO/WTB/Trade: 9-sp Campy lockring for 12t outer cog. DONE: PBK $13.87 by Miche. free shipping.
Have:
New Campy Mirage 9-s double FD 31.8
New Campy Mirage 9-sp triple FD braze-on
Need:
DA triple FD w/28.6 clamp. Old is fine.
Have:
Need:
#1746
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Have: Campy Veloce BB 111mm for double (compact/regular). Very little use, great condition, everything still smooth.
Shimano 5600 outboard crankset. 53/39 172.5mm crankarms. With english threaded bb.
Want: Slightly used 12-25, 12-27, or 11-23 10 speed shimano cassette.
Shiftmate (10 speed campy rd to 10 speed shimano)
Green stuff.
Green stuff.
#1748
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
Also for trade.
Have: Black Thomson Masterpiece 27.2 straight seatpost 330mm.
Want: Black Thomson Masterpiece 27.2 setback seatpost similar length, uncut.
#1749
have:
RSX 7 speed STI shifter (right)
28.6 clamp-on 9spd. Ultegra front der.
Tektro Cross Top Levers
Crank Bros. Mallet pedals
want:
34.9 clamp-on front der. (as long as it works with 9 spd. ultegra group)
braze-on front der. (that works with older 8spd. DA)
left-hand shimano STI shifter
want:
#1750
Bikes: 2011 Chinese Carbon Road, 2012 Giant Talon 1 29er, 2018 Mongoose Salvo Supa
Have:
SRAM Rival Front Derailleur w/ clamp -$30
Ultegra 9-speed shiifters in good condition - $75
2005 Giant OCR (alumium frame) with 105 derailleurs/tiagra shifters (more info w/ PM) -$550
Want:
Front- double 10-speed Ultegra shifter
10-speed 11-27/28 cassette
10-speed Shimano compatible chain
green stuff
Specialized 130 or 140 Alias saddle
54cm Top tube Cyclocross bike with similar components to my OCR (Fuji, Redline, etc)
Want:
green stuff
