The For Trade Thread
#1952
Have: 3T Ergosum Team Bar (carbon) 44cm
Want: 42cm Carbon Bar (will consider Ergosum, Ergonova, FSA Compact, or other comparable shallow drop)
#1953
VeloSIRraptor
HAVE:
Sugino Comp Triple cranks 172.5 @53/39/30 w/ BB- (TH BB-7420 cartridge, square taper, 68mm shell, 118mm spindle) Plenty of life left in them- only used for 2k miles.
Specialized Alloy Rear Hub 8/9/10 speed: Perfect for building a training wheel - 2000 miles use
Shimano 9spd cassette 12-25: 1500 miles use, still in good shape. (Attached to hub in photo, will separate)
Matte Black no-name dual pivot brakes - Sexy looking black calipers, stealth build
Ultegra Brake - works well- lightly used.
MKS Sylvan track pedals- I don't think my "pretty" FG build is going to happen anytime soon, they have about 4 rides on them- excellent condition.
SOMA double toe cages w/ leather straps- same as track pedals
Selle San Marco Aspide Arrowhead- my favorite saddle, but I'm looking for a tri saddle.
Not Pictured:
56cm Specialized Allez Sport in White. Photos if anyone is interested, I'm looking for a 54 alum, CAAD 8/9 or similar... What do you have?
Wired PT softpack: the full thing less HR strap, 2.4 CPU, wiring harness, cadence sensor, CD, manual, etc
PT Pro in CXP33 rim, 32spoke build. I got it this summer and used it for a month. The computer was suffering from dropouts so I got the soft-pack listed above to replace the wiring harness. The problem has been diagnosed as probably a harness issue- but I don't know for sure. I'll include the head unit (verified functional), wiring harness (one nick wrapped in electrical tape), HR Strap, CD, Manual, etc
WANT:
54cm frame: what do you have? I'm looking to trade my 56 for something one size down and along the lines of caad8/9, BMC streetfire, I'm very open to anything you've got.
Tri saddle: what do you have?
Tri mini bars: specifically shorties, T2+ DL, FSA Vision minis, (Think ITU)
Fast-Forward seat post: 27.2, (Think ITU)
Compact Cranks: 50/34 172.5 or 170
42cm Ergo Bars: what do you have?
Look pedals & cleats: what do you have?
I'm very willing to consider other stuff, tri gear, etc... PM me
#1954
cat 5 road racer
HAVE:
-pair of LOOK keo classic road pedals grey in color w/ cleats (buyer of bike had his own pedals) about 250 miles on them great condition.
-easton EA50 wheelset. front rim is bent pretty bad outta true and dont know if it can be fixed, rear wheel is still in true and works great. 700c wheels, shimano 8 9 10 compatible has a shimano 8 gears on it currently.
-carbon fiber pro road fork with alloy steerer.
-M-wings saddle
-M-wings road stem
-M-wings road seat post
WANT:
-crank brothers MTB pedals (egg beaters, candy c, smarty)
-MTB shoes size 10 US
-M-wings saddle
-M-wings road stem
WANT:
#1955
HAVE:
Sugino Comp Triple cranks w/ BB- (TH BB-7420 cartridge, square taper, 68mm shell, 118mm spindle) Plenty of life left in them- only used for 2k miles.
Shimano 9spd cassette - 1500 miles use, still in good shape. (Attached to hub in photo, will separate)
WANT:
WANT:
What cogs are on the cassette?
I have two pairs of 42cm ergo handlebars. One is a 25.4mm clamp set of Specialized Body Geometry bars. The tops are swept back for a shorter reach. There is a scrape through the powder coat on one drop from a fall otherwise just the usual slight abrasion from the stem clamp. The others are FSA RD300 bars with a 31.8mm clamp. These are basically new (used for less than 1000 miles) aside from some very slight abrasion under the stem clamp.
I can send pictures if you are interested.
#1956
CroMosexual
edit: Felt is gone to RobbieTunes, bottom bracket still available
Have:
2004 Felt F70 frame, fork and headset in good mechanical and fair cosmetic shape. 52 cm aluminum frame with carbon fork. There is some paint missing that I believe was due to a previous owner hanging a lock on the top tube. Photos are available here.
Lots of vintage stuff if you are of that persuasion.
Want:
A 57-58 or so aluminum frame and fork, cosmetics unimportant, does not have to be fancy. I would like either something with time trialing in mind or a CX frame (for two different builds obviously) budget brands are OK too. Ideally for a TT bike I want something with a cut-away seat tube and rear facing dropouts, a Leader would be perfect. The CX bike is self explanatory, something like a bikesdirect Motobecane is fine.
-OR-
Lugged steel, Japanese preferred. Race-grade tubing, Tange 1 or prestige, the better variationa of Ishiwata, Miyata STB, or quad butted VaLite. Examples including but not limited to: Centurion Iron Man, Miyata 912 or Team, Fuji Club or Team, Panasonic DX-5000, etc. You get the idea.
Bump.
Had a line on exactly the Leader I wanted but a flaky Craigslister dashed my hopes and dreams. I'm open to offers, someone must want to trade for a nice little Felt.
In addition I now have an Italian threaded UN-54 in 118mm. I don't have any (working) Italian bikes, so pretty much anything would be more useful.
Have:
Want:
-OR-
#1957
Coastal NC
Bikes: 2004 Trek 5200 w/ Ultegra
Have a 60 cm Motobecane frame and fork, aluminum with carbon stays and a carbon fork. Also includes stock headset. Brand new, never used. Same as on this bike...
https://www.bikesdirect.com/products/..._sprint_ix.htm
Will trade for a new or used frame/fork....around size 56cm
P.S...I can include a seat post and handlebars if you need it.
#1958
VeloSIRraptor
#1959
HAVE
Mavic Open Pro RIMS Silver/ Shimano SRAM COMPATIBLE - Ultegra hub 8/9/10 speed.
- DT Brass Nipples - DT Comp Silver spokes 2.0/1.8
These are a month old, perfect shape only 100 miles on them. I got a new frame and visually think black wheels would look better on my new bike.
WANT
Comparable black wheelset (black rim, black spokes) like Mavic, Fulcrum Racing
WANT
#1960
tarck as ****
i have 2 vintage frames/bikes that i need to move along. i'd be interested in hearing what people have to offer for them. i need a wheelset and other interesting offers.
first is what i believe to be a vitus frame.
super vitus drop outs seat tube cc-54 cm
seat tube ct-55,5
top tube cc-55
rear space-130mm
frame weight 2,24kg
27.2 seatpost, english thread BB
second is a '78 or '79 Serotta Titan. this is built up as a complete bike right now, with
dura ace rear derailleur, not sure which model but works with 9 speed
ultegra 9 speed front der
dura ace 9 speed cassette
dura ace 9 speed DT shifters
ultegra 9 speed Brakeset
brand new shimano 105 level wheelset
Chris King GripNut threaded headset
campy brake levers
cinelli criterium bars, 26.0
dura ace BB
Mavic Starfish Cranks
1in threaded nashbar carbon fork or threaded serotta aluminum fork, purple
3ttt stem, 110mm 26.0 Seat tube is 56 c-c and the top tube is 55.5 c-c
it has a lot of paint damage and 2 dime sized dents, one minor one right above the s in serotta on the seattube and a deeper one on the backside of the headtube. frame checks out as a-ok to ride, no problems.
seat tube ct-55,5
top tube cc-55
rear space-130mm
frame weight 2,24kg
campy brake levers
dura ace BB
#1961
tarck as ****
i have a "patriot" chris king headset that i would like to trade for the same in pretty much any other color than red.
it's
1 1/8"
threadless
low miles
blue lower cup
silver uppper cup
red compression thingy
no CK topcap, but i have a carbon one with a blue star that i would add.
not trying to sell.
it's
1 1/8"
threadless
low miles
blue lower cup
silver uppper cup
not trying to sell.
#1962
Bikes: Kona Jake (2006)
HAVE:
* Thomson 27.2 x 330, no setback, black seatpost. Very good condition (mechanically 10/10, aesthetically 8/10 w/ the usual scuffs from attaching seatbags, clamping it, lights, etc.)
* Kona P2 cyclocross fork- canti brake only. Good condition.
* FSA SL-280 Seatpost 27.2 x 350mm- lightly used, perfect condition.
* Crank Brothers 3-hole nylon base plate with premium brass cleats- new, never mounted or used. Came with a pair of Quattro pedals but I use 2-hole SPD’s. MSRP $27
* Mavic Aksiums silver. ~2K miles, very good shape, perfectly true. Skewers and rim tape included.
* FSA RD-60 wheelset, with Bontrager Race Lite Hardcase 700x32c tires. Skewers included, no cassette. 1,600 miles on the wheels and 600 on the tires, perfectly true, no wear on the brake tracks. If you swap the front and rear tires eventually, there should be another 1,500+ miles in them.
WANT:
* 32-hole wheelset in good condition- some combo of Open Pro/CXP33/etc w/ 105/Ultegra/comparable hubs. Depending on quality, willing to trade both wheelsets above, or one and a combo of my other items if in good shape.
* Thomson 27.2 x 330 or 410, SETBACK, no preferred color.
* 2x new Vittoria XN clinchers (the gray, file tread ones).
WANT:
#1963
Bikes: Giant Trance 2, Spec Rockhopper, Raleigh Mateo
I just screwed up and bought a 31.8 clamp Shimano 105 front derailleur (5504) when I really need a braze on to work with the adapter clamp on my Trek. Anyone have a 5504 braze on they want to trade?
#1965
Bikes: 85 Nishiki Riviera GT, 69 Schwinn Super Sport(fixed conversion), 80's Olmo Professionisti, 80's Univega Mixte
62cm 1970's Claude Butler steel frame/carbon fork
I got a good deal on this bike but it is way too big for me. I'm looking for something in the 55-58cm range, Probably prefer steel but would consider aluminum, I just want a high quality lightweight fast frame, preferably with a brazed on front derailer bracket, 130 rear spacing. Ideally I'm looking for a frame and fork that I can swap all the components of my bike onto, but we can discuss bottom brackets and headsets, My bike has a cinelli headset, not sure about the BB prolly Campy. Here's what I know about the frame:
1970s vintage English Claud Butler hand-built frame, horizontal drops, it's about a 62-63cm, I'll measure it up later Reynolds 531 double-butted; Nervex lugs, custom painted with a carbon composite fork
The thing is stunning, there are almost no marks on the paint anywhere, the guy I bought it from had it painted and built up in 2002 but apparently only took it out a handful of times, I love ridding it and have been trying to convince myself that it's not too big
more pics here:
https://s429.photobucket.com/albums/q...t=IMG_6492.jpg
more pics here:
#1968
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
there's no real 'vouching' system for BF, but don't trust users who joined this month, I suppose?
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
#1969
Quoted: 98 Post(s)
Have: Lightly used Sidi Genius 5 Mega in a 46
Want: Similar condition, same shoe in a 46.5
I'm sure this is a long shot, but figured I would check it out anyway.
#1970
tarck as ****
26.8 clb silver seatpost, about 30mm setback
tall 26.8 american classic post
26.0 40cm cinelli criterium bars
165 sugino rd(?) cranks
miche 110 bottombracket, new
167.5 chimano 600 cranks
new out of package: shimano ultegra 10speed brakes and front and rear derailleurs, dura ace 9 speed DT shifters
campy brake levers, can be used as aero or non aero, white hoods in good condition
looking for: any drop bars
#1971
Crushing souls
Bikes: Trek 1500
Have:
Shimano 105 12-25 Cassette with 3k miles.
Fi'zi:k Pave Saddle, white.
Selle Itallia Flite saddle, black, with a cutout.
Cash
Want:
Gloves
Sunglasses
Drop Handlebars
Make me an offer.
Cash
Want:
Gloves
Sunglasses
Drop Handlebars
Make me an offer.
#1973
C3 H6 O3 ACID
LISTING AGAIN..
HAVE
Wheelset
Alex DA-16 Double Wall w/ Kenda Kwick 700 x 26c
Good Condition, Pics Avail.
Would be good training set
All true
Cassette
SRAM PG-850 8spd Cassette 12-26T
Probably about 750miles on it...
Pics Available
Saddle
K2 Road Saddle, w/ Gel padding and reflective rear panels
Want
16 or 24 spoke wheelset...
2XL Jerseys
L riding shorts (new please)
Front Light so I can ride to work (on dark mornings)
Size 10 road shoe, look compatible
HAVE
Wheelset
All true
Cassette
Pics Available
Saddle
Want
2XL Jerseys
#1974
Quoted: 27 Post(s)
WANT:
90 or 100 black Thomson stem, 26 or 31.8 clamp (prefer 26)..actually, any nice black road stem will work..
White or black bar tape (I like Fizik, but let me know what you have..)
Gloves (size S)
HAVE:
lots of fixed gear stuff - frames, pedals, wheelsets.
PM me
Gloves (size S)
HAVE:
PM me
#1975
tarck as ****
more parts:
campy brake levers
dura ace BB
campy brake levers
dura ace BB
