Short Cage RD NOT for triples? Really?
buy my bikes
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 519 Post(s)
Liked 429 Times
Originally Posted by Drillium Dude;[url=tel:22371876
22371876[/url]]After taking a detailed look at the rest of the bike, it seems the rider came up with a novel way of turning a rigid seatpost into a shock-absorbing one by removing the binder bolt and installing that V-shaped spring unit. If that makes sense; there doesn't seem to be any other reason for it.
Also like the brake reinforcing plate on the rear brake vice the front.
DD
DD
- not sure. Just thought that was what it did.
I mean, you can laugh at me if I’m way off here…
Quoted: 2588 Post(s)
Liked 4,826 Times
DD
Bikes: 1996 Rivendell All-Rounder, 2000 Chris Kvale, 1989 Eddy Merckx 7-11 Corsa Extra, Rivendell Clem Smith Jr, Rivendell Roadini, 86 Mercian Vincitore, 85 Vitus 979, 89 Vitus Carbone 9, 83 Bianchi Tipo Corsa, 79 Motobecane Grand Touring,2022 Corvus Rhino
Quoted: 33 Post(s)
Liked 56 Times
DD
DD
Jim
Liked 4,826 Times
DD
Quoted: 3241 Post(s)
Liked 2,512 Times
Its all a matter of whether the largest rear sprocket can be handled by the rear derailleur, and the total change in the number of links that must be wrapped by the derailleur cage are within its design capability. The rear derailleur only cares about those two parameters, not how many rings are on the chainset. The sizes of the rings, yes, but the number of the rings no. Master how all of that works and you, too, will be a master gear finagler! I'm pretty sure Sheldon Brown covers all of that, it's not so obscure or hard to find.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
If the biggest cog out back on that Salsa is a 28, a short-cage RD would prolly work just fine. If an old-school NR RD can handle a 28, why not a modern slant?
I think many people might think a long cage is needed to get all the gears, but really, who would use the smallest cogs out back with the smallest ring in front? Or big/big? Cross-chaining extremes would likely not work with this setup, but gear-smart riders know the limitations inherent in their drivetrains.
Every time I see a photo of a bike on the Forum in the big/big combination I wince a little and think "those components are going to have a shorter life than normal..."
Of course, YMMV.
DD
Of course, YMMV.
DD
Likes For thook:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
It works in conjunction with the quick release. While riding and approaching a descent, for example, flip the quick release open and the saddle drops down from your weight all the while the hite-rite clamp keep the saddle center. Saddle drops and close the release. When you're ready for the saddle to be at normal height, flip the quick release, saddle pops up, and close the release, again. Here's an article I found....
https://mbaction.com/sept-hardtales/
Likes For thook:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Likes For thook:
Liked 4,826 Times
DD
Quoted: 1858 Post(s)
Liked 664 Times
In all of this, I'm figuring out why I don't agree with a lot of the builds, as great as the bikes are. It's just my prejudices, dating back to the late i960s.
1. I don't like the chain to be slack, ever. I understand it's a choice and I did try it, but it always felt odd and was distracting.
2. I don't like to have to remember to have to avoid certain chain position combinations, such as cross-chaining. I have trouble keeping track of what gear I'm in, and my eyes haven't let me look down quickly and scope out the status when I'm beating like crazy trying not to lose too much speed on the uphill. So it's too distracting to have to worry about crossing.
3. Different makers may have different design margins relative to their stated limits. Most of us agree Campy application margins are tighter than those observed by Shimano. I have mostly Campy setups, since I've never warmed up to Shimano brifters compared to Ergopowers. But, I get really upset if I break a derailleur!
Campy's can be manipulated somewhat: a lot of us have used 13/28s with Campy NR which at least in early releases seemed to have 26 limits, and a local shop here tweaked one of my setups to accept a Campy 12/30 10v cassette when it was stated only to run over their 13/29 range, I think they added a link pair and increased wheel setback in the dropout. But they got it done with no looseness. Expensive frame and I was reluctant to risk the chainstay integrity.
So I need to focus on the riding and matching my pedaling to the road/wind conditions. Rather than learn to worry about geari system limitations other than range, I like to set up my shifting systems, downtube friction or Campy Ergopower 10s triples, to go where I tell them right away no matter what. Then I can just maintain the flow as well as my meager muscles will let me!
That's why I never advocate over-limit derailleur systems, because I don't like to deal with the effect of the limits or worry about breaking my stuff. But it is your choice to accept limits in your shifting systems, if it turns out they have any. I've seen all the "textbook" ones and I don't want to accommodate them.
But I prefer to stay within my criteria - observe the limits that derailleurs are made to operate within: maxcog and chain wrap capacity.
Likes For Road Fan:
Liked 664 Times
This right here. It's easy to figure out what size sprocket the RD will take. The upper jockey wheel will start hitting the sprocket when you've reached the limit. Now you have to fiddle with the chain length until you get something that works on both ends. Also of importance is the cage length of the FD. If it's too short, the chain will drag on the cage plates bolt while on the small ring.
With an extreme front spread like 40/20, some experimenters like Jan Heine have designed short, stout cages to push the chain around and stay free of the chainstay (big chainstays, wide tires >42 mm and low, 8 cm BB drops) and achieve very low Q-factor for his randonneur bikes. So it's also a choice to go back to such 80-year old designs (Herse, Alex Singer, and other French constructeurs in the 1940s, plus innovators like Hirose), relying on modern chainrings and chains to assist shifting the wide range.
But this is pretty costly, being nearly 100% custom and shop-made.
Likes For Road Fan:
Quoted: 765 Post(s)
Liked 660 Times
No one rides around in the big-big on purpose, but even smart people make mistakes sometimes. If you shift onto the big-big without meaning to and the chain is too short, you're going to break something, and maybe hurt yourself. A slack chain in the low-low combinations is not ideal, but it's not really a safety issue. I cheat that way all the time, but learned the hard way about making sure the chain can handle the big-big. Even though, you know, you're never going to use the big-big. Except maybe that one time.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 2339 Post(s)
Liked 2,831 Times
Sure enough end of ride on a MUP and had to deal with uphill and combo of clueless adult, kid, animal and oncoming idiot on an electric fat tire bike, and slammed it into big/big without thinking.
Immediate stop, but was going so slow I was able to reach out, and grab lean on a fence and clipout. at speed it would not have been pretty
Likes For squirtdad:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Snarky? Yeah...somewhat. But, I mean no real harm. Disingenuous.....not really. I'd read some blog and participated in a few threads over the years about the idea of running a short cage with a triple. It made sense to me theoretically, at least, why it could be a good idea and how to get away with it. But, by and large others's opinions were it was stupid idea and served no real benefit. Well, that may all be true, but I had no idea there was a time pro's were actually doing it and that it had been an industry trend...even if only for a short time...and was surprised to find out. I was under the impression it was a more recent hack idea going around to try and eke out a little more performance. So, was is it just an expirement that was appropriately short lived? Does it really make a difference? I don't know. I"ve never tried running the set up...yet. I'm considering it once again. It does look pretty slick, too.
Le Crocodile
Quoted: 370 Post(s)
Liked 788 Times
DD
DD
As the brakes became more powerful, sometimes the reinforcing bridge became necessary on the rear as well. You could plainly see the seat stays flex (some frames) out under braking and get this horrible squeal.
ETA- Got beat on the explanation
Likes For Erzulis Boat:
Le Crocodile
Quoted: 370 Post(s)
Liked 788 Times
Correct. I had the XT setup, and the box it came in specified "Medium". You had a very narrow window to get the wrap/capacity right, and I recall seeing what happened with too much/little chain for the setup. I wore mine out, and then went to a long cage XTR.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
For funsies...a couple more short cagers...
Quoted: 1324 Post(s)
Liked 927 Times
Isn't this why Suntour came out with their triple-pulley rear derailleurs design? The two upper pulleys acted as a short cage rear derailleur and then when in the lower gears the forward lowest pulley would take up the chain slack.
Cheers
Cheers
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
Anyway, probably this will bore anyone here reading this thread, but my Ross mtb started getting me to thinking about doing some mod's on it. It has Suntour XC Sport derailleurs, and I've mentioned this above, but the front derailleur cage drags the chain, so I had to use a smaller outer ring to enable me to lower the front derailleur. Originally when I acquired the bike, I couldn't use any of the cogs except the largest when in the granny before the chain would drag. So, I'm thinking if I can use a 42t ring as the outer ring, I could drop the FD even lower and have a chainset of 42/34/24 and a tighter freewheel or cassette cluster in the back. Like 13-26/28 or 12/26...something like that. Or, cutting things up even further. 42/28 and 13/30 freewheel.Then, I thought after running across the Salsa website maybe I could use that 6000 medium cage because the total capacity would have dropped closer to the 6000's factory range. <<<blah, blah, blah>>>....lol! I don't know. Just messin' around, but it'd clean up the drivetrain removing some redundant gears and give smoother shifting
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Well, the whole reason I started the thread was kind of in light of that. You can read all over the BF subforums about never using a short cage with a triple...or simply never exceed the total capacity. Which I get. There are inherent issues....one of them being potentially injurious. But, I never make big/big or small/small combo's.
Because I do club rides and long brevets that impair my cognitive abilities, I include myself in both the "clever" and "idiot" categories. Toward the end of a 1200k, I don't want to have to remember not to use the extreme gear positions, because that's when I'd accidentally shift into them and blow up my bike. So my drivetrains are set up so that any gear combination works (chain rubbing on the FD cage is non-fatal, so counts as "working" here.) If I need wide enough range, I'll suck it up and install a long-cage rear derailleur. My Deore 7-speed ones shift just fine.
One idea that comes to mind for squeezing more capacity out of a short-cage RD is to install larger pulleys. After all, that's how the big 3 are doing it. You might have to bend derailleur cage tabs out of the way -- or remove them entirely. (EDIT: in the long time it took me to compose this post, you already got to the larger pulleys idea. )
RUSA #7498
Originally Posted by noglider
Likes For ThermionicScott:
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
It's one of those things where it's fine if you know what you're doing. But sometimes we can tell a poster is in over their head and doesn't really appreciate derailleur capacity, or remembering not to use certain gear combinations, so the simplest and I'd argue most responsible thing is to say "no, don't do that."
Yeah, I do know that's the responsible thing to tell "no..don't". Again, I was just surprised to find pro's were actually doing it. Question is, does a short cage really even shift different enough to justify using one instead? I wouldn't know since I've never actually used one on any of my bikes
Quoted: 1830 Post(s)
Liked 3,383 Times
+1 on this. I did a new build and did the chain a bit too small and too late to get another chain, but was excited to try the build.... so I went out knowing big/big did not work and was sure I would not go there.
Like anyone, I hope that I'm a rational person at least 90% of the time. However, I also know that my brain gets distracted now and then, or just starts shutting down due to environmental stresses (heat, hunger, etc) and that is when I'll do something stupid. Better to plan on that "stupid" happening now and then, and making stuff as stupid-proof as possible than to expect myself to be smart all of the time. We all know how that works out!
Steve in Peoria
Liked 4,826 Times
In my experience I've seen it quite often. I notice it because the drivetrain is quite noisy and when taking a look to determine the cause: big/big. Often it's a rider who should know better
YMMV. Just calling it as I've seen it.
DD
DD
