#7401
Quoted: 2588 Post(s)
Liked 4,824 Times
Looks like the correct pedals for the year - right down to the shape of the cage. Later versions (probably CPSC change-mandated) had softer curves at the quill; yours appear to have the earlier, pointy quill.
I took this pic long ago to illustrate the slight difference in quill shapes:
DD
#7403
Quoted: 876 Post(s)
Liked 2,292 Times
Funny how that works
DD
DD
Likes For Kabuki12:
#7404
Liked 4,824 Times
Cool - that looks as though it also works for cog removal! I'd be pretty stoked to add one of those to my toolbox
DD
DD
Likes For Drillium Dude:
#7405
Quoted: 4512 Post(s)
Liked 6,387 Times
I took this pic long ago to illustrate the slight difference in quill shapesD
#7406
Liked 4,824 Times
^ There's been lots of stuff about pre/post CPSC changes to Campy NR/SR components on BF C&V; I wanna say the mandates took effect in 1979. A search would confirm, tho.
EDIT: 1978, according to Velo Retro
"1978 C.P.S.C. (Consumer Product Safety Commission) mandates changes to NR/SR. Included are a front derailleur lip, 2.5 mm increase in spacing between crank spider and arm to clear the front derailleur lip with corresponding increase in bottom bracket axle length, a curved quick release lever and ball-end added to quick release conical adjuster, dome-shape added to quick release cam lever on brake calipers, plastic covering added to the wheel guides on the brake shoes, and plastic safety-shields added to rear derailleur screws. The word "Patent" is changed to "Brev." on the chainring, chainring bolts and crank dust caps. Down tube shifters with bumpy edges and raised letters changed to thicker, smooth edged levers with sunken letters. The Super Record rear derailleur has aluminum pivot bolts substituted for its titanium pivot bolts 1978 and 1979, apparently because of a titanium shortage."
Interestingly enough, there's no mention of the pedal differences here (which also included a more rounded kick-tab as well), but I'd be willing to bet they've simply been overlooked by VR. The changes are pretty subtle.
DD
DD
#7407
Likes For fabiofarelli:
#7408
Edumacator
Quoted: 2440 Post(s)
Liked 3,130 Times
Mercian arrival
Issues withstanding, Jdawg is in love. Merida Mercian hjas arrived (yes, all my bicycles have non-neutral alliterative names). Wears green with golden hand lined lugs and matte paint. Delicate decals.
Pictures in its own thread.
Likes For jdawginsc:
Likes For cv350:
#7410
Quoted: 834 Post(s)
Liked 2,127 Times
I've been eagerly awaiting this Campagnolo Italian-threaded Record triple BB from France. It was advertised as used. It came without a box, but it looks NOS to me. No marks on flats or any residue on threads, and the cups look pristine.
Likes For gaucho777:
#7411
Bikes: 1976 Schwinn Super Le Tour 12.2, 1982 Bianchi Sport SS, 1986 Schwinn Super Sport, 2018 Fuji Jari 2.1, 2018 Advocate Cycles Seldom Seen, 2019 Brompton H6R
A frame pump that was shipped loose in one of those white plastic USPS baggies. No surprise it was badly bent.
Likes For Wheelgunner2:
#7412
velo-dilettante
Quoted: 1628 Post(s)
Liked 3,114 Times
‘23 installed.
#7413
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 750 Times
Merz lightweight parts!
Getting parts together for my next build, which is a '79 Raleigh Team 753 SBDU bike, frame currently at the painter. I'm going for a lightweight build on this one, and Jim Merz put together some parts for me, including alloy barrel adjustors, titanium Cinelli stem pinch bolt, titanium Super Record seatpost bolt, titanium Super Record nuts and washers, alloy SR rear derailleur bolts, and a titanium/alloy brake center bolt (to match another one I have, made by OMAS).... beautiful craftsmanship by Jim, expensive but worth it to me!
#7416
Quoted: 1608 Post(s)
Liked 2,216 Times
I was a bit disappointed in the Racing T tooth count. Started looking occasionally for alternatives and found a guy in the UK who is selling NOS rings at the price most others on the bay charge for one.
How did this get upside down?!
#7417
Liked 6,387 Times
So cool.
Nothing better than made by the best.
#7418
Quoted: 1303 Post(s)
Liked 1,912 Times
It was a good week for MH and the Postal Service. I received a pair of calipers, and a bag of parts to bump up the stash pile.
They need some TLC but should work fine on a period correct build. Now to find some brake block holders...
Box of junk to most but the small parts in the center of the pic are kinda pricey if I needed to buy them one item at a time. The cage plates on the lower left are selling for $30 each on flea bay. The super vintage parts on the right side, are going to be looking for a new home.
#7421
Quoted: 753 Post(s)
Liked 737 Times
Most recently I found a 170mm Ritchey Logic 110 crankset and 4 volume set of Barnett's Manuals. Also got a 30.2/27 Tange Levine headset. I'm having trouble finding any one local with the proper facing and reaming cutters. 30 years ago, some one "cut" a corner.
#7422
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
Yay, I've been looking for some clincher rims since I've only got those new fangled tubulars at the moment (on Mavic Monthlery Route).
Mostly because I could fix clinchers on the road side 40+ years back, but haven't tried fixing tubulars yet.
It's also very windy outside and I need something to work on
I also want to try wheel building so I'm going to respoke these, probably on the hubs they came with.
Mavic MA2 for £47 on Ebay:
They look fairly OK, but I haven't cleaned them up and checked for cracks yet.
They're 32 spoke, would have preferred 36 spoke, but they did come with a set of Shimano RX100 hubs (8 speed):
The rear hub is FH-A551 which is 130mm OLD 8 speed, but according to https://www.bikeforums.net/classic-v...b-success.html
I may well be able to adjust it to 126mm OLD with the 8 speed cassette (or 9, or 10).
The cassette also seems to work, it's 12-23, so Shimano CS-HG50-8 U or SRAM PG-850. But that's going to get replaced since 23 is too small.
Likes For Aardwolf:
#7423
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 348 Times
My first jersey, from Oregon Cyclewear.
Likes For philpeugeot:
#7424
Bikes: Condor, Cinelli SC, MKM Metcalfe, Peugeot AE08, Bianchi, Cougar, Miyata, Harry Hall, Holdsworth Special, Raleigh Int'l, Le Croco, Bob Jackson, Zeus
Quoted: 114 Post(s)
Liked 102 Times
The Nitto rack arrived a couple of weeks ago but the Acorn bag and tool roll arrived today.
Front rack and bags. by bj.stevens, on Flickr
They are destined for this:
1986 Miyata 610 by bj.stevens, on Flickr
Cheers.
Brad
Cheers.
Brad
Better bike .. Better life!
Likes For Stevensb:
#7425
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,927 Times
It came but I’m too tired to open it and ooh and awe. It was a long day and I made it back to the terminal on fumes, putting 96 gallons of fuel in a 100 gallon tank. To top it off I wasn’t even home yet and got my Iwatch bedtime reminder
Sugar "Kane" Kowalczyk
