Disc Brake Conversion
Bad example
Quoted: 847 Post(s)
Liked 263 Times
I'm honestly not sure, but I suspect it was the geometry.
Can't see why I would be any more likely to lock up a disk than any other brake. As for slowing down, I can attest that the rear brake on my disk brake bike offers a decent amount of stopping power. Not as much as the front, but it definitely works, and better than rim brakes when it's wet.
That's great if you want to lock up the rear wheel while not slowing down much.
Quoted: 520 Post(s)
Liked 461 Times
* I'm ignoring off-roading, particularly DH MTB, as this discussion seems to be road-based.
Bad example
Quoted: 847 Post(s)
Liked 263 Times
Presumably you're fitting a disc brake to improve this ability, unless you're heavy touring or riding a tandem in hilly country in which case a drag brake may be useful. Sure the back is useful on less ideal surfaces, but it's really not going to stop you in a hurry, and any attempt to do so is likely to test the tyre's grip; a good rim brake should be able to exceed this already. Riding in wet weather? Use good brake blocks and wipe the rims before you brake harder.
Likes For Aubergine:
