For the love of English 3 speeds...
Bikes: 2016 Linus Mixte 8, 1987 Schwinn Voyageur
Quoted: 22 Post(s)
Hello knowledgeable people. I've put a 22 tooth cog and new tires (Schwalb Delta Cruiser) on a 1974 Raleigh Sports and am also putting on a new chain.
My problem: If I push the rear axle all the way back in the dropouts, the rear tire rubs on the fender in the back. Is it safe to have the rear wheel further forward within the dropouts so that the tire doesn't rub?
I can see from a circular wear pattern in the paint that, maybe for this reason, the previous owner had the wheel far forward, almost to the end--or is that called the beginning?--of the dropouts where the wheel would drop out. Is that safe/acceptable?
Quoted: 887 Post(s)
Liked 335 Times
Quoted: 22 Post(s)
Thanks! So as long as I tighten the bolts there's no safety reason why the wheel needs to be all the way back in the dropouts? Basically I don't want the wheel to fall out while I'm riding, that's my fear. eeks.
Quoted: 1299 Post(s)
Liked 103 Times
It's hard to stop riding in this fall weather. Back to work after some coffee. I did remember to bring my phone along today. I tend to stay in out of the way places, not much to see. I guess I'll never be a photographer like some of you here. Still, here's the roadster on a couple of my favorite roads.
Bikes: Too many 3-speeds, Jones Plus LWB
Quoted: 359 Post(s)
Liked 274 Times
If the nuts are tight the wheel isn't going anywhere and it can't fall out at any rate.
Quoted: 22 Post(s)
The extra room is there so as the chain wears you can move the wheel back to tighten it up. When the chain is properly set you should be able to pick up the middle of the chain about 3/4".
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
https://www.amazon.com/KMC-Bicycle-C.../dp/B00HZ8PAQY
I've used these successfully on a couple of my 10-speed to IGH conversions. They work fine.
Quoted: 359 Post(s)
Liked 274 Times
An additional note- as pointed out earlier, if the wheel goes all the way to the rear of the dropout your chain is too long; as you noted the wheel runs into the fender.
You'll need a chain link removal tool to get the chain to the right length. There is a bit of a technique to it! So I would practice removing and installing links on the old chain if its still around (youtube is your friend), otherwise get someone to show you how to use the tool.
Quoted: 22 Post(s)
Liked 103 Times
Correct-- window shifter is 1950s era.
1938-48 is the long lever:
1948-49: the uncommon "silver" or "black" solid face (two types)
Starting around 1950, and for much of that decade you see a variety of window shifters with various faceplates. They indeed were plated to start with, and lose their plating easily. If you have the short lever, window shifter, it's 1950s-era.
See: https://genetics.mgh.harvard.edu/hanc...satriggers.pdf
for an excellent resource.
Bikes: Vilano Urbana, DownTube FS9, Montaque paratrooper, Nano mini-velo, Motobecane CX, Raleigh 20, MIFA folder, ROG Pony, Iverson Grand Touring folder, Exclusiv German folder
Quoted: 168 Post(s)
Liked 192 Times
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 375 Post(s)
Liked 886 Times
They look nice, but I do think the short lever shifters from 1948 through the 1950s (silver/black face solid and window face) work better. The window shifters really are a functional wonder when you find one in good shape.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Liked 103 Times
I have early 50s 3 or 4 speed window shifters on my roadsters now and I think they're perfect for rod brake bikes. The lever isn't as long as this very early one, but it's longer than the late 50s on type. I can position them in a very comfortable position for me. The one on my 72 was a rusty mess when I took it off a salvage bike, but it cleaned up nicely and as unlikely as it sounds, I found someone selling NOS replacement leaf springs on eBay. Works beautifully. They are nice shifters.
Overdoing projects
Quoted: 784 Post(s)
Liked 1,263 Times
Not exactly vintage-approved, but I do get excited from an engineering point of view about this:
Ginko feine veloteile and their heatsink modified SA+ brake hubs.
That and a ton of small tuning parts for Sturmey Archer brake hubs.
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1030 Post(s)
Liked 444 Times
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Those are excellent shots! Wow, the leaves there are much farther along in the color cycle than here in MN. Although I suppose it probably looks the same up north, like Ely or International Falls. I have yet to take any Fall Colors shots. Better get busy this weekend.
Nice path racer! Can't beat a DL1 for that - the rod brakes really stand out.
Quoted: 231 Post(s)
Liked 10 Times
Larger rear cog / chain guard issues.
I got a 22t to replace the 19t on my 1969 superbe. I am having issues with getting the frame tabs for the chainguard to line up with the holes on the chainguard. IS there a trick here? I might just leave the guard off. ITs kind of pointless. The screws/nuts for my chainguard are gone as well. Figuring they are witworth threaded i would probably just get smaller ones that fit through the hole with washers and nylon nuts....but at this point i cant get it to line up wiht the holes. Perhaps some spacers between the guard and the tab would do the trick.
Bikes: 1965 Dilecta Le Blanc, 1956 Royal Nord, 1972 Raleigh Sports, 1972 CCM Turismo,1976 SuperCycle Excalibur, 2014 Salsa Vaya, 2017 Felt DD70, 2019 Giant Lafree and others
Quoted: 351 Post(s)
Liked 606 Times
Enjoyed the mild autumn weather today with a ride to the coffee shop with my sweetie and riding the '79 Raleigh DL1 known as "Sir Wayes A. Tonne" The Radio Canada CBC backpack does duty as a bike bag. It has taken a while to get all the bugs out of this one, but SWAT is becoming my favorite "townie".
We are what we reflect. We are the changes that we bring to this world. Ride often. -Geo.-
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 152 Post(s)
Liked 177 Times
Liked 103 Times
The trick is to tighten NOTHING down until you've gotten all the screws in place. Give yourself plenty of slack to wiggle things into place. I had similar issues on a R20, wondering what the hell happened that the guard didn't fit anymore. It'll fit, but you'll need to adjust things as you go to get them into place.
Abuse Magnet
Quoted: 152 Post(s)
Liked 177 Times
Quoted: 887 Post(s)
Liked 335 Times
@browngw
Like the DL-1. Does the bag interfere with the wheel?
Quoted: 351 Post(s)
Liked 606 Times
@browngw
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
Of course, it would help if I took the loaded down bags off first...
Great photos!
