Addiction 2022.1
#7476
Quoted: 9656 Post(s)
Liked 6,366 Times
So...My tail light hasn't shown up despite Amazon saying it was delivered to my office on Monday. I checked tracking information and confirmed after a call with Amazon that it was delivered to the USPS on Monday. In my experience, that adds a few days to the delivery time despite the USPS saying it was delivered. Amazon refunded my money. I suspect the USPS will deliver it today or tomorrow.
So much for convenience.
#7477
Quoted: 18429 Post(s)
Liked 15,583 Times
lplo
#7478
Liked 15,583 Times
I light it with a Loof Lighter (LOOFT Lighter I LO1-US (homedepot.com)). If you haven't ever used one of those, you might give it a look. No fluid, paper, or chimney required.
Maybe I will try Amazon. Might end up getting it for free.
#7479
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12790 Post(s)
Liked 7,698 Times
Non Porsche non ass pic of the day, aeronautical edition:
Likes For LesterOfPuppets:
#7480
Liked 6,366 Times
It's basically a really hot heat gun. I've been using mine for over 8 years.
#7481
Liked 6,366 Times
Such a cute pump.
#7482
Fat n slow
Quoted: 3259 Post(s)
Liked 2,085 Times
If you're doing the one-bike solution, rather than moving PMs among multiple bikes, and you want to have pedal flexibility for road and off-road, I think that going crank-based makes a lot of sense (I personally wouldn't do the Stages/4iiii route, though, unless they've gotten their DS problems straightened out recently).
#7483
So it is
Quoted: 11407 Post(s)
Liked 4,761 Times
#7484
Quoted: 10238 Post(s)
Liked 5,189 Times
48 degrees is that temperature where I don’t know what to wear. My castelli thermal jersey would be perfect but with the effort I will be putting out I am sure to over heat. Jersey might not be warm enough. Do I wear shorts? or long tights? I think I M just going to bring my whole collection and figure it out later. I only have heavy gloves or my summer fingerless gloves. Race was originally 40 mins long and now it’s 30. Originally I didn’t care about trying to place, but now I really want to win. Or podium, I just don’t want to kill myself doing it, and I have no strategy at all, other than try and get into the front pack early and if a group breaks away stay with them, I don’t plan on chasing a single person making a breakway attempt.
#7485
Liked 5,189 Times
Perfect thank you. I meant to look at the last race I went to watch and completely forgot about it.
#7486
Klaatu..Verata..Necktie?
Quoted: 10444 Post(s)
Liked 11,925 Times
"Even a blind pig finds an acorn once in a while"
Wordle 257 2/6
Wordle 257 2/6
#7487
Liked 6,366 Times
You've got too many things on your mind. Pick your one focus, and don't let distractions get in your way.
I've never raced a bike, but have raced other things, and know that any type of indecision will sink you.
#7488
Liked 11,925 Times
Shorts, short gloves, and jacket - in 30 minutes you won't overheat that quickly.
#7489
Fat n slow
Liked 2,085 Times
#7490
Fat n slow
Liked 2,085 Times
So, my chain was doing that jumping **** again. A few of the links seemed stuck and it was happening on a number of different gears. The chain doesn’t engage and slides over the top of the cassette.
was climbing a small hill and everything let go- the quick link failed- it was fully and properly engaged and one side snapped while the other bent in half. This was the first use of that link.
I may just give up on this wax nonsense and go back to drip. I don’t want to, but this is a major ass pain.
I’m chucking every Shimano quick link I have (bought them all from Bezos)and solely using the YBN links I picked up with a chain
#7491
Fat n slow
Liked 2,085 Times
WhyFi you’re using Power2max right? NGEco?
I can directly replace GRX w/ same spacing with a 24mm Rotor crank.
#7492
Liked 6,366 Times
Of course, my skinny quads only put out about 20w on a good day.
#7493
Liked 6,366 Times
In my quest to improve drive line efficiency to offset my poor motor (yep, I know!), I indulged in some BBinfiniti ceramic stuff, including 12/12T pulley wheels . Went that route so I wouldn't have to buy longer chains.
Instead, they sent a 14/12T set. Not sure if I can use those with my current chains. Sent an email to BB, but have not heard back yet. Anyone know the answer to the question of whether moving from 11/11T to 14/12T in the stock 105 cage will require a longer chain?
#7496
Liked 11,925 Times
I had an SRAM PC-870 QL problem in building the Litespeed. When I put it together with the Sachs/Campy Frankengruppo, it went together without a problem. I tried to reuse the chain and QL after I'd rebuilt it with the 7410 DA group, and it was hopping everytime it went through the RD. I traced the problem to the QL, which was acting like a stiff link, but I couldn't fix it. I finally ditched it and went with the original, lightly used 8-sp chain I'd taken off the Ritchey when I converted it to 10 speeds. It also has a QL, but that went on with no problem. So, now I have a basically new SRAM 8 speed chain that's cut real short, and no QL.
#7497
Liked 11,925 Times
#7498
So it is
Liked 4,761 Times
#7499
Liked 6,366 Times
#7500
Liked 11,925 Times
I have a Lezyne Road Drive minipump that actually works really well. The only problem is that it takes FOREVER to fill a 28, and 28s are what I run on both of the bikes that won't hold a frame pump.
