2016 Post Your Singlespeed/Fixed Gear Megathread
#651
Quoted: 230 Post(s)
Liked 18 Times
2014
2015
2016
all you'll cowards don't even smoke crack.
1cm shorter stem, Tektro levers, box added back on, paint fell off steel crank, left crank fell off and replaced with alu, new seatpost, seatpost actually raised high enough to fit me in the photo, some rust.
Maybe in a couple months I'll give it a good going over and replace the saddle and luggage rack with better ones.
2015
2016
#652
Quoted: 18 Post(s)
Cinelli compact drops. Here's where to get some.
https://www.retro-gression.com/colle...drop-handlebar
#655
Clark W. Griswold
Quoted: 4424 Post(s)
Liked 4,069 Times
#657
Haven't been here for a while.
2nd and 3rd build of 2016:
#658
Bikes: Not As Many As I'd Like
Quoted: 16 Post(s)
thanks!
oooo, I'll have to see if i can find some ritcheys. Good tips.
fuego, as always....
#662
Bikes: Are awesome!
Bikes: stinner cx, paramount track
Quoted: 262 Post(s)
Liked 9 Times
lovin that viper call out up at the top of this thread.
schools for suckas, my hood is tha real test part two.
#667
Steel N Slicks
Bikes: 1
Custom Pepper white Cartel 'Avenue Lo'
Through my work I get to come across some nice custom bikes like this one...
The full spec can be found here:
Friday update. | Cartel Bikes
#669
Pedal On
Bikes: I ride 'em!
Quoted: 5 Post(s)
Liked 18 Times
Just built this one up, my first "from-scratch" single speed. 1987 Mongoose Alta. Full cro-mo frame, fork and stays, and lots of braze-ons to boot. The horizontal dropouts were begging to be converted and I happened to already have a SS freewheel and short stack chainring bolts from another aborted project. I re-spacered the rear hub and re-dished the wheel,and as luck would have it, that lined up the freewheel pretty much dead-nuts with the outside chainring. Running 48t in the front and 20t in the back, giving 62.4 gear inches. I just went for a long ride around town and I think this just about perfect--low enough for get up and go, but high enough to achieve a little speed while spinning. Michelin Country Rock tires are a nice mix of road smoothness and grip on light dirt/gravel. Really happy with this one!
#673
Decrepit Member
2010 Schwinn Sprint with 853 main tubes.
