Commuter Bicycle Pics
That Huffy Guy
Bikes: Old School Huffy Bikes
Quoted: 79 Post(s)
Liked 6 Times
It used to be a bicycle............
https://www.bikeforums.net/commuting/...tml?highlight=
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Doesn't look like 5 years of use, very clean! I like the brownish purple, a little splash of color without going overboard.
Bikes: Giant Escape 3 (2015) - stolen, MASI Superare 2018, Bianchi Pista 2012
My Giant Escape 3. Just over 1000 km at the moment. Definitely gonna add a rear rack and another bottle cage.
cheers,
Lin
cheers,
Lin
Bikes: Marin Bolinas ridge, Carlton Corsa 5, Falcon Olympic 12, 98 Shesh Rockhopper,
Quoted: 88 Post(s)
I ride 700 x 35 Marathons on one commuter and 26 x 1.95 marathons on the other while they are heavy compared to other tyres, I would not go back to 28c as I used to ride . . .like the comfy ride.
Bikes: 1974 Gitane Tour de l'Avenir, 1975 Gitane Racing Team, 1977 LeJeune, 1988 Herrera, 1990's Ronson.
Bikes: Giant Escape 3, Giant Boulder MTB
Just Picked up a Giant Escape 3 from my LBS at their recommendation for my budget and needs , i know its the base model of the escape series . but after a couple rides im Happy with it... coming from a Giant boulder mountain bike its way lighter and faster , and handles the cracked up roads quite well . Going to add fenders, a rack (maybe panniers ) and comfort grips soon and maybe change the saddle to something more comfortable and a bike computer , Added already : replaced stock pedals with smoke gray platform pedals , added burgundy water bottle cage i had on my old bike, gives the bike a little color ... im looking for some comfort grips with bar ends that same burgundy color . and maybe add a burgundy chain to complete the theme ...
Here's mine: Late 1980s Bianchi Strada. Replaced the Biopace, added a new saddle, rack and panniers, pedals, Gatorskins. Well over 4000 miles on her.
Bikes: Breezer Uptown 8, Fuji Tread, Montague Navigator
Here is my commuter.
The panniers allow a quick transition between my bike and the rest of my commute.
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
Quoted: 79 Post(s)
Quoted: 686 Post(s)
Liked 5 Times
It's not really about the length of the chain but the thickness. Usually a fixed gear chain will be much thicker than a geared bike chain.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
It's an issue of width.
Single-speeds/fixies use I believe the oldest chainwidth standard, same as the old ten-speeds (5 cogs). As manufacturers squeezed more and more cogs into cassetes, up to 11 now, the spacing got narrower, and the chains had to get narrower. A colored single-speed chain would not fit between cogs to drive your rear wheel. Unless you could find a presumably 6-8sp chain that was colored, but as PGRS noted, colored chains are typically blingy fashion accessories for hipster ss/fix bikes
Quoted: 686 Post(s)
Liked 5 Times
All depends on how much you'd like to spend.
Fair Wheel Bikes has a wide variety of chains.
11spd red chain, $160
https://fairwheelbikes.com/kmc-x11sl...ede9a39bdd025a
10spd pink chain, $85
https://fairwheelbikes.com/kmc-x10sl...ede9a39bdd025a
Edit: just remember, they all turn black after a little lube and road grime.
Quoted: 7351 Post(s)
Liked 2,479 Times
No, ten-speed bikes (with 5 cogs in rear) use 3/32" chains whereas bikes with single cogs in the rear (one-speeds, three-speeds, etc) use 1/8" chains. The 1/32" difference in width makes a big difference in durability. So does the fact that you don't shift a 1/8" chain, as shifting causes wear.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,433 Times
Fair enough. Either way, (cheap) colored 1/8" chain would never work with the cassette he's working with on that Giant.
Quoted: 676 Post(s)
Liked 13 Times
Yeah see, $85-$160 for a colored 10/11-sp chain, vs. about $45 for the gold Ti-coated KMC 10-sp chain I run on my road/commuter bike. There are much better and more cost-effective ways to bring color to your bike.
*edit* wow the prices are astronomic on that FWB site. Amazon has this black/red 10-sp chain for $73, still way more than I would pay for a chain, though. https://www.amazon.com/KMC-X10SL-DLC-...ords=kmc+x11sl
Liked 2,479 Times
And it's only a matter of minutes before any chain turns black.
Quoted: 686 Post(s)
Liked 5 Times
*edit* wow the prices are astronomic on that FWB site. Amazon has this black/red 10-sp chain for $73, still way more than I would pay for a chain, though. Amazon.com : KMC X10SL DLC Bicycle Chain (Black/Red, 1/2 x 11/128 - Inch, 116 Links) : Bike Chains : Sports & Outdoors
Fork and spoon operator
Bikes: 2013 Surly Crosscheck, 1990 Schwinn Impact, 1973 Schwinn Continental
Quoted: 37 Post(s)
Liked 11 Times
This is my main commuter at the beginning of the spring. It's a '13 Surly Crosscheck. I have it set up 1x8, with a Surly stainless steel 38T chainring on the front. The tires are Schwalbe Marathon, 32 mm. The pad on the top tube is fake leather bar tape. I just changed the front brake housing, and didn't have any brown bar tape left, so I put on the green. For now I kind of like the two-tone look!
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
I'm slow, go around
I'm slow, go around
