Running vs Bike riding energy expenditure
#101
Quoted: 590 Post(s)
Liked 445 Times
My longest ride was 325 miles in 24 hours (mostly solo except for 2 hours at the end when a friend showed up to finish it with me, and let me draft at 19-20mph). For the next few days it felt like the front of my quads were stabbed with a Rambo knife, although oddly my sit spots were fine. Most people don't even like being awake for 24 hrs, let alone riding the whole time.
I don't think recovery time is a good criteria to compare marathons to centuries, since the impacts (high vs. low) are so different. What I want to see compared is likely the "sustained max/avg heart rate" of the athlete who has done a tough 3.5 hr marathon, and who has also done a tough 5 hr century with their avg. HR in the same zone for both events, and then see what the durations/paces of the two events were.
#102
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
As a non-runner I've only heard about the extended recovery time from marathons (compared to centuries), but isn't that due to the high impact pounding that the knees take as opposed to the energy expended?
My centuries are all solo and never flat, and I think I work pretty hard to get them in under 6 hours. Congrats on being that fast, sincerely.
My ankles are too bad to even consider running a 5k, let alone a marathon so I really can't compare on the effort aspect of things. But I definitely think it is the general stress on the joints of running that makes the recovery time so much longer. Basically, marathon runners need to actually heal stuff afterwards, bicyclists, not so much.
And yeah, I've done 12 hour rides in a day and weekly centuries, and I'm pretty much like you in the pain department after a really long ride. My butt's fine, my quads are mad at me and are going to tell me about it. They can be achy for a couple days afterwards, but nothing debilitating, and I'll be able to ride the next day if I want to. Generally, though, my weekend routine is a solo century on Saturday and 50 miles on Sunday. No way would I be able to do something comparable in terms of hours running.
#103
Quoted: 3241 Post(s)
Liked 2,512 Times
On the bike, I don't really cramp badly, except on this ride. Even with a 28t triple and a 28-30 big sprocket on the back , I cramp like clockwork on the 13-14 mile climb. Once on the first half and once before the top. The best I've ever done is one year when I was within 100 yards of the midway SAG. The fast twitch muscles can't take cranking away for 2 hours at a time. After that, I'm good for the rest of the ride. The 75 route wears me out more than the 100. The 100 gives you a chance to spin the legs out some. Once I get home, I can barely walk and can't run for 3 or 4 days. My legs are so stiiff/pumped/full of lactic acid that I have to go to the gym and swim. I also get on a stationary bike with no load and spin to get the lactic acid out. It takes about a week.
Where your knees/ankles will get sore is if the run is really flat with no terrain changes. Then your droning along using the same effort/cadence/muscles. You need some terrain changes every so often to change the body load.
https://www.ymcacva.org/100-miler-century
#104
Liked 2,512 Times
I actually took up cycling, then running in my mid 40's.........because I couldn't play basketball/court sports anymore. I have always swam. I got Plantar Fasciitis and couldn't get rid of it. I was an all arounder and played baseball/basketball at the college level. I had to quit that level after 2 years because of patella tendonitis. I kept playing at the rec level till I quit with not other injuries. The running cured the Plantar and no problems since then. I'm 56 now. 10 marathons and 50+ 1/2s, 10ks, etc. I looked at my data the other day. I've logged almost 6000 miles since I started running. The knees feel as good or better than when I gave up the court sports. In my case, the running/cycling/swimming has been good for my body. That being said, I am a mediocre endurance athlete at best.
#105
Quoted: 2236 Post(s)
Liked 1,314 Times
I don't get sore knees/ankles from running. I do get sore quads from hard runs. For about a year and a half I worked through calf issues but also had patella tracking issues from cycling.
The worst recovery issue I have ever experienced was from a long hill run and descent. The downhill portion taxed my quads so much they actually went into failure at the bottom. This was due to exvessive quad eccentric contraction, which my muscles were not fully prepared for. Would not hold me up. Schumers neck is a similar condition in cycling.
I walked around like I had two peg legs for a few days, hyperextending the knee so the joint would lock so I could walk, but there was no actual knee or ankle pain. That would be an injury and not a normal part of running.
#106
Quoted: 4420 Post(s)
Liked 4,873 Times
It sure sounds like you're burning more calories per watt running on the elliptical than riding on the bike, is that what you mean by "efficiency"?
My sense on the elliptical vs. bicycling is that I'm maxing out my leg efforts a lot on the bike, and maxing my leg effort on the elliptical plus putting out a major effort with my arm muscles. Despite everything you're saying here, I do think it's logical that the amount of energy burned will increase, all other things being equal, with an increase in the number of muscles being maxed out.
I don't meter anything, so I'm not going to attempt to compare wattage.
So there's a lot of individual bias going on here, which is not that surprising given what we know about physiological adaptation to stress from different activities and how specific that adaptation tends to be. It's why I can ride hard for a 100 miles without a break and yet struggle to run a single mile on the same legs!
#107
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
I am new to Bike riding and doing roughly 20 miles a day 16 mph on a single speed , lots of hills. Switched from running several miles a day after I saw all the knee replacements around me. Bike riding really is fun but all those miles are wearisome, noticed them when I was painting my house. How does bike riding match up to running?
Running is weight bearing exercise, cycling is non weight bearing. Theres a reason i can run maybe 3 miles but can cycle 40 or so comfortably
But switch to a bike with some gears or cycling up and down steep hills with a single speed can contribute to ugly knees too
#108
Veteran, Pacifist
Quoted: 3901 Post(s)
Liked 4,844 Times
If I went back to running……
……nobody would want pics of my vintage running shoes!
Besides, most of my bikes are so old that the effort to move a 22/23 pound bike is soooo huuuge, it must be closer to running effort expended.
edit: let’s see those old running shoes.
Likes For Wildwood:
#109
Tragically Ignorant
Liked 9,098 Times
#110
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1916 Post(s)
Liked 312 Times
I remember hearing Lance Armstrong say a few years ago that he does more running that cycling to stay fit these days, as the workout he gets from a 1 hr run, would take him 4 hrs on a bike.
How accurate was he being here? Maybe rather than a 1 to 4 ratio, it is more like 1 to 3.5ish.
But interesting perspective for sure.
#111
Quoted: 4560 Post(s)
Liked 2,802 Times
This year I've done at least as much running as cycling, especially earlier in the year. Strava says I'm spending about the same amount of time on each activity overall (about 135 hours on each so far in 2021). I'm just short of 600 miles running so far in 2021, usually 3-5 miles a few times a week and one 7-10 mile run on the weekend. I was aiming for a marathon by the end of 2021 but I'm not sure I'll reach that goal. Due to chronic neck and back pain from injuries I'm well below my usual time/mileage from previous years. I'd rather not add running related injuries to that so I may consider entering a half- marathon this autumn or winter.
Running feels much harder, although Strava's relative effort score seems rigged to favor cycling in difficulty. I don't have power meters for cycling or running but I suspect if I did for both activities it would more accurately reflect the greater difficulty I feel when running.
The nature of cycling makes it easier to vary our effort, from very easy to very difficult. Beyond around 14 mph wind resistance becomes a significant factor, more than weight, etc. Other than in a crit or time trial, hardly any cyclist is going full gas or nearly so for an hour or so.
With running it's always difficult. There's no easy gear in running. There's hard and degrees of harder. Especially on our roller coaster terrain -- there's no long stretch of flat road anywhere near me. There are school tracks but those are tedious and not available during the school year. It's difficult no matter how fast or slow you are, and wind resistance is relatively less of a factor, unless there's significant head or tail wind. Easy means walking. There's no coasting. Walking feels like giving up, unless you're doing Maffetone type training or something similar and need to walk to keep your heart rate in the target range. I do a lot of walking on some longer sessions because even slow jogging peaks my heart rate above the target range.
You're always moving your full body weight -- the only way to put in comparable effort cycling is to stand to pedal. You're swinging your arms and torso (although techniques vary considerably and many elite marathoners, especially the Kenyans and Ethiopians, minimize their upper body movement and tend to tuck in their arms and elbows, which most runners would find unnatural).
The 1:3 or 1:4 ratio sounds about right. Hard to compare because running and cycling use different muscles and techniques. I ended up changing my bike fit on two road bikes to better suit my improving conditioning from running, especially the calf strengthening -- mostly raising the saddles and scooting them forward, and pedaling toe-down a bit more than I used to.
But it's still difficult to compare because I've been cycling steadily for six years and only resumed running in January this year. It'll take me about a year to regain decent running form. If I continue with both running and cycling I might find the difficulty gap narrowing a bit in another year or so.
Likes For canklecat:
#112
Rule of thumb for a better than average condition runner and cyclist is that running burns about 3 to 4x more calories per mile than does cycling.
#114
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
Note the ratio of bike vs run distance in a triathlon...........112 vs 26.2............is roughly equal to 4x. Well four and some change. Also, the ratio doesn't hold for time. Time wise most folks spend about 1.5x the time on the bike leg as the run. So a 4 hour marathon would be a 6 hour bike ride. The pros are so fast though that ratio skews as the air gets thick going so fast on the bike. They're finishing 1/2 IM bike legs under 2 hours and doing the 1/2 marathon runs in like 2:15.
#115
Bikes: Konas: Jake the Snake-Fire Mountain-Zing Supreme, Dew Deluxe,Zone Ltd. (frame, needs parts), Surly Long Haul Trucker, Santana Arriva tandem, Montagues: Paratrooper-Fit, Trek 1200, Bianchi Ocelot, Fantom Cross Uno, Bridgestone 200
Quoted: 108 Post(s)
Liked 227 Times
The original question, for me anyway, is irrelevant. I hate running, and love bicycling.
#116
Liked 4,873 Times
#117
Liked 4,873 Times
I see we are still going on about distance when comparing running vs cycling. Average running speed is what 6-7 mph? Average cycling speed on flat say 20 mph. So on a distance basis it's going to be about 3:1 or a bit higher. All that means is that wheels are more efficient than legs. Quite a good invention for land travel.
#118
Tragically Ignorant
Liked 9,098 Times
Is he doing shoe endorsements now?
For some reason, I don't trust that guy's motivations.
#119
Tragically Ignorant
Liked 9,098 Times
#121
Old Newbie
Bikes: Many, I'll list later
Liked 6 Times
Tirtha Kumar Phani ran 38 miles a day for 1 year. Stephaan Engels ran 365 marathons in 365 days. He also completed 20 ironman triathlons in one year.
Terry Fox ran a marathon a day (more or less) in the 80's while raising money for cancer. He only had one leg !!
Rare and remarkable but it is possible !!
Eddie Izzard has raised over a quarter of a million pounds for charity after completing 32 marathons and performing 31 comedy gigs in just 31 days. The 58-year-old ran a marathon on a treadmill every day in January, followed by a "Best Of" comedy gig as part of a "Run For Hope".
#122
I don't know of a lot of people who run not for the exercise.
Cyclists bike to commute, to travel, for recreation, to replace their cars for short errands and for exercise too.
#123
Quoted: 839 Post(s)
Liked 1,064 Times
I've seen a few people riding these elliptical bikes where I live. Our Bikes | (elliptigo.com) Talked to a couple of them that were ex-runners and they had switched to these as a way to get a similar workout to running without damaging their knees/bodies. Definitely requires more effort and total body movement compared to bikes.
#124
Don't forget this great comic from the UK.
#125
I don’t care about speed… far more important, is time & cadence. Ride out for a set time keeping a cadence, say 90 a good touring cadence, no matter what the terrain keep that cadence up (30 minutes out 30 minutes back, or whatever).
So, my suggestion is to get a multi-speed cycle…learn the shifting pattern of the gearing (cuz I’m an old time tourer, I prefer the “half step plus granny”…). Anyway, keep up the cadence no matter what gear you’re in for a set time, become more of a ‘spinner’ rather than a ‘masher’ (‘mashers’ have similar knee problems as runners)
Good Luck
(oh, and I’ll always recommend a “long based recumbent” like the Linear or Ryan, if you can find one)
