Ordering aluminum track frame this weekend. Looking for some advice re: brands.
I'm looking at ordering an aluminium track frame this weekend. What are your opinions about the relative quality between Vigorelli,MASH,Super Pista, and LOW?
I've found a LOW and a MASH used on CL locally that I'm checking out this weekend, I'm also considering the Vigorelli and the Super Pista.
Which frame (out of those or throw your own suggestion into the mix that's not much more expensive) do you think is the nicest and why?
Thanks!
Thanks!
The All-City Thunderdome is one of the nicest aluminum track frames I've seen in quite some time and doesn't have stupid "pursuit" geo.
Geometry>Aesthetics
IIRC, those frames are all fairly different. Study the geometry charts and pick the on you think will work best with your fit needs.
The mash is a couple years old and looks like this (it isn't this one it's the 53cm version but the paint is the same and I think they change that every year so it should otherwise be identical to this one): https://www.ebay.com/itm/Cinelli-MASH...item2327529fbd
I get what you're saying about paying for street cred but it's actually the most affordable option out of the ones I'm looking at.
I see where you're coming from about geometry but I don't think I'm experienced enough to tell what I want just from the diagrams. Currently I ride an NJS Bridgestone and a old Fuji conversion. One with "pursuit" bars (nitto RB021) and one with flop and chop bullhorns. I prefer the Bridgestone and the RB021s but that should be obvious.
Unfortunately I won't get a chance to really try and of these out before hand because they're just frames.
Edit: Did more research and apparently that's a Mash bolt which has a less pursuit geometry than the histogram so that's probably good.
Liked 398 Times
It's faux pursuit geo either way. Just a longer seat tube. You might want to consider Leader frames as well. The 725 and 735 are both nice, and the Kagero is ******.
Wow. this post lead me to some googling. Up till then I was unaware of this frame. Gotta say I totally agree Scrod, thanks for the heads up. Pity I'm broke.
Looks nearly identical to the pake french 75. The pake can be found for cheaper.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Liked 8 Times
Someone has to be the grouch and seeing I'm overly qualified I guess it's my place to say this so ... why the aluminium fetish? Steel is at least an equal option and for long term use, possibly better
For starters - the welds are nicer, the finish is better, the dropouts have double-sided stainless plates and it doesn't use an integrated headset. I also happen to like the Thunderdome's geo better (but that's obviously a personal factor).
I am in no way saying the French 75 is a crappy frame. I think it's great. The Thunderdome just seems a bit nicer overall. How much someone is willing to pay for those details is subjective.
To dig a little deeper, All-City's products are typically better than Pake's right across the board.
I'm skeptical. The welds on my Pake look pretty good. You can't really evaluate welds by appearance anyway.
The Pake finish is fragile...it could be better.
After riding the Pake for several months, with only stainless plates on the outsides, this seems like a non-issue to me. My dropouts still look fine. The one sided design makes more sense to me (less likely to slip) even if it looks a bit jankier.
This is more of a style issue (and to some extent, geometry) than a quality issue.
This is what is really boils down to. The Pake geo works better for me.
I don't see how the Thunderdome is worth $200 more, unless the geo suits your better. I think the subtle geometry differences between the two would be lost on most.
Anyway, my point is I don't think the price difference between the Thunderdome and French 75 (both incredibly stupid names, btw) is justified from a quality perspective.
Geometry matters most, but beyond that, if the Thunderdome fits your aesthetic preference more closely then those preferences are going to cost you. Aesthetically they are very similar, at least from my perspective. I tend to ride my bikes more than I look at them.
Without needing to start the silly "I ride my bikes more than I look at them" argument (yet again), I look at bikes all day long as a shop owner and differences in quality are pretty easy to recognize.
Just in case you need a better look:
IMO, the welds on the Thunderdome are much cleaner and nicer looking than all of the aluminum Cinelli frames I've got hanging in the shop - which are often atrocious considering how much those frames cost:
Again, I'm not saying there's anything wrong with the Pake. I'm just pointing out some obvious differences that may justify the price of the Thunderdome to some.
Fixie Infamous
And the fork has the same finish?
Fixie Infamous
I want.
Pake welds look a lot better than that.
There's very little difference between the welds on my Pake 75 and the Thunderdome in your photos above. If you've seen sloppier welds on other Pakes maybe its a quality control issue. Anyway...you still can't evaluate the quality of a weld by looking at it, much less through paint.
