Random Thought Thread, aka The RTT (**possible spoilers**)
Old & Getting Older Racer
Bikes: Bicycle Transportation: 2022 Hyundai Kona Electric, 2019 Kia Niro Plug-In Hybrid
Quoted: 41 Post(s)
Liked 8 Times
you need a calibrated weight. super important. there are a few ways to do it, but essentially you measure the zero offset with no weight then with the known weight. you can do this with a simple spreadsheet or you can get the quarq app. with a quarq you need the wahoo ant+ dongle. with an SRM you don't need anything special.
here are some instrux quarq posted a while back:
Calibrate Slope Help
it's the type of thing that seems complex until you do it once. then it takes just a few minutes. hardest part is getting a weight that is both accurate and of appropriate mass. >=10kg is ideal. get a certified weight if you can. others can tell you how accurate you want that weight to be. (solid engineering principles dictate that the accuracy should be a certain %age of the thing being measured, and in this case if the weight is off even by a small amount it can mess up the calculation--moreso with smaller weights than large ones.)
Thanks.
Cleave
"Real men still wear pink."
Visit my blog at https://cleavesblant.wordpress.com/
Lightning Velo Cycling Club: https://www.lightningvelo.org/
Learn about our Green Dream Home at https://www.lawville.org/
Thanks.
Cleave
out walking the earth
Since I have a house at the base of it, I've dreamt of Whiteface glory since I started riding serious again about ten years ago. Since it's a very consistent grade I've been able to train on it using my ancient nintendo based computrainer, simply based (long sold) on putting in the avg grade and distance. Looking at winning times, my avg power on the computrainer, gave me some pretty solid estimates. In practice now, with a powermeter and race conditions those estimates proved to be pretty close.
Quoted: 693 Post(s)
with your SRM you do not need anything new (other than a calibrated weight).
you'll use the 800 to observe the ZO during the measurements i described above. you then enter them into a spreadsheet (takes a minute) and will either verify your existing slope or figure out that the slope changed. with SRMs i either find no change or a 0.1 (=0.4% or less) change (usually SRM slopes are in the 25.0 range and the actual change is <0.05...but sometimes it pushes you to round up or down as the meters can only take a value to the nearest 0.1).
if you detected a change, you can use the 800 to update the stored slope on the SRM, so you do not have to manually input it every time.
i find the 800 can update slope reliably but the 500 is sometimes less consistent.
the quarq app has a few other interesting uses that are not relevant for SRM owners. for example, you can check the factory slope at any point with it (at least you used to be able to do so). my alternative for SRMs is to just note old and new slope on the spreadsheet when i bother to do the testing.
do a quick search for "SRM + calibration + spreadsheet" and it should turn up. otherwise, PM me with your email addy and i'll send mine to you. it's' nothing special.
as for your power tap, you can check the torque at the hub, but to my knowledge that is not something that can be updated by the end user. (that is one of my own issues with it, but ideally you never have to make an update.)
Quoted: 693 Post(s)
I was a bit bummed that the data was borked, and it was the longer effort at a known grade against previous results that made me confident the meter was off.
Power that day was likely around 385. Data showed 365. Impossible to know for certain, wind matters over 11 miles, but otherwise my weight was about the same when I did my other solo run of 51:30. Power that day was 380, iirc. I believe most of my time improvement came not from higher power (subsequent climbs back this up) but from stripping about 1kg off my bike (tubulars), and better application of power through the climb.
Anyway, my training plan of non-interval riding means that if my power is a bit off it's annoying, but I'm not doing workouts in the wrong zones or something. So far the meter I received back after this round of warranty is holding pretty steady and data is true to known w/kg times from historical data.
you are quite in tune with your local routes and efforts/times (no doubt due to strava as i imagine it makes one highly aware of times for pieces of rides). not all riders are as in tune. i suspect on this forum we represent a more sophisticated user base that is the minority...and yet we still have people who have lost data, and more than just one ride's worth.
that said, even a 1-2mph change in wind can be imperceptible to us on the bike but can result in dramatically different times. were we having a day where 95% is our best effort? was the wind just a bit more in our face? was our power meter under-reporting? it gets tough to say when many possibilities are combined.
i value learning about potential problems ASAP to minimize or altogether avoid data loss -- but that is my personal bias. once bitten...
if someone has a meter that truly needs slope changes every month or so, then there is a big problem. after an initial check of a new meter, if one has to do anything other than settle into a pattern of confirming the slope every 6 months or making a slight change, then something else is going on. with what i know now, i'd never own a meter that requires me to check it frequently, though i have owned ones like that in the past.
fuggitivo solitario
as for the spreadsheet, you basically check ZO offset with no hanging weight, record the offset number. Add one item of known masd, record the number; repeat as you see fit. Ideal set up would be two 10kg plates having known masses.
open any spreadsheet and type in the numbers, do a linear regression. Slope of the regression line is, well, the slope of your PM. It records the changes in the reading as the input torque is changed. Of course, you'll also need the right unit conversions.
As for calibrated weights, the scales at the Post Office is calibrated every month.
Quoted: 693 Post(s)
to CHECK slope, all one needs is a head unit that can display ZO in real time (PC7, edge 500/800). the app does help quarq users walk-through the process and input values, as well as update the slope.
the edge 500/800 should be able to update the stored slope on the quarq as it can on the SRM meters.
Ninny
Quoted: 686 Post(s)
Random thought: is there a way to see a racer's USAC ranking points directly? The only way I know to do this is to look at the overall ranking list, like so: https://www.usacycling.org/rankings/...Road:RR&cat=03 . But it seems like there should be somewhere you can just look up a racer and see their number.
I checked my weights at home, USPS, and FedEx. They were all within an ounce of one another (2 identical, 1 an ounce lighter).
Bikes: Giant TCR, Giant Anthem, Felt CX
Quoted: 65 Post(s)
The Official Website - USA Cycling
then search by name
Bikes: Yes
Quoted: 9 Post(s)
Bikes: Yes
Quoted: 9 Post(s)
[PSA]
I have an SRM that went bad. I don't know when it went bad. I didn't know it went bad until I started training consistently on another bike. Suddenly the same workout on one bike was a lot harder than on the other bike. Any of it the end of the world? No, but…I have a heap of failed FTP tests over a long period of time because I was aiming for numbers I thought I should hit, but since I was reading low I was cracking. Can't say for certain, but I imagine it didn't help anything on the racing front. It's definitely worth checking things with regularity.
[/PSA]
[/PSA]
**** that
Quoted: 1099 Post(s)
Liked 104 Times
GC, the only way I know of is what you listed, looking at the overall list.. same for figuring out what category someone is.
The way things unfold on facebook along group think lines is pretty interesting. Watching this one thing unfold along somewhat predictable lines, yet amazed at how clearly it's doing so.
**** that
Liked 104 Times
Which is why I'm adding upgrade points calculations to the Race Results app. (which would be more accurate if USAC made it more obvious what cat someone was)
Upgrade points are way less dumb, although for cat 1's like you I suppose they don't mean much..
Bikes: Yes
Quoted: 9 Post(s)
road-results.com is better for this kind of analysis.
no, but for masters you could add a life clock countdown timer
Quoted: 693 Post(s)
i think too much stock can be placed in the rankings, but as far as a system that attempts to rank amateur athletes who race varied opponents on different courses i think it is a pretty good effort. the newer system is far, far better than the old.
i think getting a relative idea of the talent pool in a race (as measured by overall rankings of the riders) is somewhat interesting.
Just this year promoters in SoCal began to submit results to USA Cycling on a regular basis. In the past it was spotty at best. Now that there is more data the ranking numbers are more accurate.
The "Race Predictor" has been uncanny in predicting my mid-pack finish.
soon to be gsteinc...
Quoted: 842 Post(s)
Liked 469 Times
I tweaked my ankle yesterday mowing the lawn...so pissed. My bike fit reduced the pain to almost nothing and I agitate doing household chores.
Our front yard is a steep grade, and parts of it I have to run up and drive the mower like a tackle dummy. In addition to it being dangerous, it kills the leg. I'm going to have to either drop $400-$500 on a self propelled mower, or get a gardener. I'm not a fan of spending money when its not a bike or electronics
fuggitivo solitario
