For the love of English 3 speeds...
#2901
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
#2902
Bikes: A load of ancient, old and semi-vintage bikes of divers sorts
i think i may have posted this in its previous incarnation, but here is my 1956 hercules royal prince after some additional polish and spit-shining. I am really happy to have gotten rid of the wald fender stays...
1956 hercules royal prince - the evolution - 13 by sallad rialb, on flickr
1956 hercules royal prince - the evolution - 5 by sallad rialb, on flickr
#2904
Liked 10 Times
#2905
Are those cogs readily available and if so from where?
Thanks
James
Thanks
James
#2906
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Quasi available. Best source I have found in the US is BikeSmith Design. He even has them in 26t!
Also a great place to get cotters and the best cotter press currently available.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
#2907
I second this endorsement. Mark, at Bikesmith, is the go-to-guy!
Aaron
Aaron
#2908
Liked 10 Times
Aaron
Aaron
I tend to be adventurous, so I bought a dozen directly out of Germany, six at a time, for about $8 each including shipping.
Don't get me wrong on this: I know Mark from having done business with him. I have bought almost everything he sells and he has a business to run so I'm OK with him making a profit. I am sort of an outlier with regard to this because of the number of cogs I needed. It would have been more expensive than I would have liked if I had purchased a dozen from Mark. If I was just buying one or two, I would have gotten them from Mark, but in my case a dozen was a totally different story .
#2909
Quoted: 5 Post(s)
Kool-Stops
I recently picked up a 72 or 73 Sports in OK condition, and since it's not pristine in any way am riding it every day and fixing as I go. Make a new fender clip for the chainstay bridge, Repacked the front hub, WD-40'd, drained/dried, and oiled the rear hub, trued, tensioned and polished (so-so job - some rust remains) the wheels, new tires. Old Dunlop tubes still holding air. Still running old brake cables, that changes today.
I put some Kool-Stop Eagle 2 pads on for this morning's rainy commute (improved over 40 year old black rubber!), but as many of you have noted, they don't fit in the front (hit the fork). Other than buying Continentals (special order where I am), what are some options people have tried? Upside-down? Cut them down a little? Are there Kool-Stop shoes that can work in the old Raleigh metal brake shoe holders? I am interested in whether anyone has interesting tricks to share.
Thanks!
Thanks!
#2910
Quoted: 5 Post(s)
On cogs:
I think I read somewhere that there's a theory that a larger than 22t cog could damage the innards of the AW. I guess hubs have an input ratio, can anyone report on actually finding the limit, what the conditions were and what breaks? I am running 22t, but would gladly go to 24 or more. I think it would broaden the appeal of the bikes too, as the climbing ability with 22 is already a surprise to most!
#2911
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
There definitely are kool-stop shoes/pads that work in the old Raleigh shoes/holders. They look like this:
The description often indicates they are for Campy brakes; but they will work in most old brakes. They work best in holders that are open at the back; if your holders are closed on all four sides, open it up at the back.
That said, I have had trouble finding them lately; could be they have been discontinued.
#2912
Liked 10 Times
On cogs:
#2913
I believe Mark told me a couple years ago that you'd be fine as long as you aren't standing up on the pedals and pumping it out. The larger the cog, the more torque increases. Also, the direct drive gear can theoretically withstand more torque than the other two.
#2914
Bicycle Repair Man !!!
Continentals are a good replacement but they lack the classic shoe... one might also seek out NOS Matthauser shoes and pads which are the forerunner to Kool Stops.
#2915
multimodal commuter
Liked 574 Times
#2917
#2918
multimodal commuter
Liked 574 Times
They're from the 80's, which isn't terribly old. At any rate, the ones I have are fine. Though I might add, the NOS ones I've seen on ebay were hardly cheaper than new Koolstop ones.
#2919
Tyrannosaurus Rexitis
Bikes: Scott Addict 6870
Quoted: 60 Post(s)
Got myself a sports today for a broken arm cruiser. Cream tires eventually. I'm happy since it was free.
Uploaded with ImageShack.us
#2922
Liked 10 Times
#2924
Quoted: 7367 Post(s)
Liked 2,510 Times
I think it's from the early 60's. And it's an incredible specimen.
I had a customer in a bike shop whose hard pedaling damaged the hub, but I was able to fix it. He was very large, and he looked strong. We had not changed the sprocket, but I think his mass made up for it. But I've only seen this once, so yes, I wouldn't worry. I'm about to put a 24T, and I'm going to ignore the advice and stand on the pedals. I'm 175 lbs, I climb fairly steep hills, and I might be towing some big loads, so it should be a good test.
It's fine that direct drive can withstand more torque, but I normally apply the most torque in low gear.
#2925
