Stiffness Does Not Matter
#151
Quoted: 4419 Post(s)
Liked 4,873 Times
Well, since the entire lightweight bicycle doesn't weigh very much then why not suspend the rider on the frame instead of suspending the rider and frame on the wheels ? In the first case the entire bicycle would be un-sprung weight while in the second case only the wheels and suspension would be un-sprung weight. But again the bicycle doesn't weigh very much against the total weight of bicycle and rider.
The problems would seem to be that a seat suspension would hinder pedaling while sitting in the seat. But then if there were only a handlebar suspension that would tend to pitch the rider's weight forward. If there were both a seat suspension and a handlebar suspension the rider would move more vertically.
Now one bicycle developer has a seat compliance system that moves the seat mostly front and rear and not as much up and down. I suppose that the development has our attention.
My solution is a stiff frame with a deflecting fork and deflecting seat post. Of course my sport is not long-range rides but short downhill courses like a paved sports-car track but relative to the 40 MPH speed of the bicycle.
Now we all know that a wheel suspension at the rear of a bicycle does reduce pedaling effectiveness.
#152
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
Does this mean that the stupid justification for press fit bottom brackets is gone, and now we can get back to much more sensible threaded BBs?
#153
Quoted: 2333 Post(s)
Liked 2,097 Times
Jam hard out of the saddle over a hill with low tire pressure in a flexible frame Repeat with proper pressure. Switch to a stiff frame and repeat.
The losses are in the tires, not in the metal or carbon.
#154
Klaatu..Verata..Necktie?
Quoted: 10441 Post(s)
Liked 11,914 Times
Lots of theoretical handwaving. Not a lot of data.
I can tell you that the stiffest frames I have are the ones the feel best in a sprint or other out-of-saddle effort, while the least stiff don't encourage that kind of effort. However, I'm also always aware of which bike I'm riding, so I can't dismiss expectation as a variable. And in the end, I don't need to because it doesn't really matter whether or not stiffness of the frame 'doesn't really matter' because somebody's got a hypothesis (it's a hypothesis, guys, not a theory).
Hell, I've even been told that stiffness of the frame doesn't matter for comfort and compliance because of some guy's hypothesis, but I still find myself seeking the least bumpy line with some bikes more than others, and some bikes on the same roads kick me up out of the saddle more than others. So I'll stick with my observations, because observation is how you determine whether hypotheses are correct anyway.
#155
Quoted: 12 Post(s)
The Specialized Roubaix has a handlebar suspension on top of the headset allowing 20 mm of vertical travel. The latest version of it is sprung and damped. The original didn’t have the damper. They did apparently test a similar system on the seat post but found that riders didn’t like the way it pedalled with vertical compliance (not surprisingly). So they went with a more typical compliant seat post to provide a bit of comfort. Most modern bikes now have fairly flexible seat posts to add comfort. The D-shaped carbon post on my Defy is notably springy, but because it only defects backward it doesn’t affect pedalling.
On second thought, maybe the Specialized 20mm of handlebar springing is the correct amount
#157
Quoted: 7653 Post(s)
Liked 3,481 Times
#158
Quoted: 4227 Post(s)
Liked 2,488 Times
Steel is the best material for bike frames.
#159
Liked 2,097 Times
#160
Liked 11,914 Times
#161
Liked 11,914 Times
#162
Liked 3,481 Times
Steel is the best material for steel bicycle frames.
Likes For Maelochs:
#163
Quoted: 1218 Post(s)
Liked 298 Times
If you want handle bar compliance, get some abs, start pulling on the bars instead of using them as an upper body support shelf, And quit locking your elbows!
I have a theory on why some people dislike stiff bicycle frames.
Might be time to start riding your bicycle instead of riding on it.
#164
Quoted: 405 Post(s)
Liked 430 Times
At least not by the US Navy's definition of "sound," the correctness of which I am unsure of to this day, almost 27 years after I learned it in Sonar Technician A-school.
Per Uncle Sam, "sound" is the acoustic energy transmitted from a source, through a medium, to a receiver. Without a receiver, it's just acoustic energy, not sound.
Yeah, it's definitional and nit-picky and almost circular, but it made me giggle when I first heard it, and it still does.
--Shannon
#165
Quoted: 338 Post(s)
Liked 408 Times
The difference between a poorly done PF and an equally poorly done threaded BB on a carbon fiber bike is that the first will creak, the second won't. Both will eat bearings prematurely and waste more power than frame flex possibly could. Adding weight by gluing alloy inserts just so the manufacturer can mask their poor quality control on a multi thousand dollar frame - I'll pass.
#166
Quoted: 405 Post(s)
Liked 430 Times
What - no. Given the choice, I'm going for pressfit.
They have proven over and over again that they cannot.
Despite the fact that every other industry has been using press-fit cartridge bearings for decades, in applications with orders-of-magnitude greater force and speed inputs, the bicycle industry can't make frames that will properly align a pair of bearings to cope with loads of less than one horsepower at 120 rpm without screwing things up. So the only way to get a BB / frame interface that doesn't suck is make the interface adjustable.
--Shannon
Likes For ShannonM:
#167
Quoted: 338 Post(s)
Liked 408 Times
Well, some manufacturers stick with pressfit and the vast majority of their bikes have no issues. Some have abandoned it in favour of threaded, but personally I hold it against them - to me it screams "we're too cheap to do decent quality control on a multi thousand Eur / USD frame so we're not even going to try". Threaded on a CF frame also can come out crooked - it just won't squeal when it does - so it's really just fixing the symptoms of crap manufacturing tolerances.
Next CF frame I get will almost certainly also have a pressfit BB.
#168
Liked 4,873 Times
#169
Liked 4,873 Times
I was suggesting that it's the Cannondale Kingpin seat compliance system that should be considered. And I was suggesting to forget about simple handlebar springing. I haven't tested either system.
Edit: One thing about the Cannondale Kingpin I would be concerned about with 30 mm of compliance is damping as it appears to be an undamped spring and that is quite a lot of movement. I used to have a Cannondale Scalpel, which also used flexible chainstays for rear suspension, but it also had a spring/damper at the seatpost junction. The first version of Specialized's Futureshock was also undamped and some people found it too "bouncy". The Mk2 version added a damper, which was considered a significant improvement. But maybe the damping is not so critical at the rear end. The Willier system I mentioned will have a fair amount of natural damping in the elastomer.
https://wilier.com/en/my2022/int/rac...kes/cento10ndr
#170
Liked 4,873 Times
Talking of compliance, I'm quite intrigued by OPEN's MIN.D road frame with its 25 mm continuous seat tube/mast and wafer thin bowed seat stays. It looks very comfortable to me, without resorting to a more complicated suspension design. Also appears to be stiff in all the right places.
https://road.cc/content/review/open-mind-2020-276793
#171
Liked 298 Times
Oh I've seen all kinds of tips for riding rough roads.
Less psi
Relax
Higher gear
Wider tires
I've yet to read any article on how to ride rough roads / cobble stone that suggest buying a bicycle with a frame that is a flexible noodle.
Maybe you know of a few articles that suggest flexible frames?
Less psi
Relax
Higher gear
Wider tires
#173
Liked 4,873 Times
Less psi
Relax
Higher gear
Wider tires
Less psi
Relax
Higher gear
Wider tires
#175
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Seems simple enough to me .... the motion of the crank translates the motion of the foot into motion of the chain and ultimately, the rear wheel, which propels the bike forward. Anything in the system which transfers energy anywhere not alo0ng the perfect (circular) path of the crank, wastes propulsive energy.
Think about a bike with really loose bottom bracket bearings, or cranks which weren't tight to the spindle---no one would be trying to convince anyone else that those things in some way returned energy to the bike because "ya know, conservation of energy." If the whole frame flexes at the bottom bracket, same effect---some of the potential propulsive energy goes in different directions. When the frames snaps back (or is pushed back by the other crank) it is still lateral, not longitudinal motion, and this does Not help propel the bike.
it's going Sideways, people. Unless you want your bike to go sideways , any sideways motion is wasted, since "wasted" in this case means "not propelling the bike forward."
The only way the bike could be acting as a spring and propelling itself forward with energy from deflection would be if the bottom bracket twisted longitudinally under load---but that would imply a fixed or high-friction crank bearing.
Think about it .... if your wheel shakes from side to side really badly, are you going to claim that its okay, because the energy lost will be returned and help propel the bike forward.?
For maximum efficiency, everything has to stay in the plane in which it is meant to operate. Every angular flax is a waste of energy. Y'all are engineers with degrees and all that ....
What "direction" the frame appears to be flexing is a red herring. Here is is what is going on:
When you apply force and power through the cranks, the cranks exert a force on the bb shell (and the frame). The frame needs to match that force, otherwise the cranks would not redirect the force of the pedals to the chain. With an infinitely stiff frame, the force would be matched completely with no deflection thus no energy goes into bending the frame. With a real world frame, it deflects until the force is matched. It takes energy to do this, thus you temporarily lose this energy to the spring (frame). The less stiff the frame, the more it needs to deflect to match the force, and the more energy is diverted/stored in the frame.
Now consider what forces on the cranks are causing the crank to exert a force on the frame. 1- The force pushing on the crank arm, and 2- the force of the chain pulling straight back on the top of the chain ring.
When that stored energy is released, it is going to do so in the exact opposite direction (vector). Thus, unbending force of the frame will act on the crank in the exact opposite vector as when the crank deflected the frame, and the crank in turn directs this force in an opposite vector to the to the chain (pulling pulling forward.... thus the drive force) and back into the crank arm (force against you pedaling).
I believe the key as to whether you waste energy (and how much) has to do with how much of that energy goes through the chain and how much back through the cranks (*see caveat below). And honestly, this is where I get a little fuzzy (Perhaps someone else can pick up here) .I believe is has a lot to do with the timing of your pedal stroke in relation the the frequency/timing of the spring - and I am pretty sure that is what the concept of "planing" is all about.
BTW, the example above is just one of the many ways that a frame may be flexing and storing/releasing energy. Here is another: The force on the chain causes tension on the chain that is trying to pull the chainring and cog closer together. Since the chainring and cog are both off-center of the frame, they can get closer to each other by bending the frame between the BB and rear axle. Thus, there is always some bending force on most frames when you pedal. A really stiff frame bends minimally, thus diverting/storing little energy. A more flexible one bends more, thus storing more energy. This is a perfect example of the direction of the frame deflection being misleading. The frame may be bending to the side, but the forces acting on it are along the chain line. And along the chain-line is where this frame/spring is going to return this force (and energy).
*There are also loses due to damping, but that is a different subject. And for metal springs, it is minimal.
