Tire Clearance on 80’s Steel
#51
Quoted: 4806 Post(s)
Liked 3,932 Times
Funny, I forgot about the peg until it came back from paint. Next time I spoke with Davy Levy (who did the other stuff, I mentioned it and he said that it was no problem. He could just drill and tap and screw in a pan head screw. Then come the next paint job, the hole could be used to locate and properly braze the ball bearing peg. Did a beautiful job. (Look closely and you can see he rounded off the pan head freestyle, not on a lathe but who's looking that close? And with the pump on, no one sees it.
#52
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1297 Post(s)
Liked 940 Times
79p, can we get a look at that?
198
198
#53
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4682 Post(s)
Liked 5,802 Times
It's ok to have an opinion here.
We don't like jacka$$, however.
An 80's Nishiki ain't rare. I've filed the front end of a fork a few mm's often on various frames to get better tire/fender clearance, and have modified dozens of frames for 650b conversion. And note that the pro peleton is riding 28+ nowadays. Lottsa races being won on "Lincolns". Pretty sure they wouldn't be riding wider tires if they were slower. And my God wants everyone to ride wider tires. So there.
OP, The Bike Butcher of Portland sez mount 28's, heck 30's or 32's if they'll fit.
Likes For gugie:
#54
Liked 5,802 Times
A term to describe irreversibly modifying a C&V frame to accommodate wider tires is long overdue. A case could be argued for "Drew," but that should probably be reserved for turning C&V bikes into fixies by, e.g., cutting off derailleur hangers and grinding off shifter bosses and cable guides.
But I do agree that fixie idjits castrating perfectly good road frames is very bad form. The Atelier has received several bikes that I've brought back to the world of rear derailleurs and restored other tiddly bits. Here's one I did for a forum member.
New derailleur hanger brazed on
Filed and sanded. After that, derailleur hanger alignment tool goes on for fine tuning. It's a common repair at the Atelier
Likes For gugie:
#55
Liked 5,802 Times
Looks like one person did.
Likes For gugie:
#56
Liked 5,802 Times
Nope. I file 'em down all the time, usually when I'm building a scratch fork. It only takes a couple of minutes with a coarse half round file, followed by a fine one to remove visible file marks, then 80 grit garnet cloth to finish. And having the steerer stick out a bit from the fork crown while brazing is the typical construction method. You can introduce the filler material more easily that way, then file the excess. As noted by others, a production fork shop for a mid-range quality frame didn't bother to file them back in the day (saving labor), whereas a custom framebuilder definitely would.
#57
Liked 5,802 Times
I just had a Rawlands in the Atelier to move some cantilever bosses so the owner could go from 650b x 38 to 26" x 52 (we did a fit check with wheels to check clearance and BB heigh change first). I asked if it was getting repainted or powder coated, he said he'd just mask the areas off and rattle can it. He told me he likes to ride bikes, not stare at them in the garage.
Likes For gugie:
#58
Liked 5,802 Times
Anyone else remember when bastard was a dirty word that children weren't allowed to say? Giving us gems like this lil ditty:
In a long line of similar non-rhymes like
Spider spider on the wall
Ain't you got no sense at all?
Can't you see the wall's been plastered?
Get off the wall you stupid spider!
That was Comedy Gold in 3rd grade lemme tell ya. I had 'em falling off the swingset.Ain't you got no sense at all?
I knew a boy who drove a truck.
Wasn't very smart but he sure could drive.
Likes For gugie:
#59
Liked 5,802 Times
Both of my sisters were cheerleaders in high school. I was taught this classic:
Ice cold beer, makes you wanna cheer
Ice cold gin, makes you wanna win
Ice cold duck, makes you wanna...
...S-C-O-R-E, score, score!
Likes For gugie:
#60
Quoted: 3514 Post(s)
Liked 2,927 Times
#61
Quoted: 2588 Post(s)
Liked 4,824 Times
#62
Quoted: 2488 Post(s)
Liked 2,957 Times
Oh, it's beer, beer, beer, that makes you want to cheer
In the Corps, in the Corps
In the Quartermaster's, Quartermaster's Corps
(My eyes are dim, I cannot see
I fear I have not brought my specs with me)
Oh, it's wine, wine, wine, that makes you feel so fine
In the Corps, in the Corps, etc.
Oh, it's whiskey, whiskey, whiskey, ... frisky, etc.
#63
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Yeah unfortunately that was the high point of my comedy career and it's been downhill ever since.
In a desperate attempt to bring this back on-topic... Here's another fork I applied the bastard to:
The scratches you see are from the sanding drum I used to take the file-marks out. I could have just done the whole job with the sanding drum, but it's slower. The half-round bastard takes off metal in a hurry.
The bottom of this crown, on a Soma fork, has the dumbest shape you ever saw. Before filing, there was this projection down towards the tire that does nothing for ya structurally, just removes scads of tire/fender clearance for no good reason. And the crown designer put that downward projection in there on purpose, i.e. not just a lack of trying to remove the extra, like on the OP's fork. This stupid thing was intentional!
I didn't take a pic before filing, but in case you don't know what I'm talking about, here's a pic from Soma's website that shows it:
I don't blame Soma for the dumbness of the design — they didn't design it. The crown is actually pretty decent, other than that dumb downward projection, and this fork is now a good fork, now that I've filed off the offending part. The steel will rust there where I took the chrome off, but I can live with that.
The crown is made by Long Shen, I think. Here's another view of the LongShen crown:
But the design is a faithful knock-off of a Cinelli "OR" from the '80s.
Above is the Cinelli catalog drawing, below is a raw crown:
So I blame Cinelli for the dumbness.
Here's a "real" Cinelli OR (cast in Italy I believe) that I heavily re-worked for one of my MTBs:
You can't necessarily tell from the photo what-all I did, but I lightened it up considerably. (I "heavily lightened" it??)
I raced and toured and knocked around on that fork (built in 1984) for about 20 years, and I am a clydesdale+. Still have that bike in fact, though it doesn't get ridden much anymore. So it's definitely strong enough, despite all the metal I removed. Which tells me it was not an optimised design, as delivered from Cinelli — or the Long Shen copy.
Mark B
Mark B
Likes For bulgie:
#64
Liked 4,824 Times
'Heavily lightened' - I used to do that
DD
DD
Likes For Drillium Dude:
