#7776
Quoted: 4513 Post(s)
Liked 6,389 Times
Good question @bianchigirl . The drive side race is 1.683", which works out 42.75mm between the flats. And 1.195" or 30.35mm for the non-drive side nut. This size also fits Schwinn headset nuts.
Could it be that the drive side race is 1-19/32"? That would be 1.693" in digital inches. Perhaps. But how common would a 1-19/32" wrench be? And that is 10 thousandths over the flat to flat dimension. I would think a better fit would be required.
And for the non-drive side nut, the closest fractional size is 1-13/64" or 1.203" in digital inches. Or 30.56mm. This is 8 thousandths bigger than the size of the nut. So, perhaps. Usually when making nuts you start with hex stock. Then all you have to do is drill the proper size hole, thread it and part it off. There is no need to machine the outside hex surfaces. This seems to be an odd size for hex stock as well, but perhaps it was more available at some time. Or it was a Schwinn specific size.
Anyway, odd sizes. Neither metric or a standard inch size.
The Sturmey Archer axle nut wrench came in with a perfect fit from Send Cut Send, but the Ashtabula crank wrench was just undersize. That lasered surface is tuff and the file skated right across it. I had to use sandpaper to open it up for the proper fit.
I am already making modifications to the drawing for a revision B, just so that if I ever need to make another it is the right fit. I also made a couple of minor tweaks while I was at it.
So far, I'm glad that no one has replied that I could have gotten a Park tool instead of designing my own.
The bottle opener has been done so often, but now that you bring it up.... No, it doesn't work as a bottle opener except if I put the wrench under the cap an hit upward on the wrench.
47 year old Sugino's are the BB problem solvers, never fail and never hurt anything unless I force them to do so.
Likes For merziac:
#7777
Quoted: 2338 Post(s)
Liked 2,827 Times
just got a deer head derailler, not sure what i will use it for, but it is in good shape and it was a low ball bid.....that i did not expect to win
thus the part stash grows
Likes For squirtdad:
#7778
Edumacator
Quoted: 2441 Post(s)
Liked 3,137 Times
Just did that with a set of Cinelli ~$60 ergo bars. Bid $5.78 and won.
Likes For jdawginsc:
#7779
Tange
Bikes: 74 Raleigh Super Course Mk II, 77 Nishiki International, 77 Motobecane Super Mirage, 84 Team Fuji, 85 Schwinn Traveler, 86 Schwinn Prelude, 86 Raleigh Technium 460, 87 Raleigh Technium Tri Lite, 88 Cannondale "Crest", 96 Giant ATX 830, 05 Trek 1000
Quoted: 44 Post(s)
Liked 103 Times
Sometimes you have to spoil yourself....
Here it is; my 4th B-17. I miss buying them from Wall Bike.
Likes For chiefkurtz:
#7780
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
KoolStop Dura 2 pads
Upgraded from Dura pads. Not sure if the old salmon ones had dried a bit, but the new salmon ones are much grippier and have better modulation somehow
Love them
went from these: Kool Stop International - High Performance Bicycle Brake Pads Since 1977
to these: Kool Stop International - High Performance Bicycle Brake Pads Since 1977
Love them
#7781
Quoted: 188 Post(s)
Liked 997 Times
When you got a MecaDural, even if it's without a fork, you have to look around and take your chances.
Likes For fabiofarelli:
#7782
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
86bcd rings from bicycle czar!
#7783
Quoted: 1088 Post(s)
Liked 1,205 Times
Technically, these arrived yesterday, but I still can’t resist a well priced Suntour mid cage, and I also got a frame from a fellow bf’er.
Likes For noobinsf:
#7784
Parts for the next build are currently incoming. One day ago, a 26" 6 speed Richey Vantage / Suntour XC 9000 wheelset (rear came with an Alpha 14t-28t FW), and today a complete set of fairly fresh Dia Compe 986 cantilevers.
Likes For Dirt Road Blues:
#7785
Liked 6,389 Times
This can be key and invaluable in many ways IMO.
I am always on the lookout for cool, odd, rare, eclectic, etc. parts, pieces and components, especially when cheap.
I often have a particular build and or bike in mind and often not.
Awhile back I had a couple of builds that while I was digging around looking for lost treasures and parts I wanted for these builds, I found several options along the way for both that also yielded ideas and parts for other builds as well.
Many of these very cool parts were very cheap when I bought them having done so mainly based on price and knowing they would be needed for yet unplanned builds later on.
This of course has also resulted in many parts that may not get used but as they were often cheap, they are not a huge problem and many will get used eventually.
Both of the planned builds were completed with almost zero delay or additional sourcing outside the pile.
Likes For merziac:
#7786
Quoted: 188 Post(s)
Liked 997 Times
#7787
seńor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3890 Post(s)
Liked 6,491 Times
#7788
Liked 1,205 Times
Likes For noobinsf:
#7789
Quoted: 878 Post(s)
Liked 2,296 Times
Nice to see things passed around on BF. I have bought quite a few nice things on this forum....and one nice Colnago. My preferred source.
#7790
Liked 6,389 Times
You have to have vision, obsession, forethought, luck, etc, and $$$$$$ as well as being willing to part with it.
Can be very challenging, especially when it takes you out of your comfort zone as with much older than our "normal" realm.
Again, you have to be able to take a leap as you did here for it to pay off, if you don't, well it can be even more expensive and far more of a slog.
I didn't/don't have time for that so I am open to eclectic, sympathetic, compromise when necessary and have had very few complaints as well as thumbs up from some pretty serious stalwarts of this C+V thing.
I've stepped up plenty of times as you did here and have really never been sorry, just poorer but happier for not missing out.
Likes For merziac:
#7792
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 904 Post(s)
Liked 1,899 Times
got a Kreitler replacement belt for the rollers. these still roll smooth as silk and they were old when I bought them 30 + years ago.
Likes For jadmt:
#7793
Bikes: many
Quoted: 1447 Post(s)
Liked 1,396 Times
Rear derailleur and bottom bracket for frame #1. I had been planning on a Dura-Ace 740x build, but made a left turn when I was gifted some nine-speed Campy bits.
Likes For smontanaro:
#7794
Quoted: 1304 Post(s)
Liked 1,912 Times
Today I got some French goodness from the luscious and lovely Samantha. Not really destined for anything special but I couldn't resist Samantha's temptations. Smiles, MH
nice clean and with all of the parts!
Likes For Mad Honk:
#7795
Edumacator
Liked 3,137 Times
Next, we’ll see you riding a PX-10, and sporting brifters on the Ciocc...
Likes For Brad L:
#7797
Edumacator
Liked 3,137 Times
Those are perfect wheels. My favorite hubs and hoops.
#7798
Quoted: 878 Post(s)
Liked 2,296 Times
#7799
Tange
Quoted: 44 Post(s)
Liked 103 Times
For my big head
Universal fit? No. I need a true XL helmet. They're scarce, with little variety, and expensive. I looked up Smith Optics. I got this one, from them directly, an XL, without a visor (don't like them), free shipping, for $77, reduced from $120. Yes, it's MIPS. I may get a spare, at this price. https://www.smithoptics.com/en_US/p/...443LK5155.html
#7800
Bikes: many
Liked 1,396 Times
Veering off-topic, helmets (helments?) would seem to be a good fit for 3D printing, though i realize certifying one-off products would be challenging...
