1UP racks
#76
Quoted: 236 Post(s)
Liked 196 Times
Who is the other one?
#77
ignominious poltroon
Quoted: 2245 Post(s)
Liked 3,448 Times
I don't remember, but there were 2 at the beginning, and at one point both were selling the same or almost identical products under 1-up USA and 1 up USA and it was impossible for me to figure out which one it was. I think they were having a patent dispute and there was an ugly falling-out. So maybe the QuikR is the split-off? I had pretty much forgotten about that until just now.
Likes For Polaris OBark:
#78
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
#79
Liked 3,448 Times
At one point there were two of them, two companies, and the only difference in their names was a hyphen. That was when i was buying and I decided to avoid the soap opera altogether, even though I sort of wanted one more than my Kuat.
#80
Quoted: 2976 Post(s)
Liked 1,182 Times
You won't regret it. Even though it has some shortcomings for me, it's better than the previous Thule racks I have owned.
Likes For prj71:
#81
Advanced Slacker
Liked 2,537 Times
Interestingly, 1UP has made a few other products. I have two 1UP bike trainers (a Magnitude and a CPR-A200). Both are VERY well made, and fold up small.
Likes For Kapusta:
#82
I have the Quik Rack ("Mach2" technically), and it's great. The cost exceeds the entire combined cost of bikes I've ever purchased over my lifetime.
But it takes the friction to go out to ride to zero. I don't even leave it on my car, but can affix it within 2 minutes, including the time to walk it out to my car. It works seamlessly and simply. It addresses all of the issues with the 1up, and, having seen the 1up driving by, looks better too.
Is it worth it? It depends on if it's worth it to you to have something you don't have to worry about, that does its job without hassle, complications, or adornment. I can't emphasize enough how super-cheap I am, and would never spend on bikes what some people do, but I felt the Quik Rack was entirely worth it.
Likes For traycerb:
#83
I just go back from taking a 20 year old Yakima heavy duty bike rack to the local recycle store. A good bike rack is a long term investment. For mountain bikes and e-bikes which are heavier a car mounted rack is not a good choice. Platform type are the most versatile but these come in two flavors, the ones that have a mechanism that clamps to the bike's frame, and the ones that secure the front and rear tires as with the 1Up racks.
I highly recommend the type that has a platform for the bike's tires and a mechanism that secures the tires and not the frame as the frame type have problems with step through bikes and with carbon frames.
For three bikes there is the matter of having to reach past the front platforms to get to the one in the back for the first bike. This is where bike weight becomes important. When I had two heavy fat tire e-bikes I needed to adapt a motorcycle ramp so I could use it with the 1UP rack. The 1UP ramp is too short and the design is flawed as it bolts to the rack and precludes having a license plate mounted or even tail lights.
As a side note the $80 Hollywood Valet for bike racks is the best way to store a bike rack while off your vehicle. It is metal and has 4 wheels that can be locked so as not to roll and the rack mounts to the rack the same way it mounts to a vehicle hitch.
The best racks are all very expensive and the Kuat NV sells for $850 plus the cost of add on items. With the 3-bike Kuat the cost is more than $1200 and with the one bike add on the total weight is 91 lbs which is more than I want to lift into position and mount to a hitch. The 1Up is the lightest of the racks that can manage a large payload of heavy bikes.
Likes For Calsun:
#84
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
I am working OT like crazy trying scrap together the cash to get a 1UP. Its going to be awesome to finally order.
Likes For sdmc530:
#85
Quoted: 167 Post(s)
Liked 11 Times
One distinction between 1UP and the other tray style bike carriers is weight. With 1UP, one can start with their base system (1 or 2 rack) already placed in the hitch and attach the add on(s). I had a Kuat NV with just two racks and it was heavy and difficult to put on. I can only imagine how hard is would be to install an NV with 4 racks.
Also, most of the tray style racks protrude parallel from the hitch so, depending on the height your hitch is off the ground, the hitch could drag the ground when going through a ditch or steep dip in the road. On the other hand, the 1UP is a stair step design so, as you add racks, they get progressively higher of the ground.
Likes For Planemaker:
#86
The Quik Stuff rack may have some advantages over the 1Up a two bike rack from Quik Stuff sells for $1,000 as compared to $635 with 1Up. There is a 6-month plus lead time with Quik Stuff racks mentioned on their website "due to aluminum supply chain disruptions".
What should be appreciated is that this all started with Trump putting into place a 25% tariff tax on all aluminum coming into the USA from Canada. The price for my aluminum boat trailer went up $400 overnight thanks to him. Of course the Russian oligarch Oleg Deripaska benefited greatly and not by coincidence as Trump's campaign manager was a former employee of Oleg.
There are hitch extenders that allow for having the rack 7" to 24" further back from the vehicle and ones that will increase the height of the rack above the ground if that is needed.
Hitch rack theft is also a problem with these very expensive bike racks and hitch locks are a good investment in protecting yours. Even if your insurance covers much of the loss you will still be without a rack for months.
#87
Liked 1,182 Times
Blah, Blah, Blah Trump. Blah, Blah, Blah Russian oligarch Blah blah blah Trump's campaign manager blah, blah
#88
Quoted: 236 Post(s)
Liked 196 Times
Wonder why they're not as impacted as QuikrStuff?
#89
Liked 1,182 Times
I'm guessing they either planned poorly for inventory or it's really not their fault at all. I work for a company that uses tons (literally) of extruded aluminum to build the products we make. We can't get aluminum right now from our vendors and our customers have to wait 6 months to get their product. One of the products is even worse...we have orders from July 2021 that we still can't fulfill due to no availability of extruded aluminum.
Likes For prj71:
#90
They are the best bang for buck, and well made. Customer service is top notch. I originally bought the 2 inch double version but it was too heavy and I couldn't use it on my other vehicle with 1 1/4 inch receiver. They took it back without fuss and issued 100% refund, they even sent a prepaid postage. I now have the 1 1/4 version which I shuffle between vehicles.
I like that it only touches the tires and no plastic components that will deteriorate and breakunlike other racks.
Likes For mtn drew:
#91
Advanced Slacker
Liked 2,537 Times
I am sure that the current disruptions are compounding the issue, though.
And QuikrStuff is a small, new startup. I would think that puts them at a disadvantage in the supply chain compared to an established, company that has been doing steady business for a long time.
Or it could simply be a matter of these selling way better than they had expected. Sometimes wait times are just due to high demand and success of a product.
Likes For Kapusta:
#92
Most people cannot appreciate just how small these companies are in the overall scheme of things. They cannot begin to order enough product to be a valued customer by the metals wholesalers. I worked with a $2 billion dollar food processing company and the big IT software companies like SAP would not give them the time of day due to their small size.
For tires narrower than 3 inches in width there is no issue with the stock 1UP bike rack. I added 4 of their wheels savers for an additional $60 and that is all most people actually need. The "wheel locks" with a skewer through the spokes may give the owner piece of mind but they only delay a bike thief by at mosts 10 seconds per wheel.
I use a bike rack but for most of my life I have put my bikes inside a pickup truck with a fiberglass cap to keep them completely out of sight. I have done this for the past 50 years and parked in many places where a bike thief would be likely but never had anyone break into the rear of the truck to see what might be there. A Ford Transit or similar small van is a good alternative.
When discussing bikes and bike accessories and bike racks one needs to consider wait times. I waited 3 months for my 1Up rack and wait times have increased. At the time the Hollywood and all the other bike racks rated for truck or RV use and that had a load capacity of 140 lbs for my two fat tire e-bikes where out of stock everywhere and had been for months.
This is to be expected with small companies that have seen sales nearly double but cannot double their shop space or double their parts orders or double the number of employees and are rightly fearful about the demand dropping quickly and their having to lay off people and worry about a lease payment on a large shop that is no longer needed or having all of a sudden a 12 month supply of raw materials and Work in Progress. That is the real world for small businesses in
this country and why so many go out of business when forced to compete against companies wtih deeper pockets or that can shift production to Mexico or China or Vietnam.
#93
Quoted: 1110 Post(s)
Liked 1,204 Times
#94
Quoted: 236 Post(s)
Liked 196 Times
Their website was then claiming order "ship within 3-7 business days" as it is now.
Likes For gpburdell:
#95
Advanced Slacker
Liked 2,537 Times
You couldn't use it with a 1-1/4" receiver? I use 2" stuff with my 1-1/4" receiver on my car all the time. My little utitlty trailer and Yakima bike carrier are both 2". I just use a 1-1/4 to 2" adapter, available in any auto parts store. Of course, I still don't exceed the weight rating of the 1-1/4 receiver. It does introduce another potential source of rattle, but I use this (the first kind) frequently. They also make 2" to 1-1/4 adapter sleeves that slip onto a 1-1/4" rack. I had a rack that came 1-1/4 with a 2"sleeve included so it could be easily used with both.
#96
and greatly increases the leverage on your receiver. The generic saying about extenders/adapters is it cuts the tongue weight max in half.
#97
Liked 1,204 Times
#98
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
The 1UP will be your best choice. I know some of the history of the QuickR guy but I don't want to drag all that here. The 1UP is the way to go and they will be around a long time. I have owned one for ten years and one for a year. I have also owned the Saris, Kuat NV2, and Yakima Holdup. I sold all those. The 1Up gets my vote.
